Lv.0 등록일: 2006-10-102006-10-10T10:29:30+09:00 2006-10-10T10:29:30+09:00카테고리: AutoCAD & CADian 이런 해치 가지신 분..? 바이러스 때문인지… 갑자기 이 해치가 안 먹네요.. 파일을 찾을수가 없다는데.. 혹시 가지고 계신분 있으신가요..? 부탁드립니다. 공유 Facebook 관련 있는 질문들 객체 복사(ctrl+c) , 붙여넣기 (ctrl+v) 했는데 객체가 화면상에 보이질 않아요 객체 복사(ctrl+c) , 붙여넣기 (ctrl+v) 했는데 객체가 화면상에 보이질 않아요 오토캐드 2013 라이센스 관련 복합상가 프리미움 고급 아파트 도면 구합니다. 6 답변 작성 순 최신 순 공감 순 [Deleted User] 2006-10-10T11:07:09+09:00답변 등록 답변 등록 일시 2006-10-10 11:07 am 안되신다면…찾으시는 해치패턴이.. —————————————- *CS42,wavy line by Charles Sweeney http://www.HatchPatterns.com 0,0,10,10,10,.75,-19.25 0,.349,9.994,10,10,.75,-19.25 0,.698,9.976,10,10,.75,-19.25 0,1.045,9.945,10,10,.75,-19.25 0,1.392,9.903,10,10,.75,-19.25 0,1.736,9.848,10,10,.75,-19.25 0,2.079,9.781,10,10,.75,-19.25 0,2.419,9.703,10,10,.75,-19.25 0,2.756,9.613,10,10,.75,-19.25 0,3.09,9.511,10,10,.75,-19.25 0,3.42,9.397,10,10,.75,-19.25 0,3.746,9.272,10,10,.75,-19.25 0,4.067,9.135,10,10,.75,-19.25 0,4.384,8.988,10,10,.75,-19.25 0,4.695,8.829,10,10,.75,-19.25 0,5,8.66,10,10,.75,-19.25 0,5.299,8.48,10,10,.75,-19.25 0,5.592,8.29,10,10,.75,-19.25 0,5.878,8.09,10,10,.75,-19.25 0,6.157,7.88,10,10,.75,-19.25 0,6.428,7.66,10,10,.75,-19.25 0,6.691,7.431,10,10,.75,-19.25 0,6.947,7.193,10,10,.75,-19.25 0,7.193,6.947,10,10,.75,-19.25 0,7.431,6.691,10,10,.75,-19.25 0,7.66,6.428,10,10,.75,-19.25 0,7.88,6.157,10,10,.75,-19.25 0,8.09,5.878,10,10,.75,-19.25 0,8.29,5.592,10,10,.75,-19.25 0,8.48,5.299,10,10,.75,-19.25 0,8.66,5,10,10,.75,-19.25 0,8.829,4.695,10,10,.75,-19.25 0,8.988,4.384,10,10,.75,-19.25 0,9.135,4.067,10,10,.75,-19.25 0,9.272,3.746,10,10,.75,-19.25 0,9.397,3.42,10,10,.75,-19.25 0,9.511,3.09,10,10,.75,-19.25 0,9.613,2.756,10,10,.75,-19.25 0,9.703,2.419,10,10,.75,-19.25 0,9.781,2.079,10,10,.75,-19.25 0,9.848,1.736,10,10,.75,-19.25 0,9.903,1.392,10,10,.75,-19.25 0,9.945,1.045,10,10,.75,-19.25 0,9.976,.698,10,10,.75,-19.25 0,9.994,.349,10,10,.75,-19.25 0,10,0,10,10,.75,-19.25 —————————————————– 이거 입니다…캐드의 서포트방에 들어가셔서…ACAD.PAT ACADISO.PAT 파일열어서 그 안에다가 넣어주세여.. [Deleted User] 2006-10-10T11:00:11+09:00답변 등록 답변 등록 일시 2006-10-10 11:00 am ㅠ.ㅠ 안되는데..도대체..제가 뭘 잘못하고 있는건지.. 3번째글은 무슨말인지 쩝..–; [Deleted User] 2006-10-10T10:48:32+09:00답변 등록 답변 등록 일시 2006-10-10 10:48 am 파일이름이 캐드기본이름 이랑 같아서 바로 기타미리정의 부분에 뜰겁입니다.. 파일이름이 틀린경우는 바로 옆에 사용자부분에 뜨구여.. [Deleted User] 2006-10-10T10:46:24+09:00답변 등록 답변 등록 일시 2006-10-10 10:46 am 파일들을 몽땅 CAD의 SUPPORT 방에 넣어주신후 캐드를 다시 실행하면 해치가 로딩됩니다… [Deleted User] 2006-10-10T10:43:37+09:00답변 등록 답변 등록 일시 2006-10-10 10:43 am 감사합니다. 그런데 설명서 방법대로 했는데도.. 안된다는데요. 패턴을 찾을수가 없데요 ㅠㅠ [Deleted User] 2006-10-10T10:37:21+09:00답변 등록 답변 등록 일시 2006-10-10 10:37 am 출처 : VBCAD 의 공개자료실입니다.
안되신다면…찾으시는 해치패턴이..
