홈/ 질문/Q 96779
등록일: 2012-11-292012-11-29T18:05:02+09:00 2012-11-29T18:05:02+09:00카테고리: AutoCAD & CADian
자동치수 리습인데 2012버젼에서 안되네요;;; 부탁드립니다…
(DEFUN SUB_LINE()
  (SETQ SLI_10 (CDR (ASSOC 10 Q)))
  (SETQ SLI_11 (CDR (ASSOC 11 Q)))
  (IF (= A_KEY “VERT”)
     (PROGN
      (IF (= AL_DAT nil)(SETQ AL_DAT (LIST (CAR SLI_10) AL_DAT))
        (SETQ AL_DAT (CONS (CAR SLI_10) AL_DAT))
      (SETQ AL_DAT (CONS (CAR SLI_11) AL_DAT))
  (IF (= A_KEY “HORIZ”)
    (PROGN
      (IF (= AL_DAT nil)(SETQ AL_DAT (LIST (CADR SLI_10) AL_DAT))
        (SETQ AL_DAT (CONS (CADR SLI_10) AL_DAT))
      (SETQ AL_DAT (CONS (CADR SLI_11) AL_DAT))
(DEFUN SUB_CIRCLE()
  (SETQ CLI_10 (CDR (ASSOC 10 Q)))
    (PROGN
      (IF (= AL_DAT nil)
        (SETQ AL_DAT (LIST (CAR CLI_10) AL_DAT))
        (SETQ AL_DAT (CONS (CAR CLI_10) AL_DAT))
    (PROGN
      (IF (= AL_DAT nil)
        (SETQ AL_DAT (LIST (CADR CLI_10) AL_DAT))
        (SETQ AL_DAT (CONS (CADR CLI_10) AL_DAT))
(DEFUN SUB_POLYLINE()
  (SETQ T “TTT”)
  (WHILE T
    (SETQ C (ENTNEXT C))
    (IF (= C nil)
      (SETQ T nil)
      (PROGN
        (SETQ PL_A (ENTGET C))
        (SETQ PL_K (CDR (ASSOC 0 PL_A)))
        (IF (= PL_K “VERTEX”)
          (PROGN
            (SETQ PLI_10 (CDR (ASSOC 10 PL_A)))
              (PROGN
                (IF (= AL_DAT nil)
                  (SETQ AL_DAT (LIST (CAR PLI_10) AL_DAT))
                  (SETQ AL_DAT (CONS (CAR PLI_10) AL_DAT))
              (PROGN
                (IF (= AL_DAT nil)
                  (SETQ AL_DAT (LIST (CADR PLI_10) AL_DAT))
                  (SETQ AL_DAT (CONS (CADR PLI_10) AL_DAT))
          (SETQ T nil)
(DEFUN SUB_SORT_1()
  (SETQ SO_D (CDR (REVERSE AL_DAT)))
  (SETQ SO_L (LENGTH SO_D))
  (SETQ KEY 0)
  (SETQ T1 “TTT”)
  (WHILE T1
    (SETQ SO_AS (NTH KEY SO_D))
    (SETQ KEY (1+ KEY))
    (IF (= SO_AS nil)(SETQ T1 nil)
      (PROGN
        (SETQ KEY1 0)
        (SETQ SOR ‘())
        (SETQ T2 “TTT”)
        (WHILE T2
          (SETQ SO_AD (NTH KEY1 SO_D))
          (IF (= SO_AD nil)(SETQ T2 nil)
            (PROGN
              (IF (= SOR nil)(SETQ SOR (LIST SO_AS SOR)))
              (SETQ AS_1 (- SO_AS 0.000000001))
              (SETQ AS_2 (+ SO_AS 0.000000001))
              (IF (AND (< AS_1 SO_AD)(> AS_2 SO_AD))
                (SETQ KEY1 (1+ KEY1))
                (PROGN (SETQ SOR (CONS SO_AD SOR))
                       (SETQ KEY1 (1+ KEY1)))))
    (SETQ SO_D (CDR (REVERSE SOR)))
  (SETQ KEY 0)
  (SETQ SOR ‘())
  (REPEAT SO_L
    (SETQ SO_Y (NTH KEY SO_D))
    (SETQ SO_X (CONS KEY SO_Y))
    (IF SOR (PROGN
              (SETQ SOR (CONS SO_X SOR))
              (SETQ KEY (1+ KEY)))
            (PROGN
              (SETQ SOR (LIST SO_X SOR))
(DEFUN SUB_SORT_2()
  (SETQ SU_KEY (LENGTH SO_D))
  (REPEAT SU_KEY
    (SETQ SO_KEY 0)
    (SETQ T “KEY”)
      (WHILE T
        (SETQ SO_1 (NTH SO_KEY SO_D))
        (SETQ SO_2 (NTH (1+ SO_KEY) SO_D))
        (IF (= SO_2 nil)(SETQ T nil)
          (PROGN
          (SETQ SO_F1 (CDR SO_1))
          (SETQ SO_L1 (CDR SO_2))
          (IF (> SO_F1 SO_L1)(SETQ SO_KEY (1+ SO_KEY))
            (PROGN
            (SETQ CH_A1 (CAR SO_1))
            (SETQ CH_A2 (CDR SO_1))
            (SETQ CH_A3 (CAR SO_2))
            (SETQ CH_A4 (CDR SO_2))
            (SETQ CH_1 (CONS CH_A1 CH_A4))
            (SETQ CH_2 (CONS CH_A3 CH_A2))
            (SETQ SO_D (SUBST CH_1 SO_1 SO_D))
            (SETQ SO_D (SUBST CH_2 SO_2 SO_D))
(DEFUN SUB_DIM()
  (IF (= A_KEY  “VERT”)(SETQ DI_A (CADR P4)))
  (IF (= A_KEY “HORIZ”)(SETQ DI_A (CAR P4)))
    (PROGN
    (SETQ DI_FR (LIST (CDR (NTH 0 SO_D)) DI_A))
    (SETQ DI_LA (LIST (CDR (LAST  SO_D)) DI_A))
    (COMMAND “DIM” “HORIZ” DI_LA DI_FR (POLAR P4 A_ANG LE_H) “”)))
    (PROGN
    (SETQ DI_FR (LIST DI_A (CDR (NTH 0 SO_D))))
    (SETQ DI_LA (LIST DI_A (CDR (LAST  SO_D))))
    (COMMAND “DIM” “VERT” DI_LA DI_FR (POLAR P4 A_ANG LE_H) “”)))
  (SETQ SU_K (- SU_KEY 1))
  (SETQ SO 1)
  (REPEAT SU_K
    (IF (= A_KEY “HORIZ”)(PROGN
      (SETQ DI_NE (LIST DI_A (CDR (NTH SO SO_D))))
      (IF (= SO 1)(COMMAND “DIM” “VERT” DI_FR DI_NE (POLAR P4 A_ANG LE_T) “”)
      (COMMAND “DIM” “CONT” DI_NE “”))))
    (IF (= A_KEY “VERT”)(PROGN
      (SETQ DI_NE (LIST (CDR (NTH SO SO_D)) DI_A))
      (IF (= SO 1)(COMMAND “DIM” “HORIZ” DI_FR DI_NE (POLAR P4 A_ANG LE_T) “”)
    (SETQ SO (1+ SO))
(COMMAND “EXIT”)
(COMMAND “DIMZIN” 0 “DIMTIX” OFF “”)
(COMMAND “LAYER” “S” LA_YER “”)
(DEFUN C:ad_6()
  (REDRAW)
  (SETQ LA_YER (GETVAR “CLAYER”))
  (COMMAND “LAYER” “M” “DIM” “C” “” “” “S” “DIM” “”)
  (SETQ OS_MODE (GETVAR “OSMODE”))
  (SETVAR “OSMODE” 0)
  (SETVAR “CMDECHO” 1)
  (SETVAR “ORTHOMODE” 1)
  (prompt “n       <  Design System>”)
  (PROMPT “n * SELECT OBJECT  TO DIM *”)
  (SETQ LE_H (* 30 (GETVAR “DIMSCALE”)))
  (SETQ LE_T (* 20 (GETVAR “DIMSCALE”)))
  (SETQ AL_DAT ‘())
  (SETQ H (SSGET))
;  (SETQ P1 (GETPOINT  “n SELECT FIRST POINT :”))
;  (SETQ P2 (GETCORNER “n SELECT AREA  POINT :” P1))
  (SETQ P3 (GETPOINT  “n ANGLE  FIRST POINT :”))
  (SETQ P4 (GETPOINT  “n ANGLE  END   POINT :” P3))
  (SETQ A_KEY nil)
  (SETQ A_ANG (ANGLE P3 P4))
  (IF (OR (= A_ANG (* 1.5 PI))(= A_ANG (* 0.5 PI)))
  (SETQ A_KEY “VERT”))
  (IF (OR (= A_ANG PI)(= A_ANG 0))
  (SETQ A_KEY “HORIZ”))
  (SETQ B (SSLENGTH H))
  (SETQ INDEX 0)
  (REPEAT B
    (SETQ C (SSNAME H INDEX))
    (SETQ Q (ENTGET C))
    (SETQ SP (CDR (ASSOC 0 Q)))
    (IF (= SP “LINE”)(SUB_LINE))
    (IF (= SP “CIRCLE”)(SUB_CIRCLE))
    (IF (= SP “POLYLINE”)(SUB_POLYLINE))
    (SETQ INDEX (1+ INDEX))
  (SUB_SORT_1)
  (SUB_SORT_2)
  (SUB_DIM)
  (SETVAR “OSMODE” OS_MODE)
  (SETVAR “HIGHLIGHT” 1)
  (PRIN1)
자동치수 리습인데 2008에서는 사용이 되는데 2012버젼에서는
객체 선택:
 ANGLE  FIRST POINT :
 ANGLE  END   POINT :DIM
** 해당 명령은 투명명령처럼 호출될 수 없음 **
; 오류: 함수가 취소되었습니다.
이렇게 메세지가 나오네요.. 고수님들 부탁드립니다…
  • 31 조회
    • 캐드2007에서 다중지시선 메뉴가 없나요?
    • 이벤트 공유
