홈/ 질문/Q 26894
등록일: 2001-10-312001-10-31T12:00:58+09:00 2001-10-31T12:00:58+09:00카테고리: AutoCAD & CADian
출력시 용지 길이를 맘대로 정할려고 합니다!
안녕하세요!저는 캐드 2000을 사용하는데요!
출력할때 도면길이를 제가 원하는 용지크기(가로,세로)로 설정하고 싶은데
어디 들어가서 어떻게 할지 몰라서요.플롯에 들어가면 정해진 크기 밖에 없네요
도움주시면 감사하겠습니다.
  • 81 조회
    2. CADMAN
      2001-10-31T15:01:39+09:00답변 등록 답변 등록 일시 2001-10-31 3:01 pm
      참 필요한 Dialogue box File 입니다..
    3. CADMAN
      2001-10-31T14:57:11+09:00답변 등록 답변 등록 일시 2001-10-31 2:57 pm
      그러면 이렇게 해 보세요.
      Modifying the Printable Area of a Paper Size
      1.In the Plot dialog box, on the Plot Device tab, select
      the device for which you want to modify a paper size.
      2.Choose Properties (to the right of the device name) to
      launch the Plotter Configuration Editor.
      3.In the Plotter Configuration Editor, choose Modify Standard Paper
      Size at the bottom of the list.
      4.In the Plotter Configuration Editor, select the paper size for
      which you want to modify the printable area. Then choose Modify.
      The Custom Paper Size wizard is launched.
      5.In the Custom Paper Size wizard, specify the printable area you
      want. Choose Next twice and then Finish.
      Note: When specifying the non-printable area of a paper size,
      you need to distribute the margin to all four sides of the
      paper. For example,
      if you would like to specify a printable area for
      an 11″x17″ paper size as 10.6″x16.5″,
      specify the following:
      Top: 0.3″, Bottom: 0.2″, Right: 0.2, Left: 0.2″.
      6.In the Plotter Configuration Editor,
      choose OK to save your changes. When you are
      prompted to save a plotter configuration file,
      choose Save Changes to the Following File,
      and then choose OK.
      A plotter configuration file has now been created containing
      the changes to the paper size that you have made.
      The plotter configuration file will appear in the Plot Device
      list in the Plot dialog box.
      Make sure you select this plotter configuration file when you plot.
      그럼.
    4. 정아
      2001-10-31T13:47:03+09:00답변 등록 답변 등록 일시 2001-10-31 1:47 pm
      답변 감사합니다…근데 잘 모르겠네요…!
      플롯 장치에 그런기능이 없는거 같아서요.
      플롯 설정값에서는 사용자 정의는 있고 용지를 선택할수는 있는데,제가 정할수는 없네요.
      다시한번 답변 주시면 고맙겠습니다…
    5. CADMAN
      2001-10-31T12:12:47+09:00답변 등록 답변 등록 일시 2001-10-31 12:12 pm
      안녕하세요
      먼저 Plot Dialogue Box에 설정된 Plotter Device를 보시면 Roll지를
      Control 할 수 있는 것인지를 보셔야 하고.
      용지를 설정 할 수 있는 Plotter이면 그 옆의 Plot Setting에서
      용지의 크기를 조절 하시면 될 것 같네요…
      그럼.
