안녕하세요
레이어 생성 리습을 너무 유용하게 잘 사용중입니다.
만들어주신분께 감사말씀드립니다.
근데 레이어생성 후 해당 레이어가 플롯안됨으로 생성되게 하고 싶은데 방법을 모르겠습니다.
고수님 알려주세요!
(defun c:lk()
(if (= nil (tblsearch “layer” “_1”))(command “layer” “m” “_1” “lt” “continuous” “” “co” “1” “” “”))
(if (= nil (tblsearch “layer” “_2”))(command “layer” “m” “_2” “lt” “continuous” “” “co” “2” “” “”))
(if (= nil (tblsearch “layer” “_3”))(command “layer” “m” “_3” “lt” “continuous” “” “co” “3” “” “”))
(if (= nil (tblsearch “layer” “_4”))(command “layer” “m” “_4” “lt” “continuous” “” “co” “4” “” “”))
(if (= nil (tblsearch “layer” “_5”))(command “layer” “m” “_5” “lt” “continuous” “” “co” “5” “” “”))
(if (= nil (tblsearch “layer” “_6”))(command “layer” “m” “_6” “lt” “continuous” “” “co” “6” “” “”))
(if (= nil (tblsearch “layer” “_7”))(command “layer” “m” “_7” “lt” “continuous” “” “co” “7” “” “”))
(if (= nil (tblsearch “layer” “_8”))(command “layer” “m” “_8” “lt” “continuous” “” “co” “8” “” “”))
(if (= nil (tblsearch “layer” “_작업”))(command “layer” “m” “_작업” “lt” “continuous” “” “co” “6” “” “”))
(if (= nil (tblsearch “layer” “_수정”))(command “layer” “m” “_수정” “lt” “continuous” “” “co” “2” “” “”))
(if (= nil (tblsearch “layer” “_1”))(command “layer” “m” “_1” “lt” “continuous” “” “co” “1” “” “” “p” “n”))
답글감사합니다만 제대로 작동이 안됩니다.ㅠㅠ
