홈/ 질문/Q 111536
등록일: 2019-07-152019-07-15T06:25:24+09:00 2019-07-15T06:25:24+09:00카테고리: AutoCAD & CADian
텍스트합산 리습 문의드러요
       (defun c:ts (/ z ss sno no tno sum x entity etype num h pt)
       (setvar “cmdecho” 0)
       (prompt “nSelect Text: “)
       (setq ss (ssget))
       (setq sno (sslength ss))
       (setq no 0)
       (setq sum 0.0)
       (setq tno 0)
       (repeat sno
           (setq x (ssname ss no))
           (setq etype (cdr (assoc 0 (entget x))))
           (if (= etype “TEXT”)
               (progn
                  (setq entity (entget x))
                  (setq num (cdr (assoc 1 entity)))
                  (setq num (atof num))
                  (setq sum (+ sum num))
                  (setq tno (1+ tno))
           (setq no (1+ no))
       (setq tno (itoa tno))
       (setq sum (rtos sum 2 3))
       (princ “nAdding “)
       (princ tno)
       (princ ” nTexts: “)
       (princ “nThe Result is: “)
       (princ sum)
       (princ ”   “)
       (princ “nDo You Want Write it into the DWG? <y> “)
       (setq z (strcase (getstring)))
       (if (or (= z “”) (= z “Y”))
           (progn
               (setq pt (getpoint “nText Point: “))
               (setq h (getvar “textsize”))
               (prompt “nText Height: “)
               (princ H)
               (princ ”  : “)
               (setq z (getdist))
               (if z
                   (setq h z)
               (command “text”
                        (setq z pt)
                        (setq z h)
                        (setq z 0.0)
                        (setq z sum)
       (setvar “cmdecho” 1)
       (setvar “blipmode” 1)
       (prin1))
텍스트합산 리습인데 혹시 소수점 1까지 표시하고 뒤에다가 m단위 붙을수있을까요?
  • 134 조회
      2019-07-15T12:12:42+09:00답변 등록 답변 등록 일시 2019-07-15 12:12 pm
      감사합니다!
    3. 자유천지 Lv.8
      2019-07-15T06:34:00+09:00답변 등록 답변 등록 일시 2019-07-15 6:34 am
      -> (setq sum (strcat  (rtos sum 2 1) ” m”))
