홈/ 질문/Q 102425
gogohh3
gogohh3Lv.0
등록일: 2014-10-232014-10-23T10:01:01+09:00 2014-10-23T10:01:01+09:00카테고리: AutoCAD & CADian
포함하고 있는 텍스트에 따라 색깔을 바꾸는 리습인데 다중선택할수있게 하는법을…알고시퍼요
(vl-load-com)
(defun c:CS( / s str ob)
 (if (setq s (car (entsel)))
  (cond
   ((wcmatch (setq str (strcase (vlax-get (setq ob (vlax-ename->vla-object s)) ‘textstring))) “*D10*”)
    (vlax-put ob ‘color 80)
   ((wcmatch str “*D13*”)
    (vlax-put ob ‘color 130)
   ((wcmatch str “*D16*”)
    (vlax-put ob ‘color 170)
   ((wcmatch str “*D19*”)
    (vlax-put ob ‘color 190)
   ((wcmatch str “*D21*”)
    (vlax-put ob ‘color 210)
이렇게 되어있는데 이거는 각각 선택을 따로해야되는데 다중선택해서 적용해주려면 어떻게 해야할까요?
  • 21 조회
      2014-10-23T11:47:02+09:00답변 등록 답변 등록 일시 2014-10-23 11:47 am
      (defun c:CS( / str)
       (if (ssget ‘((0 . “*TEXT”)))
        (vlax-for ob (vla-get-ActiveSelectionSet (vla-get-ActiveDocument (vlax-get-acad-object)))
         (cond
            ((wcmatch (setq str (strcase (vlax-get ob ‘textstring))) “*D10*”)
