홈/ 질문/Q 95263
등록일: 2012-05-252012-05-25T16:00:32+09:00 2012-05-25T16:00:32+09:00카테고리: AutoCAD & CADian
해치관련 문의 입니다.
안녕하세요~ 캐드 사용시 궁금한게있어 글 남깁니다.
혹시 PL라인 선 안에 여러 객체의 해치가  PL라인 기준으로 한꺼번에 삭제되는 명령어가 있는지 해서요~
기존 방법은 기준선안에 여러패턴의 해치를 각각 따로 삭제했는데 아시는분이 기억은 나지 않지만
여러객체의 해치를 한꺼번에 지울수있다고 하셔서 문의 드립니다.
아래 첨부하는 내용은 그분이 보내주신 자료입니다.
;;; HATCHB.LSP
;;; Recreates hatch boundary by selecting a hatch
;;; Boundary is created in current layer/color/linetype in WCS
;;; By Jimmy B
;;; e-mail: cadman@yesbox.net
;;; 2000-02-12 – First release
;;; 2000-03-27 – Counterclockwise arc’s and ellipse’s fixed
;;;              Objects created joined to lwpolyline if possible
;;;              Error-handling, undo of command
;;;              Can handle PLINETYPE = 0,1,2
;;; 2000-03-30 – Integrating hatchb and hatchb14
;;;              Selection of many hatches
;;;              Splines supported if closed.
;;; Tested on AutoCAD 2000
;;; should be working on older versions too.
(defun c:hb () (c:hatchb)) ; this line can be commented out if there is anexisting command called hb
(defun c:hatchb (/     es    blay  ed1   ed2   loops1      bptf  part
             et    noe   plist ic    bul   nr    ang1  ang2  obj
*ModelSpace* *PaperSpace*
             space cw errexit undox olderr oldcmdecho ss1 lastent en1 en2 ss
lwp
             list->variantArray 3dPoint->2dPoint A2k ent i ss2
             knot-list controlpoint-list kn cn pos
  (setq A2k (wcmatch (getvar “ACADVER”) “15*”))
 (if A2k
  (defun list->variantArray (ptsList / arraySpace sArray)
    (setq arraySpace
      (vlax-make-safearray
        vlax-vbdouble
        (cons 0 (- (length ptsList) 1))
    (setq sArray (vlax-safearray-fill arraySpace ptsList))
    (vlax-make-variant sArray)
 (if A2k
  (defun 3dPoint->2dPoint (3dpt)
    (list (float (car 3dpt)) (float (cadr 3dpt)))
  (defun errexit (s)
    (princ “nError:  “)
    (princ s)
    (restore)
  (defun undox ()
    (command “._ucs” “_p”)
    (command “._undo” “_E”)
    (setvar “cmdecho” oldcmdecho)
    (setq *error* olderr)
  (setq olderr  *error*
        restore undox
        *error* errexit
  (setq oldcmdecho (getvar “cmdecho”))
  (setvar “cmdecho” 0)
  (command “._UNDO” “_BE”)
  (if A2k (progn
    (vl-load-com)
    (setq *ModelSpace* (vla-get-ModelSpace
                         (vla-get-ActiveDocument (vlax-get-acad-object))
          *PaperSpace* (vla-get-PaperSpace
  (if (/= (setq ss2 (ssget ‘((0 . “HATCH”)))) nil)
   (progn
    (setq i 0)
    (while (setq ent (ssname ss2 i))
      (setq ed1 (entget ent))
      (if (not (equal (assoc 210 ed1) ‘(210 0.0 0.0 1.0))) (princ “nHatch
not in WCS!”))
      (command “._ucs” “_w”)
      (setq loops1 (cdr (assoc 91 ed1))) ; number of boundary paths (loops)
      (if (and A2k (= (strcase (cdr (assoc 410 ed1))) “MODEL”))
        (setq space *ModelSpace*)
        (setq space *PaperSpace*)
      (repeat loops1
        (setq ed1 (member (assoc 92 ed1) ed1))
        (setq bptf (cdr (car ed1))) ; boundary path type flag
        (setq ic (cdr (assoc 73 ed1))) ; is closed
        (setq noe (cdr (assoc 93 ed1))) ; number of edges
        (setq ed1 (member (assoc 72 ed1) ed1))
        (setq bul (cdr (car ed1))) ; bulge
        (setq plist nil)
        (setq blist nil)
        (cond
          ((> (boole 1 bptf 2) 0) ; polyline
           (repeat noe
             (setq ed1 (member (assoc 10 (cdr ed1)) ed1))
             (setq plist (append plist (list (cdr (assoc 10 ed1)))))
             (setq blist (append blist
                                 (if (> bul 0)
                                   (list (cdr (assoc 42 ed1)))
                                   nil
           (if A2k (progn
             (setq polypoints
                    (apply ‘append
                           (mapcar ‘3dPoint->2dPoint plist)
             (setq VLADataPts (list->variantArray polypoints))
             (setq obj (vla-addLightweightPolyline space VLADataPts))
             (setq nr 0)
             (repeat (length blist)
               (if (/= (nth nr blist) 0)
                 (vla-setBulge obj nr (nth nr blist))
               (setq nr (1+ nr))
             (if (= ic 1)
               (vla-put-closed obj T)
            (progn
              (if (= ic 1)
                (entmake ‘((0 . “POLYLINE”) (66 . 1) (70 . 1)))
                (entmake ‘((0 . “POLYLINE”) (66 . 1)))
              (setq nr 0)
              (repeat (length plist)
                (if (= bul 0)
                  (entmake (list (cons 0 “VERTEX”)
                                 (cons 10 (nth nr plist))
                                 (cons 42 (nth nr blist))
                (setq nr (1+ nr))
              (entmake ‘((0 . “SEQEND”)))
          (t ; not polyline
           (setq lastent (entlast))
           (setq lwp T)
           (repeat noe
             (setq et (cdr (assoc 72 ed1)))
             (cond
               ((= et 1) ; line
                (if A2k
                  (vla-AddLine
                    space
                    (vlax-3d-point (cdr (assoc 10 ed1)))
                    (vlax-3d-point (cdr (assoc 11 ed1)))
                  (entmake
                    (list (cons 0 “LINE”) (assoc 10 ed1) (assoc 11 ed1))
                (setq ed1 (cddr ed1))
               ((= et 2) ; circular arc
                 (setq ang1 (cdr (assoc 50 ed1)))
                 (setq ang2 (cdr (assoc 51 ed1)))
                 (setq cw (cdr (assoc 73 ed1)))
                 (if (equal ang2 6.28319 0.00001)
                   (progn
                     (if A2k
                       (vla-AddCircle
                         space
                         (cdr (assoc 40 ed1))
                       (entmake (list (cons 0 “CIRCLE”)
                                      (assoc 10 ed1)
                                      (assoc 40 ed1)
                     (setq lwp nil)
                   (if A2k
                     (vla-AddArc
                       space
                       (if (= cw 0)
                         (- 0 ang2)
                         ang1
                       (if (= cw 0)
                         (- 0 ang1)
                         ang2
                     (entmake (list (cons 0 “ARC”)
                                    (assoc 10 ed1)
                                    (assoc 40 ed1)
                                    (cons 50
                                          (if (= cw 0)
                                            (- 0 ang2)
                                            ang1
                                    (cons 51
                                          (if (= cw 0)
                                            (- 0 ang1)
                                            ang2
                 (setq ed1 (cddddr ed1))
               ((= et 3) ; elliptic arc
                (if A2k (progn
                  (setq obj (vla-AddEllipse
                              space
                  (vla-put-startangle obj (if (= cw 0) (- 0 ang2) ang1))
                  (vla-put-endangle obj (if (= cw 0) (- 0 ang1) ang2))
                 (princ “nElliptic arc not supported!”)
                (setq lwp nil)
               ((= et 4) ; spline
                (setq ed1 (member (assoc 94 (cdr ed1)) ed1))
                (setq knot-list nil)
                (setq controlpoint-list nil)
  (setq kn (cdr (assoc 95 ed1)))
                (setq cn (cdr (assoc 96 ed1)))
                (setq pos (vl-position (assoc 40 ed1) ed1))
                (repeat kn
                  (setq knot-list (cons (cons 40 (cdr (nth pos ed1)))
knot-list))
                  (setq pos (1+ pos))
                (setq pos (vl-position (assoc 10 ed1) ed1))
                (repeat cn
                  (setq controlpoint-list (cons (cons 10 (cdr (nth pos
ed1))) controlpoint-list))
                  (setq pos (1+ pos))
                (setq knot-list (reverse knot-list))
                (setq controlpoint-list (reverse controlpoint-list))
                (entmake (append
                 (list ‘(0 . “SPLINE”))
                               (list (cons 100 “AcDbEntity”))
                               (list (cons 100 “AcDbSpline”))
                               (list (cons 70 (+ 1 8 (* 2 (cdr (assoc 74
ed1))) (* 4 (cdr (assoc 73 ed1))))))
                               (list (cons 71 (cdr (assoc 94 ed1))))
                               (list (cons 72 kn))
                               (list (cons 73 cn))
                               knot-list
                               controlpoint-list
  (setq ed1 (member (assoc 10 ed1) ed1))
                (setq lwp nil)
             ) ; end cond
           ) ; end repeat noe
           (if lwp (progn
             (setq en1 (entnext lastent))
             (setq ss (ssadd))
             (ssadd en1 ss)
             (while (setq en2 (entnext en1))
               (ssadd en2 ss)
               (setq en1 en2)
             (command “_.pedit” (entlast) “_Y” “_J” ss “” “”)
          ) ; end t
        ) ; end cond
      ) ; end repeat loops1
      (setq i (1+ i))
  (restore)
  • 48 조회
