홈/ 질문/Q 110960
등록일: 2019-02-182019-02-18T14:03:43+09:00 2019-02-18T14:03:43+09:00카테고리: AutoCAD & CADian
해치테이블 리습입니다. 면적단위수정 (㎡) 부탁드립니다.
레이로 구별된 해치를 선택하면 해치 면적을 표로 만들어주는
리습입니다. 표로 정리된는데 단위가 ㎡가 아닙니다. 면적 단위 변경 요청드립니다.
(Defun c:HatchTAble ( / AllData ss e edata Area_table crow bn area_ ssNH)
(vl-load-com)
;;; pBe 23Apr2013 ;;;
;;; Mod for FSJ_Mo : Layer instead of Block swatches ;;;
;; pBe 18Jul2013 ;;;
  (if
    (setq AllData nil ssNH (ssadd)
          ss      (ssget ‘((0 . “Hatch”)))
     (progn
       (repeat (setq i (sslength ss))
         (setq e (vlax-ename->vla-object (ssname ss (Setq i (1- i)))))
         (setq edata
                (list
                  (vlax-get e ‘Layer)
                  (IF
                    (not
                      (vl-catch-all-error-p
                        (setq area_ (vl-catch-all-apply ‘vla-get-area (list E)))
                     area_
                     (progn (ssadd (ssname ss i) ssNH) 0.0)
         (setq AllData
                (if (setq f (assoc (car edata) AllData))
                  (subst (list (car f) (+ (cadr f) (cadr edata))) f Alldata)
                  (cons edata AllData)
       (setq AllData (vl-sort AllData ‘(lambda (m n) (> (Cadr m) (cadr n)))))
       (setq Area_table
              (vlax-invoke
                (vlax-get (vla-get-ActiveLayout
                            (vla-get-activedocument (vlax-get-acad-object))
                          ‘Block
                ‘Addtable
                (getpoint “nPick point for Table:”)
                2  2 50 275
       (vla-settext Area_table 0 0 “Area Tabulation”)
       (vla-setcelltextheight Area_table 0 0 20.0)
       (mapcar ‘(lambda (y)
                  (vla-settext Area_table 1 (car y) (cadr y))
                  (vla-setcelltextheight Area_table 1 (car y) 20.0)
               (list ‘(0 “Area”) ‘(1 “Layer”))
       (foreach d AllData
         (vla-insertrows
           Area_table
           (1+ (setq crow (vla-get-rows Area_table)))
           50
           1
         (vla-setCellValue Area_table crow 0 (cadr d))
         (vla-setcelltextheight Area_table crow 0 20.0)
         (vla-setCellAlignment Area_table crow 0 5)
         (vla-setcellformat Area_table crow 0 “%lu2%pr2%th44”)
(vla-setcelltextheight Area_table crow 1 20.0)
         (vla-setCellAlignment Area_table crow 1 5)
(vla-setCellValue Area_table crow 1 (car d))
  • 191 조회
    • 캐드 좌표값을 위경도값으로 산출 가능할까요?
    • 오토캐드 호그리기 질문
    2. LEE Lisp Lv.2
      2019-02-18T15:23:13+09:00답변 등록 답변 등록 일시 2019-02-18 3:23 pm
      (vla-setcellformat Area_table crow 0 “%lu2%pr2%th44%ct8[0.000001]”)
      2019-02-18T18:16:43+09:00답변 등록 답변 등록 일시 2019-02-18 6:16 pm
      감사합니다
