홈/ 질문/Q 53597
샘골길동이
샘골길동이Lv.0
등록일: 2005-06-092005-06-09T13:06:51+09:00 2005-06-09T13:06:51+09:00카테고리: AutoCAD & CADian
dxf 화일이 안열여요~~
The following error was encountered while reading
in TEXT starting at line 16318:
Missing DXF group code: 1
Invalid or incomplete DXF input — drawing discarded.
Regenerating model.
Initializing….
….Done.
AutoCAD menu utilities loaded.*Cancel*
Command:
Command:
Command: _open
이케 나오네요…..=,.=;; 해결좀 부탁드립니다…
참 autodesk map 2004 씁니다..
  • 16 조회
    • cadplus_plot 사용방법 질문드립니다
