홈/ 질문/Q 105849
등록일: 2016-01-122016-01-12T10:46:05+09:00 2016-01-12T10:46:05+09:00카테고리: AutoCAD & CADian
handrail lisp
핸드레일 리습인데요 2007번전이라 그런지 작동이 안되는데요 2007에서 가능한 버전 으로 부탁드립니다.
(defun c:hrail (/ x y z q dy h m xx xs xp dq hz i
                 fl cl tl ul ml)
(while (or (not x)
           (not (< 4 x 240)))
       (initget 7)
       (setq x (getdist "nOverall Width S-S ( 4-240 ):   ")))
(initget 6)
(setq y (getdist "nHeight T-B <42>:   "))
(or y (setq y 42.))
(initget 6)
(setq z (getdist "nTube Size <1.5>:   "))
(or z (setq z 1.5))
(setq dq (cond ((<= x 50) 0)
               (T
                (fix (/ x 42)))))
(initget 4)
(setq q (getint (strcat "nMiddle Upright Qty <" (itoa dq) ">:   ")))
(or q (setq q dq))
(setq dy (* (- y z) 0.5))
(setq h (getdist (strcat "nMid Rail Height <" (rtos dy 2 2) ">:   ")))
(or h (setq h dy))
(initget 1 "Mild Stainless")
(setq m (getkword "nMaterial - Mild/Stainless:   "))
;;;HALF TUBE
(setq hz (* z 0.5))
;;;UPRIGHT SPACING
(setq xx (- x z)
      xs (/ xx (1+ q))
      xp hz)
;;;CENTER LINE LIST
(setq cl (list hz))
(repeat q
 (setq cl (cons (+ xp xs) cl)
       xp (+ xp xs)))
(setq cl (cons (- x hz) cl))
(setq cl (reverse cl))
;;;MAIN FRAME LIST
(setq fl (list (list (car cl)        0  0)
               (list (car cl)  (- y hz) 0)
               (list (last cl) (- y hz) 0)
               (list (last cl)       0  0)))
;;;UPRIGHT LIST
(setq i 1)
(repeat q
  (setq ul (cons (list (list (nth i cl) 0 0)
                       (list (nth i cl) (- y z) 0)) ul))
  (setq i (1+ i)))
;;;MID SUPPORTS
(setq tl cl)
(while (> (length tl) 1)
  (setq ml (cons (list (list (+ (car tl) hz) h 0)
                       (list (- (cadr tl) hz) h 0)) ml))
  (setq tl (cdr tl)))
(setvar "CMDECHO" 1)
(setvar "TRACEWID" z)
(setvar "THICKNESS" z)
(setvar "SNAPMODE" 0)
(command "_.UCS" "_W")
(command "_.TRACE" "")
(foreach v fl (command v))
(command "")
(foreach v ml
  (command (car v))
  (command (cadr v))
  (command ""))
(foreach v ul
  (command (car v))
  (command (cadr v))
  (command ""))
(prin1))
  • 68 조회
    • 선배님들 덕트 엘보 작성 리습좀 봐주세요
    2. 수야12 Lv.21
      2016-01-14T07:33:19+09:00답변 등록 답변 등록 일시 2016-01-14 7:33 am
      64비트 2008 작동은 합니다  (다른 사람리습을 연구목적이 아니라면 구지(이것도 맞고 “굳이”도 맞음.)구문해석의 즐거움을 거부할 경우도 많습니다..)
      원하시는 결과물의 파일을 같이 올리시면 파일 수정 가능하신분들이 수정하기 편할겁니다
