홈/ 질문/Q 108827
등록일: 2017-08-252017-08-25T10:51:09+09:00 2017-08-25T10:51:09+09:00카테고리: AutoCAD & CADian
lisp 속도
수고 많으십니다.
리습으로 간단하게 레이어 생성하는것을 만들어 사용하고 있습니다.
리습을 실행후 다른 명령어를 입력하면
이 리습이 다시 실행되는듯 하며 속도가 느려집니다.
무엇이 문제인지 조언 부탁 드립니다.
수고하세요
  • 48 조회
      2017-08-25T12:45:57+09:00답변 등록 답변 등록 일시 2017-08-25 12:45 pm
      처음 올려주신 리습의 경우 오류가 뜨면서 실행이 되지 않았습니다. 보니 리습에 남는 괄호가 2개 나왔더군요.
      ;** kylenc ************************************************************************
      (DEFUN C:lam()
             (command “-linetype” “L” “~” “come.lin” “” “”)
             (command “LAYER” “M” “A” “C” “8” “” “”)
             (command “LAYER” “M” “TEXT” “C” “7” “” “”)
             (command “LAYER” “M” “MTEXT” “C” “3” “” “”)
             (command “LAYER” “M” “DIM” “C” “15” “” “”)
             (command “LAYER” “M” “KLDIM” “C” “1” “” “”)
             (command “LAYER” “M” “DS” “C” “4” “” “”)
             (command “LAYER” “M” “AIR” “C” “3” “” “”)
             (command “LAYER” “M” “Rt” “C” “2” “” “”)
             (command “LAYER” “M” “EQ” “C” “7” “” “”)
             (command “LAYER” “M” “FF” “C” “3” “” “”)
             (command “LAYER” “M” “JB” “C” “1” “” “”)
             (command “LAYER” “M” “cen” “C” “1” “” “L” “center” “” “”)
             (command “LAYER” “M” “MA” “C” “15” “” “”)
             (command “LAYER” “M” “si” “C” “2” “” “”)
             (command “LAYER” “M” “pipe” “C” “3” “” “”)
             (command “LAYER” “M” “OA” “C” “5” “” “”)
             (command “LAYER” “M” “SA” “C” “3” “” “”)
             (command “LAYER” “M” “RA” “C” “6” “” “”)
             (command “LAYER” “M” “EA” “C” “4” “” “”)
             (command “LAYER” “M” “PW” “C” “5” “” “”)
             (command “LAYER” “M” “CW” “C” “5” “” “”)
             (command “LAYER” “M” “DHWS” “C” “6” “” “”)
             (command “LAYER” “M” “DHWR” “C” “1” “” “”)
             (command “LAYER” “M” “D” “C” “11” “” “”)
             (command “LAYER” “M” “S” “C” “10” “” “”)
             (command “LAYER” “M” “V” “C” “3” “” “L” “PASUN2” “” “”)
             (command “LAYER” “M” “RGRL” “C” “3” “” “”)
             (command “LAYER” “M” “ED” “C” “11” “” “”)
             (command “LAYER” “M” “CHS” “C” “3” “” “”)
             (command “LAYER” “M” “CHR” “C” “6” “” “”)
             (command “LAYER” “M” “CTWS” “C” “6” “” “”)
             (command “LAYER” “M” “CTWR” “C” “4” “” “”)
             (command “LAYER” “M” “MS” “C” “6” “” “”)
             (command “LAYER” “M” “MC” “C” “2” “” “”)
             (command “LAYER” “M” “AMA” “C” “251” “” “”)
             (command “LAYER” “M” “250” “C” “250” “” “”)
             (command “LAYER” “M” “251” “C” “251” “” “”)
             (command “LAYER” “M” “252” “C” “252” “” “”)
             (command “LAYER” “M” “253” “C” “253” “” “”)
             (command “LAYER” “M” “254” “C” “254” “” “”)
             (command “LAYER” “M” “255” “C” “255” “” “”)) <- 이거
        ) <- 이거
      밑줄 표시된 괄호 2개를 빼고 하니 리습이 실행되고 명령어도 정상 입력되는 걸 확인했습니다. 윈도우7 autocad 2015 다른 보조프로그램 사용 하나도 하지 않았을 때를 기준으로 합니다.
      2017-08-25T13:08:21+09:00답변 등록 답변 등록 일시 2017-08-25 1:08 pm
      답변 감사합니다.
      그거 수정해도,,
      계속 버벅 거리고,,,명령어가 실행 되는듯 합니다.
      ㅠ.ㅠ
    4. 심심할땐커피한잔 Lv.0
      2017-11-10T13:45:11+09:00답변 등록 답변 등록 일시 2017-11-10 1:45 pm
      (DEFUN C:lam() 밑에 (setvar “cmdecho” 0)   <<< 추가해보셔요
