홈/ 질문/Q 113435
JunGuri
JunGuriLv.0
등록일: 2021-11-122021-11-12T10:53:33+09:00 2021-11-12T10:53:33+09:00카테고리: AutoCAD & CADian
LM 리습에 중복값? 없이? 수정좀 알려주세요.
(defun c:Lm (/ ss sslist i index linelist linenumlist ent old10 old11 dist lnum count temp total total1 subtotal txt pt)
        ;—->total1 추가함
  (princ “n Eltity Length Sum”)
  (setvar “cmdecho” 0)
  (setq ss (ssget (list (cons 0 “LINE,CIRCLE,ARC,POLYLINE,LWPOLYLINE,ELLIPSE,SPLINE”))))
  (if ss
    (progn
      (setq index 0)
      (setq linelist nil)
      (setq linenumlist nil)
      (repeat (sslength ss)
        (setq ent (ssname ss index))
        (command-s “lengthen” ent “” “” “”)
        (setq dist (GETVAR “PERIMETER”))
        (if (apply ‘or (mapcar ‘(lambda (x) (equal dist x 1)) linelist))
          (progn
            (setq temp 0)
            (setq lnum nil)
            (foreach x linelist
              (if (equal dist x 1)
                (setq lnum temp)
              (setq temp (1+ temp))
            (setq count 0)
            (setq temp nil)
            (foreach x linenumlist
              (if (= count lnum)
                (setq temp (append temp (list (+ x 1))))
                (setq temp (append temp (list x)))
              (setq count (1+ count))
            (setq linenumlist temp)
          (progn
            (setq linelist (append linelist (list dist)))
            (setq linenumlist (append linenumlist (list 1)))
        (setq index (1+ index))
      (setq txt “”)
      (setq count 0)
      (setq total 0)
      (setq subtotal 0)
      (repeat (length linelist)
        (if (= count 0)
          (if (> (nth count linenumlist) 1)
            ;;;;(setq txt (strcat “nL = ” (rtos (/ (nth count linelist) 1.0) 2 2) “*” (rtos (nth count linenumlist) 2 0) “개”))
            ;;;;(setq txt  (strcat “nL = ” (rtos (/ (nth count linelist) 1.0) 2 2)))
            (setq txt (strcat “nL = ” (rtos (/ (nth count linelist) 1000.0) 2 2) “*” (rtos (nth count linenumlist) 2 0) “개”))
            (setq txt  (strcat “nL = ” (rtos (/ (nth count linelist) 1000.0) 2 2)))
            ;;;;(setq txt (strcat txt ” + ” (rtos (/ (nth count linelist) 1.0) 2 2) “*” (rtos (nth count linenumlist) 2 0) “개”))
            ;;;;(setq txt (strcat txt ” + ” (rtos (/ (nth count linelist) 1.0) 2 2)))
            (setq txt (strcat txt ” + ” (rtos (/ (nth count linelist) 1000.0) 2 2) “*” (rtos (nth count linenumlist) 2 0) “개”))
            (setq txt (strcat txt ” + ” (rtos (/ (nth count linelist) 1000.0) 2 2)))
        (setq subtotal (* (/ (nth count linelist) 1) (nth count linenumlist)))
        (setq total (+ subtotal total))
        (setq total1 (/ total 1000));————->추가함
      ;;;;(setq txt (strcat txt ” = ” (rtos total 2 2) “m”))
      (setq txt (strcat txt ” = ” (rtos total1 2 2) “m”));——->total에서 total1 변경함
      (setq txt (strcat txt ” : 객체수 ” (rtos (length linelist) 2 +0) ” 개”))
      (princ txt)
(if (not (setq tth (getreal (strcat “n현재 TextSize : <” (rtos(getvar “textsize”) 2 1) “> 입니다. 원하는 Text 크기를 입력하세요 : “))))
    (setq tth (getvar “textsize”))
    (setvar “textsize” tth)
      (setq pt (getpoint “n 텍스트 삽입점 : “))
      (if pt (command “text” pt “” “” txt))
만약 선들이 1.51, 1.2, 1.541, 1.57, 1.99, 1, 1.51 있다고 가정하고
예를들어 이런식으로 있으면 1.51*2개 이런식으로 나오는데
저런식 말고 1.51, 1.51 이런식으로 나눠지게 하려면 어떤식으로 해야하나요?
  • 81 조회
    2. JunGuri Lv.0
      2021-11-21T14:51:34+09:00답변 등록 답변 등록 일시 2021-11-21 2:51 pm
      lambda (-) 이 부분 만 다른거 같은데 그 외에는 다른 점은 모르겠지만
      리습을 로드하면
      성공적으로 로드되었습니다.
      명령: ; 오류: 입력에서 잘못된 리스트 이렇게 뜨는군요 ㅠㅠ
    3. JunGuri Lv.0
      2021-11-30T22:51:57+09:00답변 등록 답변 등록 일시 2021-11-30 10:51 pm
      네.. 그대로 했고 추후 글과 비교하면서 썼는데도 똑같더라구요
    4. JunGuri Lv.0
      2021-12-02T11:15:20+09:00답변 등록 답변 등록 일시 2021-12-02 11:15 am
      집에서는 되네요..
      회사컴퓨터는 오류가 뜨더군요 집에서라도 해야죠 감사합니다.
