홈/ 질문/Q 30523
등록일: 2002-04-292002-04-29T20:56:42+09:00 2002-04-29T20:56:42+09:00카테고리: AutoCAD & CADian
simplex hsg 글꼴있는 분
simplex hsg
  • 30 조회
    2. 캐드중수
      2002-04-29T22:48:24+09:00답변 등록 답변 등록 일시 2002-04-29 10:48 pm
      그래두 없으면 다시 올리세요…^^
      찾아서 올려드릴께요..
    3. egb
      2002-04-29T22:59:53+09:00답변 등록 답변 등록 일시 2002-04-29 10:59 pm
      AutoCAD menu utilities loaded.
      Command: z ZOOM
      Specify corner of window, enter a scale factor (nX or nXP), or
      [All/Center/Dynamic/Extents/Previous/Scale/Window] <real time>:
      Specify opposite corner:
      Command: list
      Select objects: 1 found
      Select objects: TEXT Layer: “WALL”
      Space: Model space
      Color: 20 Linetype: “BYLAYER”
      Handle = 68B
      Style = “STANDARD”
      Font file = SIMPLEX HSG
      start point, X= 16.7 Y= 71.6 Z= 0.0
      height 0.2
      text 7.00
      rotation angle 0
      width scale factor 1.0
      obliquing angle 0
      generation normal
      _______________ font file:simplex hsg 이 폰트 찾으면 글 나옵니까??
    4. 캐드중수
      2002-04-30T01:55:50+09:00답변 등록 답변 등록 일시 2002-04-30 1:55 am
      텅…..텅
