홈/ 질문/Q 189575
등록일: 2024-04-012024-04-01T23:00:29+09:00 2024-04-01T23:00:29+09:00카테고리: AutoCAD & CADian
TADD 리습의 면적을 변경하고 싶어요
TADD의 내용 중 면적 구하는 방식을 MM 리습의 면적 구하는 방식으로 변경하고 싶습니다.
직접 수정을 하려고 하니 쉽지 않네요..
TADD 시작———————–
TotalADD Total Addition v. 1.0 ;;
By: Andrea Andreetti 2009-10-20 ;;
(princ
“nTotalADDition v.1.0 activated! -run “TADD” to start or “TADD-r” to end.”
(defun c:tadd (/ itemarea itemperimeter itemlinelength
itemarclength itemsplinelength itemregionperimeter itemcircumference
itemsplineperimeter itemplineperimeter itemplinelength itemtracelength
itemarclength itemellipselength a b c d p1 p2 itemlength tarea tperim tlength
(vl-load-com)
(defun *oo_object_modification* (objreactor objectsmodified)
(setq selected_objects (vla-get-pickfirstselectionset
(vla-get-activedocument (vlax-get-acad-object))
(setq itemarea 0
itemperimeter 0
itemlinelength 0
itemarclength 0
itemsplinelength 0
itemregionperimeter 0
itemcircumference 0
itemsplineperimeter 0
itemplineperimeter 0
itemplinelength 0
itemtracelength 0
itemarclength 0
itemellipselength 0
;AREA
(vlax-for n selected_objects
(if (vlax-property-available-p n ‘area)
(if (eq (vla-get-objectname n) “AcDbRegion”)
(setq itemarea (+ itemarea (vla-get-area n)))
(if (vlax-curve-isclosed n)
;;CIRCLE
(if (vlax-property-available-p n ‘circumference)
(setq itemcircumference (+ itemcircumference (vla-get-circumference n)))
;;SPLINE
(if (eq (vla-get-objectname n) “AcDbSpline”)
(setq itemsplineperimeter (+ itemsplineperimeter
(vlax-curve-getdistatparam n (vlax-curve-getendparam n))
(setq itemsplinelength (+ itemsplinelength
;;REGION
(setq itemregionperimeter (+ itemregionperimeter (vla-get-perimeter n)))
;;PLINE
(if (or (eq (vla-get-objectname n) “AcDb2dPolyline”)
(eq (vla-get-objectname n) “AcDbPolyline”)
(setq itemplineperimeter (+ itemplineperimeter
(setq itemplinelength (+ itemplinelength
;;LINE
(if (eq (vla-get-objectname n) “AcDbLine”)
(setq itemlinelength (+ itemlinelength (vla-get-length n)))
;;ARC
(if (eq (vla-get-objectname n) “AcDbArc”)
(setq itemarclength (+ itemarclength (vla-get-arclength n)))
(if (eq (vla-get-objectname n) “AcDbEllipse”)
(setq itemellipselength (+ itemellipselength
;;TRACE
(if (eq (vla-get-objectname n) “AcDbTrace”)
(progn (setq plist (vlax-safearray->list
(vlax-variant-value (vla-get-coordinates n))
(setq a (list (nth 0 plist) (nth 1 plist) (nth 2 plist)))
(setq b (list (nth 3 plist) (nth 4 plist) (nth 5 plist)))
(setq c (list (nth 6 plist) (nth 7 plist) (nth 8 plist)))
(setq d (list (nth 9 plist) (nth 10 plist) (nth 11 plist)))
(setq p1 (polar a (angle a b) (/ (distance a b) 2.0)))
(setq p2 (polar c (angle c d) (/ (distance c d) 2.0)))
(setq itemtracelength (+ itemtracelength (distance p1 p2)))
;;_end vlax-for
(setq itemperimeter (+ itemcircumference
itemsplineperimeter
itemregionperimeter
itemplineperimeter
(setq itemlength (+ itemplinelength itemsplinelength itemlinelength itemtracelength itemarclength itemellipselength)
(setq tarea (rtos itemarea 2 8))
(setq tperim (rtos itemperimeter 2 8))
(setq tlength (rtos itemlength 2 8))
(acet-ui-status (strcat “Toatl Area: ” tarea “n” “Total Perimeter: ” tperim “n”
“Total Length: ” tlength)
;;OBJECT SELECTION
(if oo_object_modification
(progn (vlr-remove oo_object_modification)
(setq oo_object_modification nil)
(vlr-miscellaneous-reactor
nil
‘((:vlr-pickfirstmodified . *oo_object_modification*))
;;Command ended
(if oo_object_modification_action
(progn (vlr-remove oo_object_modification_action)
(setq oo_object_modification_action nil)
(vlr-command-reactor nil
‘((:vlr-commandended . *oo_object_modification*)
;(:vlr-commandcancelled . *oo_object_modification_CANCEL*))
(defun c:TADD-r ()
TADD 끝———————–
MM 시작———————–
; 인터넷 이곳저곳…. 말씀해주세요… ;
; 저작권 문제가 된다면 수정하겠습니다. http://szpl.tistory.com/ ;
; Zebra Pattern Lemon ;
; 레이어 제어 리습 명령어 참조 : http://szpl.tistory.com/11 ;
(defun c:mm ( / doc space ss index obj mi mx minpt maxpt inspt area txtobj )
(setvar “cmdecho” 0)
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(cond
((= (vla-get-activespace doc) 1) (setq space (vla-get-modelspace doc)))
((= (vla-get-activespace doc) 0) (setq space (vla-get-paperspace doc)))
(if (setq ss (ssget (list (cons 0 “CIRCLE,ARC,*POLYLINE,LINE,ELLIPSE,SPLINE”))))
(if (or (setq ts (getreal (strcat “n텍스트 높이 입력 :”))) (setq ts (getvar “textsize”)))
(progn
(setvar “textsize” ts)
(setq index 0)
(repeat (sslength ss)
(setq obj (vlax-ename->vla-object (ssname ss index)))
(vla-getboundingbox obj ‘mi ‘mx)
(setq minpt (vlax-safearray->list mi) maxpt (vlax-safearray->list mx))
(setq inspt (polar minpt (angle minpt maxpt) (/ (distance minpt maxpt) 2)))
(setq inspt (list (car inspt) (+ (cadr inspt) (* ts 2))))
(setq area (vla-get-area obj) len (vlax-curve-getdistatparam obj (vlax-curve-getendparam obj)))
(mapcar ‘(lambda (a b)
(setq p (vlax-3d-point inspt))
(setq txtobj (vla-addtext space (strcat a b) p ts))
(vla-put-alignment txtobj 4)
(vla-put-textalignmentpoint txtobj p)
(setq inspt (polar inspt (/ (* 270 pi) 180) (* ts 2)))
‘(“평 : ” “면적(㎡) : ” “길이(mm) : ” ) (list (rtos (/ area 3305796.) 2 2) (rtos (/ area 1000000.) 2 3) (rtos len 2 2))
(setq index (1+ index))
(command “chprop” (ssget “x” ‘((0 . “TEXT”) (1 . “평*”))) “” “c” “7” “”)
(vl-load-com)
(prompt “n[ AAA ]”)
MM 끝———————–
MM의 리습으론 면적이 잘 나오는데 TADD 리습은 면적을 되는건 되고 안되는건 안되네요ㅜㅜ
  • 395 조회
