홈/ 질문/Q 161831
등록일: 2005-10-072005-10-07T19:11:59+09:00 2005-10-07T19:11:59+09:00카테고리: Inventor & Solidworks
vault 4.0 에러 해결 방법을 알고 싶습니다.
어디를 수정해야 하는지 궁금 합니다.
“vault 서비스팩 2” 설치후 이 증상ㅣ 나왔습니다.
  • 24 조회
      2005-10-09T14:33:43+09:00답변 등록 답변 등록 일시 2005-10-09 2:33 pm
      출처: Autodesk Vault 뉴스그룹 > Why do I have an “incompatible database” on a new install?
      다음은 Autodesk MSD의 Product Manager인 Brian Roepke의 답변입니다.
      From the help file they mention to check a few things – even if you
      don’t think they are there you might want to check those install
      directories or see if MSDE is already installed… You never know (plus,
      I haven’t ever seen this warning when it wasn’t supposed to be there)
      Checks for an existing database instance named AUTODESKVAULT. There are
      three possible failure conditions for this check:
      1. The installer found a Vault database that is incompatible with the
        current release. The installer cannot upgrade this database to the new
        release.
      2. The installer found an existing vault file store and database files in
        the installation locations. This may happen if you have uninstalled the
        Autodesk Data Management framework and have also uninstalled the
        MSSQL$AUTODESKVAULT database instance, resulting in vault data that is
        no longer associated with the MSDE database.
      3. The installer found an MSDE/Microsoft SQL Server database instance named
        AUTODESKVAULT, but the database does not contain Vault data.
      For condition 1
      Use the Autodesk Vault Manager that was installed with the existing
      vault system to back up your vault.
      Install a newer version of Autodesk Vault that supports migrating the
      data from the existing version.
      Use the Autodesk Vault Manager that was installed with the newer version
      to back up the vault again.
      Uninstall the newer vault client but not the database.
      Start this installation again.
      For condition 2
      Back up and then remove the files from the following locations:
      [install drive]Program FilesMicrosoft SQL ServerMSSQL$AUTODESKVAULT
      [windows drive]Documents and SettingsAll UsersApplication
      DataAutodeskVaultServerFileStore
      Note: Windows hides these directories by default. Enable "Show Hidden
      Files and Folders" in Windows Explorer if you have trouble locating
      these files.
      For condition 3
      Uninstall the existing MSSQL$AUTODESKVAULT SQL Server instance.
