홈/ 질문/Q 113170
등록일: 2021-06-232021-06-23T12:47:26+09:00 2021-06-23T12:47:26+09:00카테고리: AutoCAD & CADian
다중지시선 색상 변경 문의의건.
해당 LISP을 사용하면 다중지시선 TEXT,화살표 색상이 빨간색으로 나오는데 혹시 파랑색으로 바꾸게 할 수 있을까요?
LSIP 고수님들 조언 부탁드립니다.
어디 부분에서 바꿔야 할지 모르겠네요
(vl-load-com)
(defun makeLayer (newlayername newlayerColor)
(entmake
(list
(cons 0 “LAYER”)
(cons 100 “AcDbSymbolTableRecord”)
                                    (cons 100 “AcDbLayerTableRecord”)
                                    (cons 2  newlayername) ;layer name
                                    (cons 70 0)
(cons 62 newlayerColor) ;layer color
(defun maketextstyle (newstylename)
(entmake
(list
(cons 0 “style”)
(cons 100 “AcDbTextStyleTableRecord”)
(cons 2 newstylename) ;style name
(cons 3 “arial.ttf”) ;font
;(cons 4 “whgtxt.shx”) ;bigfont
(cons 70 0)
(cons 40 0) ;fixed height / 0=non
(cons 41 1) ;width factor
(cons 50 0) ;oblique angle
(cons 71 0) ;2=mirrored in X / 4=mirrored in Y
(defun searchmleaderstyle (mleaderstylename / mleaderstyledict searchresult)
(if
(setq mleaderstyledict (dictsearch (namedobjdict) “acad_mleaderstyle”))
(foreach x mleaderstyledict
(if
(and
(= (car x) 3)
(eq (strcase (cdr x)) (strcase mleaderstylename))
(setq searchresult t)
searchresult
(defun makemleaderstyle (newmleadername newmleadertextstyle)
(setq mleaderstyles (vla-item (vla-get-Dictionaries (vla-get-ActiveDocument (vlax-get-acad-object))) “ACAD_MLEADERSTYLE”))
(setq newmleaderstyle (vla-AddObject mleaderstyles newmleadername “AcDbMLeaderStyle”))
(vla-put-TextStyle newmleaderstyle newmleadertextstyle)
(vla-put-TextAngleType newmleaderstyle “1”)
(vla-put-ArrowSize newmleaderstyle “6000”)
(vla-put-DoglegLength newmleaderstyle “6000”)
(vla-put-TextHeight newmleaderstyle “6000”)
(vla-put-TextLeftAttachmentType newmleaderstyle “3”)
(vla-put-TextRightAttachmentType newmleaderstyle “3”)
 (defun c:refcheck_knw_test()
(if
(= (tblsearch “style” “xycoordinates”) nil)
(maketextstyle “xycoordinates”)
(setq oldlayer (getvar “clayer”))
(if
(= (tblsearch “layer” “xycoordinates”) nil)
(progn
(makelayer “xycoordinates” 1)
(setvar “clayer” “xycoordinates”)
(setq oldcmleaderstyle (getvar “cmleaderstyle”))
(if
(= (searchmleaderstyle “xycoordinates”) nil)
(progn
(makemleaderstyle “xycoordinates” “xycoordinates”)
(setvar “cmleaderstyle” “xycoordinates”)
   (command “undo” “begin”)
   (setq lup(getvar “luprec”))
   (setvar “luprec” 4)
   (setq zin(getvar “dimzin”))
   (setvar “dimzin” 0)
   (setvar “cmdecho” 0)
   (setq chip (getpoint “Enter chip size W/ SL (um) n”))
   (setq pointx (getpoint “pick on good die x coordinaten”))
   (setq pointy (getpoint “pick on good die y coordinaten”))
   (setq num (getint “Enter the number of ref diesn”))
   (princ “[Coordinates will show up once at a time]n”)
   (repeat num
   (setq ref1 (getpoint “Pick on the left corner of ref dien”))
   (setq ref1x (/ (- (car pointx) (car ref1)) (car chip)))
   (setq ref1y (/ (- (cadr pointy) (cadr ref1)) (cadr chip)))
   (princ “n–n”)
   (princ (abs ref1x))
   (princ “n”)
   (princ (abs ref1y))
   (princ “n–n”)
   (setq xp (strcat “X:” (rtos (abs ref1x) 2 0)))
   (setq yp (strcat “Y:” (rtos (abs ref1y) 2 0)))
   (setq allcoordinate (strcat xp ” ” yp))
   (command “mleader” ref1 pause allcoordinate )
    (setvar “clayer” oldlayer)
    (setvar “cmleaderstyle” oldcmleaderstyle)
  • 134 조회
    • 도구막대 이동시 미리보기가 안됩니다.
      2021-06-23T13:41:46+09:00답변 등록 답변 등록 일시 2021-06-23 1:41 pm
      이 리습은 xycoordinates라는 이름의 도면층을 만들고, 그 도면층으로 지시선을 작성하기 때문에
      도면층의 색을 바꾸면 됩니다.
      이 내용에서 숫자 1이 색상 번호예요.
      https://blog.naver.com/trusted_dwg/221205713908
      2021-06-23T14:02:27+09:00답변 등록 답변 등록 일시 2021-06-23 2:02 pm
      빠른 답변 감사드립니다!
