리습 고수님들 도와주세요~ㅠ.ㅠ
리습 초보입니다.. 아래 리습실행중..구하는점을 클릭하게 되면 다중지시선이 직각방향위로만 출력이 되는데…
첫번째 구하는점을 클릭후 두번째 클릭을 어느 위치나 방향으로 해도 다중지시선이 표시 될수 있도록 수정부탁드리겠습니다.(ps.좌표구하는 리습 처럼 지시선을 어느방향으로나 자유롭게 표시하고 싶네요)
(defun draw_txt()
(setvar “osmode” 0)
(setq txt_len (strlen (rtos next_elev 2 2)))
(setq txt (strcat “EL:” (rtos next_elev 2 2)))
(setq drw1_len (* text_size 4))
(setq drw2_len (* text_size 5))
(setq drw1_point (polar pick (* pi 0.5) drw1_len))
(setq drw2_point (polar drw1_point (* pi 2) drw2_len))
(setq txt_point (polar drw1_point (* pi 0.25) (/ text_size 3)))
(setq arrow (polar pick (* pi 0.5) text_size))
(setq arrow1 (polar arrow (* pi 2) (* text_size 0.25)))
(setq arrow2 (polar arrow (* pi 1) (* text_size 0.25)))
(command “pline” pick drw1_point drw2_point “”)
(command “solid” pick arrow1 arrow2 “” “”)
(command “text” txt_point text_size “” txt)
(defun run_FH()
(setq base_y (cadr pick))
(setvar “osmode” old_osm)
(setq pick (getpoint “nPick Next point :”))
(while pick
(setq next_y (cadr pick))
(cond
((> base_y next_y)
(setq ch_y (- base_y next_y))
(setq next_elev (- base_elev ch_y))
(draw_txt)
(setq base_elev next_elev)
((< base_y next_y)
(setq ch_y (- next_y base_y))
(setq next_elev (+ base_elev ch_y))
(draw_txt)
((= base_y next_y)
(setq next_elev base_elev)
(draw_txt)
(defun c:FH(/ base_elev ch_y drw1_point drw2_point base_y next_y)
(setvar “cmdecho” 1)
(setq old_osm (getvar “osmode”))
(setq height (getvar “textsize”))
(setq msg (strcat “Text size <” (rtos height 2 1) “> : “))
(princ “n”) (princ msg)
(setq text_size (getreal))
(if text_size
(setvar “textsize” text_size)
(setq text_size height)
(setq pick (getpoint “nPick Base point : “))
(if pick
(progn
(setq base_elev (car (entsel “nSelect Base elevation Text : “)))
(if base_elev
(progn
(setq base_elev (atof (cdr (assoc 1 (entget base_elev)))))
(run_FH))))))
부탁드립니다. .
개인적으로 변수선언 없는 리습 NO~! ㅡ.ㅡ;;;
수야님 감사합니다~^^
