홈/ 질문/Q 107395
등록일: 2016-10-192016-10-19T09:24:21+09:00 2016-10-19T09:24:21+09:00카테고리: AutoCAD & CADian
리습 오류 해결좀 부탁드려요 ㅠ
이런 리습인데요
ct를 입력하면
CTABLESTYLE에 대한 새 값 입력 <“Standard”>
이라는 말만 뜨고 글자변경이 되지 않네요 ㅠㅠ
이게 두줄문자도 수정이 되고
그런 리습인데 왜 안될까요
도움좀 부탁드립니다 ㅠㅠ
; Next available MSG number is   83
; MODULE_ID CHTEXT_LSP_
; $Header: /sedona/develop/support/chtext.lsp 8     4/29/97 5:35p Derrl $
;;;    CHTEXT.lsp – change text
;;;    Copyright 1997 by Autodesk, Inc.
;;;    Permission to use, copy, modify, and distribute this software
;;;    for any purpose and without fee is hereby granted, provided
;;;    that the above copyright notice appears in all copies and
;;;    that both that copyright notice and the limited warranty and
;;;    restricted rights notice below appear in all supporting
;;;    documentation.
;;;    AUTODESK PROVIDES THIS PROGRAM “AS IS” AND WITH ALL FAULTS.
;;;    AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
;;;    MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE.  AUTODESK, INC.
;;;    DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
;;;    UNINTERRUPTED OR ERROR FREE.
;;;    Use, duplication, or disclosure by the U.S. Government is subject to
;;;    restrictions set forth in FAR 52.227-19 (Commercial Computer
;;;    Software – Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
;;;    (Rights in Technical Data and Computer Software), as applicable.
;;; DESCRIPTION
;;;   This is a “text processor” which operates in a global manner
;;;   on all of the text entities that the user selects; i.e., the
;;;   Height, Justification, Location, Rotation, Style, Text, and
;;;   Width can all be changed globally or individually, and the
;;;   range of values for a given parameter can be listed.
;;;   The command is called with CHT from the command line at which
;;;   time the user is asked to select the objects to change.
;;;     Select text to change.
;;;     Select objects:
;;;   If nothing is selected the message “ERROR: Nothing selected.”
;;;   is displayed and the command is terminated.  If more than 25
;;;   entities are selected the following message is displayed while
;;;   the text entities are sorted out from the non-text entities.
;;;   A count of the text entities found is then displayed.
;;;     Verifying the selected entities…
;;;     nnn  text entities found.
;;;     CHText:  Height/Justification/Location/Rotation/Style/Text/Undo/Width:
;;;   A typical example of the prompts you may encounter follows:
;;;   If you select a single text entity to change and ask to change
;;;   the height, the prompt looks like this:
;;;     New text height for text entity. <0.08750000>:
;;;   If you select more than one text entity to change and ask to change
;;;     Individual/List/<New height for all entities>:
;;;   Typing “L” at this prompt returns a prompt showing you the range of
;;;   values that you are using for your text.
;;;     Height — Min: 0.05000000  Max: 0.10000000  Ave: 0.08392857
;;;   Typing “I” at this prompt puts you in a loop, processing the text
;;;   entities you have selected one at a time, and giving the same prompt
;;;   you get for a single text entity shown above.
;;;   Pressing ENTER at this point puts you back at the Command: prompt.
;;;   Selecting any of the other options allows you to change the text
;;;   entities selected.
(defun cht_Main ( / sset opt ssl nsset temp unctr ct_ver sslen style hgt rot
                    txt ent loc loc1 just-idx justp justq orthom
                    cht_ErrorHandler cht_OrgError cht_OrgCmdecho
                    cht_OrgTexteval cht_OrgHighlight)
  ;; Reset if changed
  (setq ct_ver “2.00”)
  ;; Internal error handler defined locally
  (defun cht_ErrorHandler (s)
    (if (/= s “Function cancelled”)
      (if (= s “quit / exit abort”)
        (princ (strcat “nError: ” s))
    (eval (read U:E))
    ;;  Reset original error handler if there
    (if cht_OrgError (setq *error* cht_OrgError))
    (if temp (redraw temp 1))
    (ai_undo_off) ;; restore undo state
    (if cht_OrgCmdecho (setvar “cmdecho” cht_OrgCmdecho))
    (if cht_OrgTexteval (setvar “texteval” cht_OrgTexteval))
    (if cht_OrgHighlight (setvar “highlight” cht_OrgHighlight))
  ;; Set error handler
  (if *error*
    (setq cht_OrgError *error*
          *error* cht_ErrorHandler)
    (setq *error* cht_ErrorHandler)
  ;; Set undo groups and ends with (eval(read U:G)) or (eval(read U:E))
  (setq U:G “(command ”_.undo” ”_group”)”
        U:E “(command ”_.undo” ”_en”)”
  (ai_undo_on)       ;; enable undo
  (setq cht_OrgCmdecho (getvar “cmdecho”))
  (setq cht_OrgHighlight (getvar “highlight”))
  (setvar “cmdecho” 0)
  (princ (strcat “nChange text, Version “
                 ct_ver
                 “, Copyright ?1997 by Autodesk, Inc.”))
  (prompt “nSelect annotation objects to change.”)
  (setq sset (ai_aselect))
  (if (null sset)
    (progn
      (princ “nNo objects selected.”)
      (exit)
  ;; Validate selection set
  (setq ssl   (sslength sset)
        nsset (ssadd))
  (if (> ssl 25)
    (princ “nVerifying selected objects…”)
  (while (> ssl 0)
    (setq temp (ssname sset (setq ssl (1- ssl))))
    (if (or
          (= (cdr (assoc 0 (entget temp))) “TEXT”)
          (= (cdr (assoc 0 (entget temp))) “ATTDEF”)
          (= (cdr (assoc 0 (entget temp))) “MTEXT”)
      (ssadd temp nsset)
  (setq ssl (sslength nsset)
        sset nsset
        unctr 0
  (print ssl)
  (princ “annotation objects found.”)
  ;; Main loop
  (setq opt T)
  (while (and opt (> ssl 0))
    (setq unctr (1+ unctr))
    (command “_.UNDO” “_GROUP”)
    (initget “Location Justification Style Height Rotation Width Text Undo”)
;;;    (setq opt (getkword
;;;        “nHeight/Justification/Location/Rotation/Style/Text/Undo/Width: “))
;;;    (if opt
;;;      (cond
;;;        ((= opt “Undo”)
;;;          (cht_Undo)
;;;        ((= opt “Location”)
;;;          (cht_Location)
;;;        ((= opt “Justification”)
;;;          (cht_Justification)
;;;        ((= opt “Style”)
;;;          (cht_Property “Style”    “New style name”      7) )
;;;        ((= opt “Height”)
;;;          (cht_Property “Height”   “New height”         40) )
;;;        ((= opt “Rotation”)
;;;          (cht_Property “Rotation” “New rotation angle” 50) )
;;;        ((= opt “Width”)
;;;          (cht_Property “Width”    “New width factor”   41) )
;;;        ((= opt “Text”)
;;;          (cht_Text)
;;;      (setq opt nil)
    (cht_Text)
    (setq opt nil)
    (command “_.UNDO” “_END”)
  ;; Restore
  (eval (read U:E))
;;; Undo an entry
(defun cht_Undo ()
  (if (> unctr 1)
    (progn
      (command “_.UNDO” “2”)
      (setq unctr (- unctr 2))
    (progn
      (princ “nNothing to undo. “)
      (setq unctr (- unctr 1))
;;; Change the location of an entry
(defun cht_Location ()
  (setq sslen (sslength sset)
        style “”
        hgt   “”
        rot   “”
        txt   “”
  (command “_.CHANGE” sset “” “”)
  (while (> sslen 0)
    (setq ent (entget(ssname sset (setq sslen (1- sslen))))
          opt (list (cadr (assoc 11 ent))
                    (caddr (assoc 11 ent))
                    (cadddr (assoc 11 ent)))
    (prompt “nNew text location: “)
    (command pause)
    (if (null loc)
      (setq loc opt)
    (command style hgt rot txt)
  (command)
;;; Change the justification of an entry
(defun cht_Justification ()
  (initget “TL TC TR ML MC MR BL BC BR Align Center Fit Left Middle Right ?”)
  (setq sslen (sslength sset))
  (setq justp (getkword “nAlign/Fit/Center/Left/Middle/Right/TL/TC/TR/ML/MC/MR/BL/BC/BR/<?>: “))
  (cond
    ((= justp “Left”)    (setq justp 0 justq 0 just-idx 4) )
    ((= justp “Center”)  (setq justp 1 justq 0 just-idx 5) )
    ((= justp “Right”)   (setq justp 2 justq 0 just-idx 6) )
    ((= justp “Align”)   (setq justp 3 justq 0 just-idx 1) )
    ((= justp “Fit”)     (setq justp 5 justq 0 just-idx 1) )
    ((= justp “TL”)      (setq justp 0 justq 3 just-idx 1) )
    ((= justp “TC”)      (setq justp 1 justq 3 just-idx 2) )
    ((= justp “TR”)      (setq justp 2 justq 3 just-idx 3) )
    ((= justp “ML”)      (setq justp 0 justq 2 just-idx 4) )
    ((= justp “Middle”)  (setq justp 4 justq 0 just-idx 5) )
    ((= justp “MC”)      (setq justp 1 justq 2 just-idx 5) )
    ((= justp “MR”)      (setq justp 2 justq 2 just-idx 6) )
    ((= justp “BL”)      (setq justp 0 justq 1 just-idx 7) )
    ((= justp “BC”)      (setq justp 1 justq 1 just-idx 8) )
    ((= justp “BR”)      (setq justp 2 justq 1 just-idx 9) )
    ((= justp “?”)       (setq justp nil)       )
    (T                   (setq justp nil)       )
  (if justp
    (progn ;; Process them…
      (while (> sslen 0)
        (setq ent (entget (ssname sset (setq sslen (1- sslen)))))
        (cond
          ((= (cdr (assoc 0 ent)) “MTEXT”)
            (setq ent (subst (cons 71 just-idx) (assoc 71 ent) ent))
          ((= (cdr (assoc 0 ent)) “TEXT”)
            (setq ent (subst (cons 72 justp) (assoc 72 ent) ent)
                  opt (trans (list (cadr (assoc 11 ent))
                             (cdr (assoc -1 ent)) ;; from ECS
                             1)               ;; to current UCS
            (setq ent (subst (cons 73 justq) (assoc 73 ent) ent))
            (cond
              ((or (= justp 3) (= justp 5))
                (prompt “nNew text alignment points: “)
                (if (= (setq orthom (getvar “orthomode”)) 1)
                  (setvar “orthomode” 0)
                (redraw (cdr (assoc -1 ent)) 3)
                (initget 1)
                (setq loc (getpoint))
                (initget 1)
                (setq loc1 (getpoint loc))
                (redraw (cdr (assoc -1 ent)) 1)
                (setvar “orthomode” orthom)
                (setq ent (subst (cons 10 loc) (assoc 10 ent) ent))
                (setq ent (subst (cons 11 loc1) (assoc 11 ent) ent))
              ((or (/= justp 0) (/= justq 0))
                (setq loc (getpoint opt))
                (if (null loc)
                  (setq loc opt)
                  (setq loc (trans loc 1 (cdr (assoc -1 ent))))
                (setq ent (subst (cons 11 loc) (assoc 11 ent) ent))
        (entmod ent)
    (progn ;; otherwise list options
      (textpage)
      (princ “nAlignment options:n”)
      (princ “t  TL     TC      TRn”)
      (princ “t  ML     MC      MRn”)
      (princ “t  BL     BC      BRn”)
      (princ “t Left   Center  Rightn”)
      (princ “tAlign   Middle  Fitn”)
      (princ “nPress ENTER to continue: “)
      (grread)
      (princ “r                                                            “)
      (graphscr)
  (command)
;;; Change the text of an object
(defun cht_Text ( / ans)
;;;  (initget “Globally Individually Retype”)
;;;  (setq ans (getkword
;;;    “nFind and replace text.  Individually/Retype/<Globally>:”))
  (setq cht_OrgTexteval (getvar “texteval”))
  (setvar “texteval” 1)
;;;  (cond
;;;    ((= ans “Individually”)
;;;      (progn
;;;       (initget “Yes No”)
;;;        (setq ans (getkword “nEdit text in dialog? <Yes>:”))
;;;      (while (> sslen 0)
;;;        (redraw (setq sn (ssname sset (setq sslen (1- sslen)))) 3)
;;;        (setq ss (ssadd))
;;;        (ssadd (ssname sset sslen) ss)
;;;        (if (= ans “No”)
;;;          (cht_Edit ss)
;;;          (command “_.DDEDIT” sn “”)
;;;        (redraw sn 1)
;;;    ((= ans “Retype”)
;;;        (setq ent (entget (ssname sset (setq sslen (1- sslen)))))
;;;        (redraw (cdr (assoc -1 ent)) 3)
;;;        (prompt (strcat “nOld text: ” (cdr (assoc 1 ent))))
;;;        (setq nt (getstring  T “nNew text: “))
;;;        (redraw (cdr (assoc -1 ent)) 1)
;;;        (if (> (strlen nt) 0)
;;;          (entmod (subst (cons 1 nt) (assoc 1 ent) ent))
;;;    (T
;;;      (cht_Edit sset)   ;; Change all
  (cht_Edit sset)
;;; The old CHGTEXT command – rudimentary text editor
(defun C:CHGTEXT () (cht_Edit nil))
(defun cht_Edit (objs / last_o tot_o ent o_str n_str st s_temp
                       n_slen o_slen si chf chm cont ans class)
  ;; Select objects if running standalone
  (if (null objs)
    (setq objs (ssget))
  (setq chm 0)
  (if objs
    (progn                   ;; If any objects selected
      (if (= (type objs) ‘ENAME)
        (progn
          (setq ent (entget objs))
          (princ (strcat “nExisting string: ” (cdr (assoc 1 ent))))
        (if (= (sslength objs) 1)
          (progn
            (setq ent (entget (ssname objs 0)))
      (setq o_str (getstring “nMatch string   : ” t))
      (setq o_slen (strlen o_str))
      (if (/= o_slen 0)
        (progn
          (setq n_str (getstring “nNew string     : ” t))
          (setq n_slen (strlen n_str))
          (setq last_o 0
                tot_o  (if (= (type objs) ‘ENAME)
                         1
                         (sslength objs)
          ;; For each selected object…
          (while (< last_o tot_o)
            (setq class (cdr (assoc 0 (setq ent (entget (ssname objs last_o))))))
            (if (or (= “TEXT” class)
                    (= “MTEXT” class) )
              (progn
                (setq chf nil si 1)
                (setq s_temp (cdr (assoc 1 ent)))
                (while (= o_slen (strlen (setq st (substr s_temp si o_slen))))
                  (if (= st o_str)
                    (progn
                      (setq s_temp (strcat
                                     (if (> si 1)
                                       (substr s_temp 1 (1- si))
                                     n_str
                                     (substr s_temp (+ si o_slen))
                      (setq chf t)    ;; Found old string
                      (setq si (+ si n_slen))
                    (setq si (1+ si))
                (if chf
                  (progn              ;; Substitute new string for old
                    ;; Modify the TEXT entity
                    (entmod (subst (cons 1 s_temp) (assoc 1 ent) ent))
                    (setq chm (1+ chm))
            (setq last_o (1+ last_o))
        ;; else go on to the next line…
  (if (/= (type objs) ‘ENAME)
    ;; Print total lines changed
    (if (/= (sslength objs) 1)
      (princ (strcat (rtos chm 2 0) ” text lines changed.”))
  (terpri)
;;; Main procedure for manipulating text entities
(defun cht_Property (typ prmpt fld / temp ow nw ent tw sty w hw lw
                              sslen n sn ssl)
  (if (= (sslength sset) 1)           ;; Special case if there is only
                                      ;; one entity selected
    ;; Process one entity.
    (cht_ProcessOne)
    ;; Else
    (progn
      ;; Set prompt string.
      (cht_SetPrompt)
      (if (= nw “List”)
        ;; Process List request.
        (cht_ProcessList)
        (if (= nw “Individual”)
          ;; Process Individual request.
          (cht_ProcessIndividual)
          (if (= nw “Select”)
            ;; Process Select request.
            (cht_ProcessSelect)
            ;; Else
            (progn
              (if (= typ “Rotation”)
                (setq nw (* (/ nw 180.0) pi))
              (if (= (type nw) ‘STR)
                (if (not (tblsearch “style” nw))
                  (progn
                    (princ (strcat nw “: Style not found. “))
                  (cht_ProcessAll)
                (cht_ProcessAll)
;;; Change all of the entities in the selection set
(defun cht_ProcessAll (/ hl temp)
  (setq hl (getvar “highlight”))
  (setvar “highlight” 0)
  (while (> sslen 0)
    (setq temp (ssname sset (setq sslen (1- sslen))))
    (entmod (subst (cons fld nw)
                   (assoc fld (setq ent (entget temp)))
                   ent ) )
  (setvar “highlight” hl)
;;; Change one text entity
(defun cht_ProcessOne ()
  (setq temp (ssname sset 0))
  (setq ow (cdr (assoc fld (entget temp))))
  (if (= opt “Rotation”)
    (setq ow (/ (* ow 180.0) pi))
  (redraw (cdr (assoc -1 (entget temp))) 3)
  (initget 0)
  (if (= opt “Style”)
    (setq nw (getstring (strcat prmpt ” <” ow “>: “)))
    (setq nw (getreal (strcat prmpt ” <” (rtos ow 2) “>: “)))
  (if (or (= nw “”) (= nw nil))
    (setq nw ow)
  (redraw (cdr (assoc -1 (entget temp))) 1)
  (if (= opt “Style”)
    (if (null (tblsearch “style” nw))
                     ent
                   ent
;;; Set the prompt string
(defun cht_SetPrompt ()
  (if (= typ “Style”)
    (progn
      (initget “Individual List New Select “)
      (setq nw (getkword (strcat “nIndividual/List/Select style/<“
                                 prmpt
                                 ” for all text objects” “>: “)))
      (if (or (= nw “”) (= nw nil) (= nw “Enter”))
                                    ” for all text objects” “: “)))
    (progn
      (initget “List Individual” 1)
      (setq nw (getreal (strcat “nIndividual/List/<“
                                 prmpt
;;; Process List request
(defun cht_ProcessList ()
  (setq unctr (1- unctr))
  (setq tw 0)
  (while (> sslen 0)
    (if (= typ “Style”)
      (progn
        (if (= tw 0)
          (setq tw (list (cdr (assoc fld (entget temp)))))
          (progn
            (setq sty (cdr (assoc fld (entget temp))))
            (if (not (member sty tw))
              (setq tw (append tw (list sty)))
      (progn
        (setq tw (+ tw (setq w (cdr (assoc fld (entget temp))))))
        (if (= (sslength sset) (1+ sslen)) (setq lw w hw w))
        (if (< hw w) (setq hw w))
        (if (> lw w) (setq lw w))
    (setq tw (* (/ tw pi) 180.0)
          lw (* (/ lw pi) 180.0)
          hw (* (/ hw pi) 180.0))
  (if (= typ “Style”)
    (progn
      (princ (strcat “n” typ “(s) — “))
      (princ tw)
             ” — Min: ” (rtos lw 2)
             “t Max: ” (rtos hw 2)
             “t Avg: ” (rtos (/ tw (sslength sset)) 2) ) )
;;; Process Individual request
(defun cht_ProcessIndividual ()
  (while (> sslen 0)
    (initget 0)
    (if (= typ “Style”)
      (progn
        (setq nw (getstring (strcat “n” prmpt ” <” ow “>: “)))
      (progn
        (setq nw (getreal (strcat “n” prmpt ” <” (rtos ow 2) “>: “)))
      (setq nw ow)
                   ent
;;; Process the Select option
(defun cht_ProcessSelect ()
  (princ “nSearch for which Style name?  <*>: “)
  (setq sn  (xstrcase (getstring))
        n   -1
        nsset (ssadd)
        ssl (1- (sslength sset))
  (if (or (= sn “*”) (null sn) (= sn “”))
    (setq nsset sset sn “*”)
    (while (and sn (< n ssl))
      (setq temp (ssname sset (setq n (1+ n))))
      (if (= (cdr (assoc 7 (entget temp))) sn)
        (ssadd temp nsset)
  (princ (strcat “nStyle: ” sn))
  (print (setq ssl (sslength nsset)))
  (princ “objects found.”)
;;; Check to see if AI_UTILS is loaded, If not, try to find it,
;;; and then try to load it.  If it can’t be found or can’t be
;;; loaded, then abort the loading of this file immediately.
(cond
  ((and ai_dcl (listp ai_dcl))) ; it’s already loaded.
  ((not (findfile “ai_utils.lsp”)) ; find it
    (ai_abort “CHT” nil)
  ((eq “failed” (load “ai_utils” “failed”)) ; load it
;;; If we get this far, then AI_UTILS.LSP is loaded and it can
;;; be assumed that all functions defined therein are available.
;;; Next, check to see if ACADAPP.EXP has been xloaded, and abort
;;; if the file can’t be found or xloaded.  Note that AI_ACADAPP
;;; does not abort the running application itself (so that it can
;;; also be called from within the command without also stopping
;;; an AutoCAD command currently in progress).
(if (not (ai_acadapp)) (ai_abort “CHT” nil))
;;; The C: function definition
(defun c:ct () (cht_Main))
(princ “ntCT command loaded.”)
  • 108 조회
    • cadplus_plot 사용방법 질문드립니다
      2016-10-19T09:52:22+09:00답변 등록 답변 등록 일시 2016-10-19 9:52 am
      아 CT라는 중복명령어가 있었네요 중복 명령어 지웠는데
      명령: (LOAD “C:/Users/archias/Desktop/lisp/ct(글자수정).lsp”) ; 오류: no function
      definition: AI_ABORT
      이런 오류가 다시 뜨는데 왜그런지 아시나요 ㅠㅠ
      2016-10-19T12:44:09+09:00답변 등록 답변 등록 일시 2016-10-19 12:44 pm
      ai_utils.lsp 파일은 없는데 있어야 실행이 되는건가요?
