홈/ 질문/Q 109442
등록일: 2018-02-102018-02-10T20:19:42+09:00 2018-02-10T20:19:42+09:00카테고리: AutoCAD & CADian
리습 이름변경 했는데 무슨리습인지 도통 모르겠네요..
;;;    Copyright (C) 2002 by Autodesk, Inc.
;;;    Permission to use, copy, modify, and distribute this software
;;;    for any purpose and without fee is hereby granted, provided
;;;    that the above copyright notice appears in all copies and
;;;    that both that copyright notice and the limited warranty and
;;;    restricted rights notice below appear in all supporting
;;;    documentation.
;;;    AUTODESK PROVIDES THIS PROGRAM “AS IS” AND WITH ALL FAULTS.
;;;    AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
;;;    MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE.  AUTODESK, INC.
;;;    DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
;;;    UNINTERRUPTED OR ERROR FREE.
;;;    Use, duplication, or disclosure by the U.S. Government is subject to
;;;    restrictions set forth in FAR 52.227-19 (Commercial Computer
;;;    Software – Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
;;;    (Rights in Technical Data and Computer Software), as applicable.
;;; DESCRIPTION:
;;;  Sample profile manipulation utilities. All functions return T on success and nil
;;  on failure. See comments above each function for additional details.
;;; EXAMPLES:
;;; – Set active profile:
;;;     (sample-profile-set-active “MyProfile”)
;;; – Import a profile:
;;;     (sample-profile-import “c:\myExportedProfile.arg” “MyFavoriteProfile” T)
;;; – Delete a profile:
;;;     (sample-profile-delete “unwanted”)
;;; – Import a profile, even if it already exists, and set it active.
;;;    (sample-profile-import “c:\CompanyProfile.arg” “MyProfile” T)
;;; – Import a profile, if not already present, and set it active
;;;    (if (not (sample-profile-exists “myProfile”))
;;;        (progn
;;; – Import a profile and set it active when AutoCAD is first started.
;;;  Place the following code in acaddoc.lsp with the desired “.arg” filename
;;;  and profile name…
;;;    (defun s::startup ()
;;;      (if (not (vl-bb-ref ‘:sample-imported-profile)) ;; have we imported the profile yet?
;;;          (progn
;;;            ;; Set a variable on the bulletin-board to indicate that we’ve been here before.
;;;            (vl-bb-set ‘:sample-imported-profile T)
;;;            ;; Import the profile and set it active
;;;          );progn then
;;;      );if
;;;    );defun s::startup
;; This helper function gets the profiles object.
(defun sample-get-profiles-object ( / app pref profs )
 (vl-load-com)
 (and
  (setq   app (vlax-get-acad-object))
  (setq  pref (vla-get-preferences app))
  (setq profs (vla-get-profiles pref))
 profs
);defun sample-get-profiles-object
;; Determine if a profile exists. Returns T if the specified profile name exists, and nil if not.
(defun sample-profile-exists ( name / profs )
 (and name
      (setq names (sample-profile-names))
      (member (strcase name) (mapcar ‘strcase names))
);defun sample-profile-exists
;; Set the active profile.
;; NOTES:
;;  – If the specified profile name is already active then the function returns T and makes no additional
;;    changes.
;;  – The specified profile must exist. (You can import a profile using the  ‘sample-profile-import’
;;    function.) If the specified profile does not exist, the function returns nil.
(defun sample-profile-set-Active ( name / profs )
 (and
  name
  (setq profs (sample-get-profiles-object))
  (or (equal (strcase name) (strcase (getvar “cprofile”)))
      (not (vl-catch-all-error-p (vl-catch-all-apply ‘vla-put-activeProfile (list profs name))))
 );and
);defun sample-profile-set-Active
;; Delete the specified profile. Fails if the specified profile is current.
(defun sample-profile-delete ( name / profs )
 (and
  name
  (not (vl-catch-all-error-p (vl-catch-all-apply ‘vla-deleteprofile (list profs name))))
);defun sample-profile-delete
;; Copy profile.
(defun acad-pref-profile-copy ( source target / profs )
 (and
  source
  target
  (not (vl-catch-all-error-p (vl-catch-all-apply ‘vla-CopyProfile (list profs source target))))
);defun sample-profile-copy
;; Get a list of profile names
(defun sample-profile-names ( / profs result )
 (and
  (not (vl-catch-all-error-p (vl-catch-all-apply ‘vla-GetAllProfileNames (list profs ‘result))))
  result
  (setq result (vlax-safearray->list result))
 result
);defun sample-profile-names
;; Rename
(defun sample-profile-rename ( oldName newName / profs )
 (and
  oldName
  newName
  (not (vl-catch-all-error-p (vl-catch-all-apply ‘vla-RenameProfile (list profs oldName newName))))
);defun sample-profile-rename
;; Get a unique profile name. This function returns a unique profile name that is guaranteed
;; to not be present in the current list of profiles.
(defun sample-get-unique-profile-name ( / names n name )
       names (mapcar ‘strcase names)
        name “TempProfileName”
           n 1
 (while (member (strcase (setq name (strcat name (itoa n)))) names)
  (setq n (+ n 1))
 name
);defun sample-get-unique-profile-name
;; Import
;; This function imports the specified .arg file and creates a new profile with the provided profile name.
;; If the specified profile already exists, it will be overwritten.
;; If the ‘bUsePathInfo’ parameter is non-nil then path information will be imported from the specified
;; file. Otherwise, path information will be ignored.
;; NOTES:
;;  This function does not set the active profile. If you import a new profile
;;  it will not become active unless it matches the name of the existing active profile.
;;  You can set the active profile by calling:
;;    (sample-profile-set-active “ProfileName”)
(defun sample-profile-import ( filename profileName bUsePathInfo / sample-oldError profs isCProfile tempProfile result )
 ;; Set up an error handler so, if something goes wrong, we can put things back the way we found them
 (setq sample-oldError *error*)
 (defun *error* ( msg / )
  (if (and profileName
           tempProfile
           (equal tempProfile (getvar “cprofile”))
      (progn
       ;; Something went wrong so put things back the way they were.
       (sample-profile-rename tempProfile profileName)
       (sample-profile-set-active profileName)
       (sample-profile-delete tempProfile)
      );progn then
  );if
  (setq *error* sample-oldError)
  (if msg
      (*error* msg)
 );defun *error*
 (if (and bUsePathInfo
          (not (equal :vlax-false bUsePathInfo))
     (setq bUsePathInfo :vlax-true)
     (setq bUsePathInfo :vlax-false)
 (if (and filename
          (setq filename (findfile filename))
          profileName
     );and
     (progn
      ;; We can’t import directly to the current profile, so if the provided profile name matches
      ;; the current profile, we’ll need to:
      ;;  – rename the current profile to a unique name
      ;;  – import
      ;;  – set the new one current
      ;;  – delete the old one with the temp name
      (setq isCProfile (equal (strcase (getvar “cprofile”)) (strcase profileName)))
      (if isCProfile
          (progn
           (setq tempProfile (sample-get-unique-profile-name))
           (sample-profile-rename (getvar “cprofile”) tempProfile)
          );progn then
      );if
      ;; Import
      (setq result (not (vl-catch-all-error-p (vl-catch-all-apply ‘vla-ImportProfile (list profs profileName filename bUsePathInfo)))))
      (if isCProfile
          (progn
           ;;  Handle current profile case…
           ;;  If the import was successful, then set the new profile active and delete the original
           ;;  else if something went wrong, then put the old profile back
           (if (and result
                    (setq result (sample-profile-set-Active profileName)) ;; set the newly imported profile active
               );and
               (sample-profile-delete tempProfile)            ;; then delete the old profile
               (sample-profile-rename tempProfile profileName);; else rename the original profile back to its old name
           );if
          );progn then
      );if
     );progn then
 );if
 (*error* nil) ;; quietly restore the original error handler
 result
);defun sample-profile-import
  • 29 조회
