홈/ 질문/Q 21254
등록일: 2002-09-032002-09-03T11:25:28+09:00 2002-09-03T11:25:28+09:00카테고리: AutoCAD & CADian
리습명령실행후 “Unknown command “DSET”. Press F1 for help.” 없애는 법 좀..
여기저기 책찾아보구 아래같이 리습을 작성해서 실행하면
실행은 되는데 자꾸 “Unknown command “DSET”. Press F1 for help.” 문구가
뜨네요 어디를 잘못한건지 초보라서 잘모르겠슴다.^^;;;
없앨려면 어떻게하는지 좀 알려주세요
(defun C:dset()
(princ “nDraw Setting Start”)
(setvar “cmdecho” 0)
(setvar “blipmode” 0)
(setvar “osmode” 191)
(command “-layer” “m” “1” “c” “1” “” “l” “cl” “” “”)
(command “-layer” “m” “2” “c” “2” “” “”)
(command “-layer” “m” “3” “c” “3” “” “”)
(command “-layer” “m” “4” “c” “4” “” “”)
(command “-layer” “m” “5” “c” “5” “” “”)
(command “-layer” “m” “6” “c” “6” “” “”)
(command “-layer” “m” “7” “c” “7” “” “”)
(command “-layer” “m” “8” “c” “8” “” “”)
(command “-layer” “m” “9” “c” “9” “” “”)
(command “-layer” “m” “10” “c” “11” “” “”)
(command “-layer” “m” “11” “c” “85” “” “”)
(command “-layer” “m” “12” “c” “83” “” “”)
(command “-layer” “m” “13” “c” “3” “” “”)
(command “-layer” “m” “14” “c” “6” “” “”)
(command “-layer” “m” “15” “c” “30” “” “”)
(command “-layer” “s” “1” “”)
(command “-style” “nt” “romans.shx,ghs.shx” “” “” “” “” “” “”)
(command “-style” “bt” “hywb.ttf” “” “” “” “” “”)
(command “ucsicon” “n”)
(command “mirrtext” “0”)
(command “fillet” “r” “0”)
  • 37 조회
    • cadplus_plot 사용방법 질문드립니다
    • 캐드 좌표값을 위경도값으로 산출 가능할까요?
