홈/ 질문/Q 99119
등록일: 2013-08-202013-08-20T08:48:56+09:00 2013-08-20T08:48:56+09:00카테고리: AutoCAD & CADian
리습수정 부탁드릴께요 ^^ (필렛값이 적용이 잘 안되요)
제가 사용하는 필렛값은 100인데..
어떤도면에서는 잘 적용이 되고, 어떤 도면에서는 필렛 100이 적용이 안되요
너무작게 표현이 되는 도면이 있는데, 이유가 무엇일까요?
어떤도면에서든지 실행시키면 무조건 필렛 100이 적용되도록 수정 부탁드립니다. ^^
; VV – ㄱ자 자동배선
(defun c:VV (/ radd L:1 L:22 L1 L2 L3 dist dist11 dist22 dist1)
   (setq old_osmode (getvar “osmode”)) ; 에러처리 루틴
   (setq old_layer (getvar “clayer”)) ; 에러처리 루틴
  (setq temp_osnap (getvar “osmode”))
  (setq la (getvar “clayer”))
  (setvar “cmdecho” 0)
  (setvar “blipmode” 0)
  (command “color” “bylayer”)
  (prompt “n *** ㄱ자 ㄴ자 자동배선…↗(┌)↖(┐)↘(└)↙(┘)… “)
  (setq radd (getvar “filletrad”))
  (setq radd (fix radd))
  (if (= han_round_size nil) (setq han_round_size 1000))
  (setq L:1 han_round_size)
  (setq old_osnap (getvar “osmode”))
  (command “osnap” “QUA,MID”)
  (setq L1 (getpoint “n Pick First line point : “))
  (setq L2 (getcorner L1 “n Pick Second point : “))
  (setvar “osmode” old_osnap)
  (setq L3 (list (car L1) (cadr L2)))
  (setq dist11 (distance L3 L1))
  (setq dist22 (distance L2 L3))
  (if (< dist11 dist22)
    (setq dist dist11)
    (setq dist dist22)
  (if (< dist L:1)
    (setq L:1 (* 3 (/ dist 4)))
  (if (or (= (car L1) (car L2)) (= (cadr L1) (cadr L2)))
    (command “line” L1 L2 “”)
    (progn
      (command “pline” L1 “w” “0” “” L3 L2 “”)
      (command “fillet” “r” L:1)
      (command “fillet” “p” “L”)
      (setvar “filletrad” radd)
  (command “layer” “s” la “”)
  (setvar “osmode” temp_osnap)
    (setvar “osmode” old_osmode) ; 에러처리 루틴
; BB – ㄷ자 자동배선
(defun c:BB (/ dist1)
  (prompt “n *** ㄷ자 자동 배선… “)
  (command “osnap” “none”)
  (setq L2 (getpoint L1 “n Distance line point : “))
  (setq L4 (getpoint “n Pick Last point : “))
  (if (/= (cadr L1) (cadr L2))
    (setq L3 (list (car L4) (cadr L2)))
    (setq L3 (list (car L2) (cadr L4)))
  (setq dist1 (distance L1 L2))
  (setq dist2 (distance L3 L4))
  (if (< dist1 dist2)
    (setq kk dist1)
    (setq kk dist2)
  (if (< kk L:1)
    (setq L:1 (* 3 (/ kk 4)))
  (command “pline” L1 “w” “0” “” L2 L3 L4 “”)
  (prin1)
  • 98 조회
