홈/ 질문/Q 112084
등록일: 2020-01-092020-01-09T11:41:04+09:00 2020-01-09T11:41:04+09:00카테고리: AutoCAD & CADian
면적및길이 구하는 리습 aaa
(defun c:aaa ( / doc space ss index obj mi mx minpt maxpt inspt area txtobj)
  (setq doc (vla-get-activedocument (vlax-get-acad-object)))
  (cond
    ((= (vla-get-activespace doc) 1) (setq space (vla-get-modelspace doc)))
    ((= (vla-get-activespace doc) 0) (setq space (vla-get-paperspace doc)))
  (if (and (setq ss (car (entsel “n객체 선택 : “))) (setq inspt (getpoint “n텍스트 삽입점 지정 : “)))
    (progn
      (setq obj (vlax-ename->vla-object ss))
      (setq area (vla-get-area obj) len (vlax-curve-getdistatparam obj (vlax-curve-getendparam obj)))
      (mapcar ‘(lambda (a b)
   (setq p (vlax-3d-point inspt))
   (setq txtobj (vla-addtext space (strcat a b) p 1000))
   (vla-put-alignment txtobj 10)
   (vla-put-textalignmentpoint txtobj p)
   (setq inspt (polar inspt (/ (* 270 pi) 180) 1000))
       (list (rtos (/ area 1000000.) 2 2) (rtos (/ len 1000.) 2 2)) ‘(“m2” “m”)
(vl-load-com)
(prompt “n[ AAA ]”)
면적(m2)과 길이(m) 줄 간격을 500 띄우고 싶어요  어떻게 수정해야 하나요 도와주세요
예) 123.22 m2
      123.22 m
  • 232 조회
