홈/ 질문/Q 106784
등록일: 2016-06-172016-06-17T09:14:16+09:00 2016-06-17T09:14:16+09:00카테고리: AutoCAD & CADian
브레이크 리습 수정부탁드립니다
이리습은 간격을 줘서 브레이크 해주는 리습입니다
처음에  첫번째 LENGTHEN 명령어로  10 미리 값을 입력하여
연장시키고 아래리습으로 10미리 선에 브레이크 합니디 이걸 하나에 리습으로 만들수 없을까해서요 고수님 부탁드립니다
혹시.. 폴리선도 가능하면 폴리선도 부탁드리겠습니다
(defun c:BAD (/ *error* AT:GetSel AT:DrawX _getDist ent pnt cmd undo total add dist break)
  ;; Break curve At Distance
  ;; Alan J. Thompson, 09.21.11
  (vl-load-com)
  (defun *error* (msg)
    (and cmd (setvar ‘CMDECHO cmd))
    (and *AcadDoc* (vla-endundomark *AcadDoc*))
    (if (and msg (not (wcmatch (strcase msg) “*BREAK*,*CANCEL*,*QUIT*,”)))
      (princ (strcat “nError: ” msg))
  (defun AT:GetSel (meth msg fnc / ent)
    ;; meth – selection method (entsel, nentsel, nentselp)
    ;; msg – message to display (nil for default)
    ;; fnc – optional function to apply to selected object
    ;; Ex: (AT:GetSel entsel “nSelect arc: ” (lambda (x) (eq (cdr (assoc 0 (entget (car x)))) “ARC”)))
    ;; Alan J. Thompson, 05.25.10
    (setvar ‘ERRNO 0)
    (while
      (progn (setq ent (meth (cond (msg)
                                   (“nSelect object: “)
             (cond ((eq (getvar ‘ERRNO) 7) (princ “nMissed, try again.”))
                   ((eq (type (car ent)) ‘ENAME)
                    (if (and fnc (not (fnc ent)))
                      (princ “nInvalid object!”)
    ent
  (defun AT:DrawX (P C)
    ;; Draw and “X” vector at specified point
    ;; P – Placement point for “X”
    ;; C – Color of “X” (must be integer b/w 1 & 255)
    ;; Alan J. Thompson, 10.31.09
    (if (vl-consp P)
      ((lambda (d)
         (grvecs (cons C
                       (mapcar (function (lambda (n) (polar P (* n pi) d)))
                               ‘(0.25 1.25 0.75 1.75)
         P
        (* (getvar ‘viewsize) 0.02)
  (defun _getDist (total point / dist)
    (and undo (initget “Undo”))
    (cond ((not (setq dist (getdist (AT:DrawX point 4)
                                    (strcat
                                      “nDistance at which to break curve (Total= “
                                      (rtos total)
                                      (if undo
                                        “) [Undo]: “
           nil
          ((eq dist “Undo”) dist)
          ((not (< 0. dist total))
           (princ (strcat “nValue must be between 0.0 and and ” (rtos total) “!”))
           (_getDist total point)
          (dist)
  (vla-startundomark
    (cond (*AcadDoc*)
          ((setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object))))
  (if (setq ent (AT:GetSel
                  entsel
                  “nSelect curve to break: “
                  (lambda (x)
                    (and (wcmatch (cdr (assoc 0 (entget (car x))))
                                  “ARC,LINE,*POLYLINE,SPLINE”
                         (not (vlax-curve-isClosed (car x)))
    (progn
      (setq pnt (trans (cadr ent) 1 0)
            ent (car ent)
            cmd (getvar ‘CMDECHO)
      (setvar ‘CMDECHO 0)
      (while
        (setq
          dist (_getDist (setq total (vlax-curve-getDistAtParam ent (vlax-curve-getEndParam ent)))
                         (setq pnt
                                (trans (if (> (vlax-curve-getParamAtPoint
                                                ent
                                                (vlax-curve-getClosestPointToProjection ent pnt ‘(0. 0. 1.))
                                              (vlax-curve-getParamAtDist ent (/ total 2.))
                                         (progn (setq add total) (vlax-curve-getEndPoint ent))
                                         (progn (setq add 0.) (vlax-curve-getStartPoint ent))
                                       0
                                       1
         (if (eq dist “Undo”)
           (progn (vl-cmdf “_.U”)
                  (setq ent  (caar undo)
                        pnt  (cadar undo)
                        undo (cdr undo)
           (progn
             (setq break (trans (vlax-curve-getPointAtDist ent (abs (- add dist))) 0 1))
             (vl-cmdf “_.break” ent “_F” “_non” break “_non” break)
             (setq undo (cons (list ent pnt) undo))
             (and (zerop add) (setq ent (entlast)))
         (redraw)
         (foreach p (vl-remove (last undo) undo) (AT:DrawX (cadr p) 1))
  (*error* nil)
  • 19 조회
    • 도구막대 이동시 미리보기가 안됩니다.
