블록이름 변경 리습 내용인데요.
전에 잘 되다가 갑자기 안되기 시작했는데 무슨 문제인지 알수가 없네요 ㅠㅠ
(defun c:bt(/ obn nbn ss ky1)
   (prompt “…블록이름 변경하기”)
   (setq obn nil nbn nil ss nil)
   (setq ss (ssget “:s” ‘((0 . “insert”))))
   (if ss (setq obn (cdr (assoc 2 (entget (ssname ss 0)))))
          (setq obn “지정된 블록이 없음…다시지정하세요”))
   (setq dcl_id (load_dialog “bt.dcl”))
   (setq ky1 3)
(while (= ky1 3)
   (if (not (new_dialog “bn_chg” dcl_id)) (exit))
   (set_tile “text_old” obn)
   (if (= nbn nil) (set_tile “text_new” obn)(set_tile “text_new” nbn))
   (mode_tile “text_new” 2)
   (action_tile “text_old” “(setq obn $value)”)
   (action_tile “text_new” “(setq nbn $value)”)
(action_tile “butt1” “(setq ky1 3)(done_dialog)”)
   (action_tile “butt2” “(@butt2)”)
   (action_tile “accept” “(setq ky1 33)(done_dialog)”)
   (action_tile “cancel” “(setq ky1 4)(done_dialog)”)
   (start_dialog)
   (cond
      ((= ky1 3)
         (if ss (progn
            (setq nbn obn))
      ((= ky1 33)
         (if (or (tblsearch “block” nbn) (= nbn ” “))
         (setq ky1 3) (setq ky1 9))
   (if (and (= (tblsearch “block” obn) nil)(/= ky1 4))
      (setq ky1 3 obn “지정된 블록이 없음…다시지정하세요”))
);while end
   (unload_dialog dcl_id)
   (if (= ky1 9) (progn
      (command “rename” “b” obn nbn)
      (prompt “n블록이름변경:”) (prin1 obn)(prompt “->”) (prin1 nbn)
(prin1))
;subroutine
(defun @butt2()
   (if (or (tblsearch “block” nbn) (= nbn ” “)) (progn
      (set_tile “text_new” obn)(mode_tile “text_new” 2)
캐드 2015에는 command 함수를 command-s로 수정해야 한다고 하네요.
