홈/ 질문/Q 106688
등록일: 2016-05-302016-05-30T14:12:23+09:00 2016-05-30T14:12:23+09:00카테고리: AutoCAD & CADian
블록안의 블록 이름바꾸는 리습 질문요
CB명령어를 쳐서 블록안에 블록을 치면 원본블록은 그대로 있고 그위에 겹쳐서 다른블록이 생성되는데 원본블록이 지워지게끔 가능하게 고수님 수정좀 해주세요
(defun c:cb nil (LM:RenameBlockReference   t))
(defun c:rb nil (LM:RenameBlockReference nil))
(defun LM:RenameBlockReference ( cpy / *error* abc app dbc dbx def doc dxf new old prp src tmp vrs )
    (defun *error* ( msg )
        (if (and (= ‘vla-object (type dbx)) (not (vlax-object-released-p dbx)))
            (vlax-release-object dbx)
        (if (not (wcmatch (strcase msg t) “*break,*cancel*,*exit*”))
            (princ (strcat “nError: ” msg))
    (while
        (progn
            (setvar ‘errno 0)
            (setq src (car (entsel (strcat “nSelect block reference to ” (if cpy “copy & ” “”) “rename: “))))
            (cond
                (   (= 7 (getvar ‘errno))
                    (princ “nMissed, try again.”)
                (   (= ‘ename (type src))
                    (setq dxf (entget src))
                    (cond
                        (   (/= “INSERT” (cdr (assoc 0 dxf)))
                            (princ “nPlease select a block reference.”)
                        (   (= 4 (logand 4 (cdr (assoc 70 (tblsearch “layer” (cdr (assoc 8 dxf)))))))
                            (princ “nSelected block is on a locked layer.”)
    (if (= ‘ename (type src))
        (progn
            (setq app (vlax-get-acad-object)
                  doc (vla-get-activedocument app)
                  src (vlax-ename->vla-object src)
                  old (vlax-get-property src (if (vlax-property-available-p src ‘effectivename) ‘effectivename ‘name))
                  tmp 0
            (while (tblsearch “block” (setq def (strcat (vl-string-left-trim “*” old) “_” (itoa (setq tmp (1+ tmp)))))))
            (while
                (and (/= “” (setq new (getstring t (strcat “nSpecify new block name <” def “>: “))))
                    (or (not (snvalid new))
                        (tblsearch “block” new)
                (princ “nBlock name invalid or already exists.”)
            (if (= “” new)
                (setq new def)
            (setq dbx
                (vl-catch-all-apply ‘vla-getinterfaceobject
                    (list app
                        (if (< (setq vrs (atoi (getvar ‘acadver))) 16)
                            “objectdbx.axdbdocument”
                            (strcat “objectdbx.axdbdocument.” (itoa vrs))
            (if (or (null dbx) (vl-catch-all-error-p dbx))
                (princ “nUnable to interface with ObjectDBX.”)
                (progn
                    (setq abc (vla-get-blocks doc)
                          dbc (vla-get-blocks dbx)
                    (vlax-invoke doc ‘copyobjects (list (vla-item abc old)) dbc)
                    (if (wcmatch old “`**”)
                        (vla-put-name (vla-item dbc (1- (vla-get-count dbc))) new)
                        (vla-put-name (vla-item dbc old) new)
                    (vlax-invoke dbx ‘copyobjects (list (vla-item dbc new)) abc)
                    (if cpy (setq src (vla-copy src)))
                    (if
                        (and
                            (vlax-property-available-p src ‘isdynamicblock)
                            (= :vlax-true (vla-get-isdynamicblock src))
                        (progn
                            (setq prp (mapcar ‘vla-get-value (vlax-invoke src ‘getdynamicblockproperties)))
                            (vla-put-name src new)
                            (mapcar
                               ‘(lambda ( a b )
                                    (if (/= “ORIGIN” (strcase (vla-get-propertyname a)))
                                        (vla-put-value a b)
                                (vlax-invoke src ‘getdynamicblockproperties) prp
                    (if (= :vlax-true (vla-get-isxref (setq def (vla-item (vla-get-blocks doc) new))))
                        (vla-reload def)
                    (if cpy (sssetfirst nil (ssadd (vlax-vla-object->ename src))))
;;                             End of File                              ;;
  • 5 5 답변
  • 62 조회
    • 도구막대 이동시 미리보기가 안됩니다.
    5 답변
      2016-05-30T14:29:41+09:00답변 등록 답변 등록 일시 2016-05-30 2:29 pm
      (and (/= “” (setq new (rtos (getvar ‘cdate) 2 8)))  이렇게 바꾸심?
      2016-05-30T14:57:41+09:00답변 등록 답변 등록 일시 2016-05-30 2:57 pm
      뭐하남님 너무 고맙습니다^^ 염치없지만 하나만 더 물어봐도 되겠습니까
      CB명령어로 쳐서 ** (블록안에 블록을)** 치면 원본블록은 그대로 있고 그위에 겹쳐서 다른블록이 생성되는데 원본블록이 지워지게끔 가능하게 고수님 수정좀 해주세요 유일하게 이리습이 블록안에 불록이름을 바꿀수 있더라구요 근데 블록안에 블록이름이 바꿔면서 기존에 있던 원본은 블록이 있더라구요 즉 겹쳐지는데 가능할수 있는지요 부탁좀 드리겠습니다 이런 종루에 블록도면이 너무 많아서 공수가 많이 들어가네요
      2016-05-30T16:25:56+09:00답변 등록 답변 등록 일시 2016-05-30 4:25 pm
      RB명령을 치면 되잖아요!
      2016-05-30T18:05:18+09:00답변 등록 답변 등록 일시 2016-05-30 6:05 pm
      머하남님 죄송합니다 직원들이 설명을 잘못해서 1번을 클릭하면 1번2번 동일 블록이름이 같기 때문에
      3번처럼 뜹니다 여기서 3번에 M12 이름을 RB나CB로  클릭해서 바꾸면 1번2번 블록이름이 같이 따라 옵니다
      즉 M12 만 개별적으로 바꿀수 없는지요  참고로 1번 2번 3번은 같은 이름입니다 즉 서브 블록만 바꿀수 없는가 해서요.
      파일 참조해서 봐주세요. 부탁드립니다.
      2016-05-30T18:33:38+09:00답변 등록 답변 등록 일시 2016-05-30 6:33 pm
      뭔가 착각하신 것 같은데요. 블록 속 블록이 다를 수가 있나요? 같은 이름의 블록인데 안에 내용물(속성문자가 아닌)이 다를 수가 있나요? abc(블록) 안에 123(블록), abc(블록) 안에 가나다(블록)가 가능한가요?
