홈/ 질문/Q 93127
등록일: 2011-10-082011-10-08T15:07:41+09:00 2011-10-08T15:07:41+09:00카테고리: AutoCAD & CADian
소숫점 2자리로 조정하려면?
소숫점 3자리로 결과값이 나오는데… 소숫점 2자리로 조정하려면 어디 수정해야 하죠?
;*    ADDTEXT
;*              ADD to TEXT
;*              By Suk-Jong Yi
;*              99/6/8
(defun C:hh(
 / ans ss1 num index cnum entl ass ass1 newtext co entl1
  (defun SETERR(s)                          ;내장에러루틴 정의
    (if (/= s “Function cancelled”)
        (princ (strcat “nError: ” s))
    ); of If
    (setq *error* oer seterr nil)
  ); of SETERR
;  (setq oer *error* *error* seterr)         ;내장에러루틴 가동
   (initget “All Select”)
   (setq ans (getkword “nAll/<Select>: “))
   (cond
       ((or (= ans nil) (= ans “Select”))
           (princ “nSelect text: “)
           (setq ss1 (ssget     ‘((-4 .   “<OR”)
                                  ( 0 .  “TEXT”)
                                  ( 0 . “MTEXT”)
                                  (-4 .   “OR>”)))) ; All text
       ) ;of ans=nil
       ((= ans “All”)
           (setq ss1 (ssget “X” ‘((-4 . “<OR”)
                                  (0 . “TEXT”)
                                  (0 . “MTEXT”)
       ) ;of ans=All
   ); of cond
   (setq num (sslength ss1))                        ;선택된 text갯수 출력
   (princ num)
   (princ ” found”)
   (setq addval (getreal “nEnter Add value: “))    ;더해질 값 지정
   (setq index 0)
   (setq cnum 0)
   (repeat num                                      ;text갯수만큼 반복
       (setq entl (entget (ssname ss1 index)))
       (setq index (1+ index))
       (setq ass (assoc 0 entl))
       (if (or (= “TEXT” (cdr ass)) (= “MTEXT” (cdr ass)))
         (progn
           (setq ass1 (assoc 1 entl))         ;text내용
           (if (is-num (cdr ass1))
             (progn
               (setq newtext (rtos (+ addval (atof (cdr ass1))) 2 3))
               (setq co (cons (car ass1) newtext))
               (setq entl1 (subst co ass1 entl))
               (entmod entl1)                       ;새로운 크기로 업데이트
               (setq cnum (1+ cnum))
             );progn
           );if
         ) ;of progn
       ) ;of if
   ) ;of repeat
   (terpri)
   (princ cnum)
   (princ ” Modified”)
;  (setq *error* oer seterr nil)
) ;of defun
; Function : IS-NUM
;            IS NUMber ?
;            By Suk-Jong Yi
;            1996/2/23
; 문자열이 숫자인가?를 판단해준다.
(defun IS-NUM(str
/ str strl count ch )
  (setq strl (strlen str))
  (setq count 1)
  (while (or (and (>= (setq ch (ascii (substr str count 1))) 48)
                  (<= ch 57))
             (= ch 44)
             (= ch 46)
             (and (= count 1) (= ch 43))
             (and (= count 1) (= ch 45))
    (setq count (+ count 1))
  ) ;of while
  (if (= count (+ strl 1)) strl NIL)
) ;of defun
  • 20 조회
