홈/ 질문/Q 112806
블루진
블루진Lv.0
등록일: 2021-01-162021-01-16T16:52:35+09:00 2021-01-16T16:52:35+09:00카테고리: AutoCAD & CADian
아이소 치수 리습 수정 부탁합니다
치수선과 보조선,문자색상을 바꾸고 싶은데 부탁 드립니다
(defun dtr (a)
 (* pi (/ a 180.0))
(defun rtd (a)
 (/ (* a 180.0) pi)
(defun c:dm(/ pt1 pt2 pt3 pt4 pt5 pt6 pt7 pt8 pt9 pt10 ang t_ang g_ang l_dist t_dist str)
    (setq txt-h 2.0)
    (setq s (getvar “dimscale”))
    (setq text-type 2)
    (setq orth(getvar “orthomode”))
    (setq os(getvar “osmode”))
    (setvar “osmode” 33)
    (setq sk1 (* 1.0 s))
    (setq cor_sty (getvar “textstyle”))
    (setq pt1 (getpoint “nPick iso dimension start point : “)
          pt2 (getpoint “nPick iso dimension end point : ” pt1)
          pt3 (getpoint “nPick iso dimension line position : ” pt2)
          ang (angle pt1 pt2)        ; dimension line angle
          t_ang (angle pt2 pt3)      ; text style angle
          g_ang (angtos ang)         ; function angle
          l_dist (distance pt1 pt2)  ; dimension line distance
          t_dist (* 15 sk1)          ; dimension line distance
       pt3 (polar pt1 t_ang t_dist)
       pt4 (polar pt2 t_ang t_dist)
       pt5 (polar pt3 ang (/ (distance pt1 pt2) 2))
       pt7 (polar pt3 t_ang (* 1.4 sk1))
       pt8 (polar pt4 t_ang (* 1.4 sk1))
       pt9 (polar pt1 t_ang (* 1.4 sk1))
       pt10(polar pt2 t_ang (* 1.4 sk1))
       str (getstring “nInput text string : “)
    (if (or (and (>= (rtd ang) 61) (<= (rtd ang) 120))
            (and (>= (rtd ang) 241) (<= (rtd ang) 300))
            (setq pt6 (polar pt5 (dtr 210) (* 1.4 sk1)))
            (setq pt6 (polar pt5 (dtr 90) (* 1.4 sk1)))
    (setvar “osmode” 0)
    (command “line” pt9 pt7 “”)
    (command “line” pt3 pt4 “”)
    (command “line” pt10 pt8 “”)
    (daa pt3 ang)
    (daa pt4 (+ ang (dtr 180)))
    (i_t pt6 ang str)
    (setq q_con (strcase (getstring “nDo you want to continue dimension < Yes / No > : “)))
    (if (= q_con “N”)(setq jhg nil)(setq jhg 7))
    (while jhg
        (setq pt1 pt2)
        (setq pt2 (getpoint “nPick iso dimension end point : ” pt1))
        (if (= pt2 nil)
            (setq jhg nil)
            (progn
                (setq pt3 (getpoint “nPick iso dimension line position : ” pt2)
                (setvar “osmode” 0)
                (daa pt3 ang)
                (i_t pt6 ang str)
    (setvar “textstyle” cor_sty)
    (setvar “orthomode” orth)
    (setvar “osmode” os)
    (prin1)
(defun i_t(g_pt g_ang g_str)
    (if (= text-type 2)
        (progn
            (if (not (tblsearch “style” “D1”))
                (progn
                    (command “filedia” “0”)
                    (command “style” “D1” “ROMANS” “” “0.8” “30” “” “” “”)
                    (command “filedia” “1”)
            (if (not (tblsearch “style” “D2”))
                (progn
                    (command “style” “D2” “ROMANS” “” “0.8” “-30” “” “” “”)
 (cond
    ((and (>= (rtd g_ang) 15) (<= (rtd g_ang) 60))
        (if (= text-type 2)
            (if (or (and (>= (rtd t_ang) 61) (<= (rtd t_ang) 120)) (and (>=  (rtd t_ang) 241) (<= (rtd t_ang) 300)))
                (setvar “textstyle” “D1”)
                (setvar “textstyle” “D2”)
             (setvar “textstyle” “ROMANS”)
        (command “text” “c” g_pt (* txt-h s) “30” g_str)
    ((and (>= (rtd g_ang) 61) (<= (rtd g_ang) 120))
        (if (= text-type 2)
            (if (or (and (>= (rtd t_ang) 15) (<= (rtd t_ang) 60)) (and (>= (rtd t_ang) 181) (<= (rtd t_ang) 240)))
         (command “text” “c” g_pt (* txt-h s) “90” g_str)
     ((and (>= (rtd g_ang) 121) (<= (rtd g_ang) 180))
        (if (= text-type 2)
        (command “text” “c” g_pt (* txt-h s) “330” g_str)
     ((and (>= (rtd g_ang) 181) (<= (rtd g_ang) 240))
        (if (= text-type 2)
     ((and (>= (rtd g_ang) 241) (<= (rtd g_ang) 300))
        (if (= text-type 2)
     ((and (>= (rtd g_ang) 301) (<= (rtd g_ang) 360))
        (if (= text-type 2)
(defun daa (g_pt g_ang / pt3 pt4)
 (setq as (* 0.4 s);;arrow hight
       pt21  (polar g_pt g_ang (* 2.5 s));;arrow length
       g_ang (angtos g_ang)
 (setq pt3 (polar pt21 t_ang  as)
       pt4 (polar pt21 (+ t_ang (dtr 180)) as)
 (command “solid” g_pt pt4 pt3 “” “”)
  • 129 조회
