홈/ 질문/Q 110842
조니1
조니1Lv.1
등록일: 2019-01-172019-01-17T18:09:46+09:00 2019-01-17T18:09:46+09:00카테고리: AutoCAD & CADian
양방향 옵셋 수정 해봤는데
(defun c:YY()
    (setq  olderr *ERROR*)
(setq os_m (getvar “osmode”))
(setvar “osmode” 37)
(setvar “cmdecho” 0)
(if (= OFF100 nil) (setq OFF100 0))
(SETQ OFF_100 OFF100)
(SETQ OOABC “”)
(PRINC “N 양쪽 간격의 총 크기 [반지름 (R)] “)
(PRINC “< “) (PRINC OFF_100) (PRINC” > :”)
(setq OOABC (strcase (getstring)))
(setq OFF100 (ATOf OOABC))
(IF (OR (= OOABC “R” ) (= OOABC “r”))
    (PROGN
        (SETQ OO222 (/ OFF_100 2))
        (setq OFF100 (getreal (strcat “n양쪽 간격의 반 지름 <” (rtos OO222) “>:”)))
        (SETQ OFF_100 (* OO222 2))
        (SETQ OFF100 (* OFF100 2))
(IF (OR (= OFF100 NIL) (= OFF100 0))
(SETQ OFF100 OFF_100)
(setq off1(* off100 0.5))
(SETQ a1(SSGET))
(SETQ NUM(SSLENGTH a1))
(SETQ INDEX 0)
(REPEAT NUM(SETQ b1(entget(ssname a1 index)))
    (setq kkke(cdr(assoc 0 b1)))
    (IF(= “LINE” kkke)
         (progn
              (setvar “osmode” 0)
              (setq c1(assoc 10 b1))
              (setq c2(assoc 11 b1))
              (setq d1(cdr c1))
              (setq d2(cdr c2))
              (setq ang(angle d1 d2))
(setq p1(polar d1(+ ang (* 0.5 pi)) off1))
(setq p2(polar d1(- ang (* 0.5 pi)) off1))
(setq p3(polar d2(+ ang (* 0.5 pi)) off1))
(setq p4(polar d2(- ang (* 0.5 pi)) off1))
              (command “line” p1 p3 “”)
              (command “line” p2 p4 “”)
              (setq index(+ index 1))
              (command “osmode” 191)
              (SETQ KIS OFF100)
    (if(= “ARC” kkke)
         (progn
              (setvar “osmode” 0)
              (setq cc1(assoc 10 b1))
              (setq rr1(assoc 40 b1))
              (setq c1(assoc 50 b1))
              (setq c2(assoc 51 b1))
              (setq dd1(cdr cc1))
              (setq r1(cdr rr1))
              (setq d1(cdr c1))
              (setq ang1(rtd d1))
              (setq d2(cdr c2))
              (setq ang2(rtd d2))
              (setq ptt1(+ r1 off1))
              (setq ptt2(- r1 off1))
              (setq kkkk1(strcat “@”(rtos ptt1) “<“(rtos ang1)))
              (setq kkkk2(strcat “@”(rtos ptt1) “<“(rtos ang2)))
              (setq kkkk3(strcat “@”(rtos ptt2) “<“(rtos ang1)))
              (setq kkkk4(strcat “@”(rtos ptt2) “<“(rtos ang2)))
              (command “arc” “c” dd1 kkkk1 kkkk2)
              (command “arc” “c” dd1 kkkk3 kkkk4)
              (command “osnap” “int”)
              (SETQ KIS OFF100)
              (COMMAND “osmode” os_m)
(setq OOABC “”)
       (if (tblsearch “layer” “!JK01”)
            (command “_layer” “S” “!JK01”  “color” “1” “” “”)
        (command “_layer” “make” “!JK01” “lt” “CONTINUOUS” “” “color” “1” “” “”)
        );endif
     (command “-layer” “s” “!JK01” “”)
(command “chprop” ent “” “c” “bylayer” “lt” “bylayer” “la” “!JK01” “”)
(prompt “nSet !JK01 Layer… “)
처음에 선택한 가운데 선을 빨간색으로 바꾸고싶어서 해봤는데
될때가있고 전체도면이 빨간색으로 바뀔때가있네요 뭐가 잘못된걸까요 ㅠ
  • 41 조회
