홈/ 질문/Q 26512
등록일: 2001-09-162001-09-16T14:06:44+09:00 2001-09-16T14:06:44+09:00카테고리: AutoCAD & CADian
치수에 꼬리를 달고 싶소…
나는 캐드 14를 사용하여 건축도면을 작업하고 있는데
딤의 보조치수선에 꼬리를 달아 멋을? 부리고 싶은데
다음의 맹구메뉴의 딤셋업을 설정하여 사용하는데
위로는 꼬랑지가 나오나 좌우는 절대? 안나오므로
고걸 아는분이 있으면 감사하겠습니다….
다음 딤변수중 어느것을 핸드링혀야 할지 아직
발견치 못하여 땀을 흘리고 있습니다….
도와주시면 고맙겠습니다.
끝…..백발노인…..
(defun mgset2 ()
(setvar "cmdecho" 0)
(setvar "ltscale" (* 3 SCL_1))
(command "units" 2 0 1 2 0 "n")
(command "ucsicon" "off")
(command "mirrtext" "0")
(command "color" "bylayer")
(command "pdmode" "3")
(command "pdsize" "-20")
(command "dimadec" "2")
(command "dimalt" "off")
(command "dimaltd" "0")
(command "dimalttd" "0")
(command "dimalttz" "0")
(command "dimaltu" "8") ;;
(command "dimaltz" "8") ;;
(command "dimapost" ".")
(command "dimaso" "on")
(command "dimasz" "1") ;;"1"
(command "dimaunit" "0")
(command "dimblk" "dot")
(command "dimblk1" ".")
(command "dimblk2" ".")
(command "dimcen" "1")
(command "dimclrd" "256")
(command "dimclre" "256")
(command "dimclrt" "256")
(command "dimdec" "0")
(command "dimdle" "2") ;;원 1
(command "dimdli" "8") ;;8
(command "dimexe" "2") ;;원 1
(command "dimexo" "1") ;;1
(command "dimfit" "5")
(command "dimgap" "1") ;;1 조정요
(command "dimjust" "0")
(command "dimlfac" "1")
(command "dimlim" "off")
(command "dimpost" ".")
(command "dimrnd" "0")
(command "dimsah" "on")
(command "dimscale" SCL_1)
(command "dimsd1" "off")
(command "dimsd2" "off")
(command "dimse1" "off")
(command "dimse2" "off")
(command "dimsho" "on")
(command "dimsoxd" "on") ;;off
;; (command "dimstyle" "_s" "mgnew")
(command "dimtad" "1")
(command "dimtdec" "0")
(command "dimtfac" "1")
(command "dimtih" "off")
(command "dimtix" "on")
(command "dimtm" "0")
(command "dimtofl" "on")
(command "dimtoh" "off")
(command "dimtol" "off")
(command "dimtolj" "1")
(command "dimtp" "0")
(command "dimtsz" "0")
(command "dimtvp" "1")
;; (command "dimtxsty" "ktxt")
(command "dimtxsty" "hws")
(command "dimtxt" "3")
(command "dimtzin" "8") ;; 0 8
(command "dimunit" "8") ;; 2 8
(command "dimupt" "off")
(command "dimzin" "8") ;; 0 8
(command "fillet" "r" "0")
(setvar "cmdecho" 1)
(setvar "blipmode" 0)
  • 45 조회
