클라우드 이쁘게 쳐지는 LISP인데, 2022에서 사용 하려 하니 오류가 발생하네요.
뭐가 잘못된건가요??
(defun C:RM (/ stp ssp np nnp true dist ft ea ang arc sp)
(setq olderr *error*
*error* error
(setvar “CMDECHO” 0)
(setq cl (getvar “clayer”))
(setq co (getvar “cecolor”))
(SETQ DDD (GETREAL “nINPUT SCALE :”))
; (SETQ DDD 300)
(COMMAND “LAYER” “m” “CLOUD” “c” “4” “” “”)
(command “color” “bylayer”)
(setq stp (getpoint “n–Point : “))
(setq ssp stp)
(setq np (getpoint stp “n–Point : “))
(command “PLINE” stp “w” “0” “0” “A” “A” “90”)
(setq true t)
(while true
(setq dist (distance stp np)
ft (fix (/ dist DDD))
(if (< ft 1)
(setq ea 1)
(setq ea ft)
(setq ang (angle stp np))
(if (> ea 1)
(progn
(setq arc (/ dist ea))
(setq sp stp)
(repeat ea
(setq nnp (polar sp ang arc))
(command nnp “W” “0” “0” “A” “90”)
(setq sp nnp)
(setq stp np)
(progn
(command np “A” “90”)
(setq stp np)
(if (/= (type np) ‘LIST)
(progn
(setq true nil)
(setq np ssp)
(if (< ft 1)
(setq ea 1)
(setq ea ft)
(if (> ea 1)
(progn
(setq sp stp)
(repeat ea
(command nnp “A” “90”)
(setq sp nnp)
(setq stp np)
(command ssp “” “”)
(SETVAR “CMDECHO” 1)
; (command “INSERT” “RV”)
(COMMAND “LAYER” “S” cl “”)
(command “color” co)
