홈/ 질문/Q 23304
등록일: 2005-09-202005-09-20T11:16:22+09:00 2005-09-20T11:16:22+09:00카테고리: AutoCAD & CADian
품번 리습 도넛에서 화살표로 바꿔주세요~
(defun c:p1 ()
(graphscr)
(reset)
(prompt “*** PART NO. (SINGLE) ***”)(princ)
(setq siz (getvar “dimscale”))
(setq t 1)
(setq gap (* siz 12)) ;circle diameter
(setvar “cmdecho” 0)
(setvar “osmode” 0)
(setvar “orthomode” 0)
(setq cla (getvar “clayer”))
(setq tsz (* siz 3.75))
(setq sty (getvar “textstyle”))
(setq dn1 (* siz 0.01))
(setq dn2 (* siz 1.5))
(command “layer” “s” “4” “”)
(command “osnap” “off”)
(setq pnt1 (getpoint “nSelect part :”))
(setq pnt2 (getpoint “nTo point :” pnt1))
(command “donut” dn1 dn2 pnt1 “”)
(command “line” pnt1 pnt2)
(while t
(setq pnt3 pnt2)
(setq pnt2 (getpoint “nTo point :” pnt2))
(command pnt2)
(setq e2 (entlast))
(if (= pnt2 nil)
(setq t nil)
(command “layer” “s” “1” “”)
(command “circle” pnt3 “d” gap) (setq e3 (entlast))
(command “trim” e3 “” (list e2 pnt3) “”)
(command “layer” “s” “8” “”)
(if (= num nil) (setq num “”))
(setq re_num num)
(setq num (strcase (getstring (strcat “nEnter part number <" (strcat num) "> :”))))
(if (= num nil) (setq num re_num))
(setvar “textstyle” “romans”)
(command “text” “j” “m” pnt3 tsz “0” num)
(setvar “textstyle” sty)
(reset1)
(defun c:p2 ()
(graphscr)
(reset)
(prompt “*** PART NO. (DOUBLE) ***”)(princ)
(setq t 1)
(setq gap (* siz 15)) ;circle diameter
(setvar “osmode” 0)
(setq tsz (* siz 2.5))
(while t
(setq pnt3 pnt2)
(command pnt2)
(setq e2 (entlast))
(if (= pnt2 nil)
(setq t nil)
(setq lpt1 (polar pnt3 (dtr 0) (* siz 7.5)))
(setq lpt2 (polar pnt3 (dtr 180) (* siz 7.5)))
(command “line” lpt1 lpt2 “”)
(setq re_num num)
(setq num (strcase (getstring (strcat “nEnter part number of the top <" (strcat num) "> :”))))
(setq pnt3 (polar pnt3 (dtr 90) (* siz 3.5)))
(command “text” “j” “mc” pnt3 tsz “0” num)
(setq t1 (entlast))
(if (= nu1 nil) (setq nu1 “”))
(setq re_nu1 nu1)
(setq nu1 (strcase (getstring (strcat “nEnter part number of the buttom <" (strcat nu1) "> :”))))
(if (= nu1 nil) (setq nu1 re_nu1))
(setq pnt3 (polar pnt3 (dtr 270) (* siz 6.2)))
(command “text” “j” “mc” pnt3 tsz “0” nu1)
(setq t2 (entlast))
(reset1)
품번 뽑는 리습입니다. 스타트 지점이 도넛이 아니라 화살표로 바꿀 수가
없어서 글을 씁니다. 바꿔주시거나 방법을 알려주시면 감사해요
  • 40 조회
