캐드 2009에 캠퍼스랑 옛날 프로그램을 깔았는데
구름마크가 없는 시절에 만든프로그램이라
지금 구름마크랑 충돌이 나서 구름그리기를 쓸수가없내요 ㅜㅡ
이 리습을 지우면 프로그램에서 리습찾아내라고 난리고 ㅜㅡ
방법이없나요.
그냥 리습 내용을
REVCLOUD 란 명령어만 입력하게 하면 될거같은데 ㅜㅡ
캠퍼스란 프로그램에서 리습은
;;; REVCLOUD.LSP
;;; Copyright (C) 1997 by Autodesk, Inc.
;;; Permission to use, copy, modify, and distribute this software
;;; for any purpose and without fee is hereby granted, provided
;;; that the above copyright notice appears in all copies and
;;; that both that copyright notice and the limited warranty and
;;; restricted rights notice below appear in all supporting
;;; documentation.
;;; AUTODESK PROVIDES THIS PROGRAM “AS IS” AND WITH ALL FAULTS.
;;; AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
;;; MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. AUTODESK, INC.
;;; DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
;;; UNINTERRUPTED OR ERROR FREE.
;;; Use, duplication, or disclosure by the U.S. Government is subject to
;;; restrictions set forth in FAR 52.227-19 (Commercial Computer
;;; Software – Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
;;; (Rights in Technical Data and Computer Software), as applicable.
;;; Last revision 3/14/97 1:28 PM Greg Robinson
;;; Credits: Original Code, idea and concept by David Harrington
;;; Bill Kramer, Q.C.
;;; Phil Kreiker, Q.C.
;;; Dominic Panholzer, Q.C.
;;; Randy Kinsley, Error Control
;;; Greg Robinson
(Defun C:REVCLOUD (/
ARC_DIST ;;radius of included arc
INC_ANGLE ;;included angle in degrees
LAST_PT ;;the last point just entered/shown
START_PT ;;where the cloud began
NEXT_PT ;;where we are going next
TMP ;;tempory holder for radius of bulge
(init_bonus_error
(List
(List “cmdecho” 0
“blipmode” 0
“osmode” 0
T ;flag. True means use undo for error clean up.
) ;list
) ;init_bonus_error
;;——–real program starts here!
(Setq INC_ANGLE 110)
(if (and
(/= “” (getcfg “AppData/AC_Bonus/Revcld_Bulge”))
(/= nil (getcfg “AppData/AC_Bonus/Revcld_Bulge”))
(setq ARC_DIST (atof (getcfg “AppData/AC_Bonus/Revcld_Bulge”)))
(if (= (getvar “DIMSCALE”) 0)
(setq ARC_DIST 0.375)
(setq ARC_DIST (* 0.375 (getvar “DIMSCALE”)))
);end if
(prompt (strcat “nArc length set at ” (rtos ARC_DIST 2 3)))
(initget “Arc”)
(setq LAST_PT (GetPoint “nArc length/<Pick cloud starting point>: “))
(if (= LAST_PT “Arc”)
(progn
(initget 6)
(setq TMP (getdist (strcat “nArc length <” (rtos ARC_DIST 2 3) “>: “)))
(if TMP
(Progn
(setq ARC_DIST TMP)
;R14 method of saving variable values
(setcfg “AppData/AC_Bonus/Revcld_Bulge” (rtos ARC_DIST))
(setq LAST_PT (getpoint “nPick cloud start point: “))
) ;;end STR “RADIUS” test
(if LAST_PT (progn ;;start up the cloud generator…
(setq START_PT LAST_PT
SAVED_EN (entlast))
(Prompt “nGuide crosshairs along cloud path…”)
(Command
“_.pline” ;draw cloud as a polyline on current layer
LAST_PT
“_a” ;specify arc option
“_a” ;specify angle option
INC_ANGLE ;included angle
)) ;end IF LAST_PT
(While LAST_PT ;;as long as we have a last point value,
(Setq NEXT_PT (GrRead 1) ;;real time read
READTYP (car NEXT_PT)
(if (or (= 5 READTYP) (= READTYP 3)) ;;read a position or a pick?
(progn
(setq NEXT_PT (cadr NEXT_PT))
(If (or (> (Distance LAST_PT NEXT_PT) ARC_DIST) (= READTYP 3))
(Progn
(Command NEXT_PT “_a” INC_ANGLE)
(Setq LAST_PT NEXT_PT)
(If (>
(Distance START_PT NEXT_PT)
(Progn
(Command START_PT “_cl”)
(Setq LAST_PT Nil)
(prompt “nCloud finished.”)
(prompt “nMove the pointer to draw the cloud”)
);End if
);End while
(restore_old_error)
(Princ)
) ;end cloud.lsp
(Defun c:RCHELP (/)
(prompt ” The Revision Cloud program draws a user specified bulge plinen”)
(prompt ” along the path of the crosshairs. To close the cloud, n”)
(prompt ” simply return to the starting pointn”)
(prompt ” The cloud arc length can be specified in the beginning, with keyboard inputn”)
(prompt ” by specifying A for Arc, entering a length, or picking two pts.n”)
(textscr)
(Prompt ” REVCLOUD loaded. Type REVCLOUD to draw Revision Cloud,n”)
(prompt ” to close, return to starting point. For additional Help – RCHELP”)
(Princ)
CADian 기반의 캠퍼스를 설치하면 잘 구동됩니다. 기능 추가도 가능합니다
http://www.cadian.com/download/value_content.asp?idx=52 다운로드
* 캐디안 사용자는 무료 다운하여 사용할 수 있습니다
