홈/ 질문/Q 103264
등록일: 2015-01-262015-01-26T09:13:19+09:00 2015-01-26T09:13:19+09:00카테고리: AutoCAD & CADian
깨진글씨복원 리습
깨진글씨복원리습인데요
밑의 빨간 굴림부분을 큰글꼴로 하여
romans.shx  whgtxt.shx로 바꿀수있을까요?
;; Style Change  —————>   st
(DEFUN C:stg()
;(defun stylech ()
   (setvar “cmdecho” 0)
   (command “style” “standard” “굴림” “” “” “” “” “”)
   (prompt “n This Program is change STYLE  –>  굴림으로 전환  n “)
   (setq sss(ssget “X” ‘((0 . “TEXT”))))
   (setq num (sslength sss))
   (setq i 0)
 (repeat num
   (setq ent (entget (ssname sss i)))
   (setq i (1+ i))
   (setq ass (assoc 0 ent))
 (if
      (= “TEXT” (cdr ass))
 (progn
   (setq ass1 (assoc 7 ent))
   (setq co (cons 7 “standard”))
   (setq entl (subst co ass1 ent))
   (entmod entl)
  (prompt “n”)
  (princ num) (prompt ” TEXT changed “)
  (setvar “cmdecho” 0) (princ)
(defun c:aa()
   (setq n 0)
(setq ss (ssget))
(setq id (load_dialog “aaa.dcl”))
(new_dialog “aaa” id)
(mode_tile “edit” 2)
(action_tile “edit” “(setq ed $value)”)
(setq ok (start_dialog))
(if (= ok 1)
   (draw)
(unload_dialog id)
(defun draw()
(setq sl (sslength ss))
(repeat sl
   (setq sn (ssname ss n))
   (setq get (entget sn))
   (setq as (assoc 1 get))
   (setq con (cons 1 ed))
   (setq sub (subst con as get))
   (entmod sub)
   (setq n (1+ n))
우
  • 57 조회
      2015-01-26T09:28:30+09:00답변 등록 답변 등록 일시 2015-01-26 9:28 am
      굴림을
      romans.shx,whgtxt.shx
      로 바꾸세요
