홈/ 질문/Q 112484
등록일: 2020-07-132020-07-13T14:06:45+09:00 2020-07-13T14:06:45+09:00카테고리: AutoCAD & CADian
공차 리습 잘못된 인수유형 오류에 대해 질문드립니다.
안녕하세요. 공차리습을 잘 쓰고있다가 포멧하고 리셋하였는데 잘못된 인수유형 오류라고 하면서
잘쓰던게 되질않네요.. 뭐가 문제인지 모르겠어요.
도움주셨으면 감사하겠습니다!
첨부가 안되어서 복사할게요!
(defun c:er (/ ss old_bl old_cm old_dimstyle dim_tol_list)
  (setq old_bl (GETVAR “BLIPMODE”)
old_cm (GETVAR “cmdecho”)
ok_1   0
  (defun *error* (msg)
    (if (/= (vl-directory-files
      (vl-filename-directory dim_tol_dcl_name)
      (strcat (vl-filename-base dim_tol_dcl_name)
      “.dcl”
    nil
      (vl-file-delete dim_tol_dcl_name)
      (vl-filename-directory dim_tol_setting_dcl_name)
      (strcat (vl-filename-base dim_tol_setting_dcl_name)
      “.dcl”
    nil
      (vl-file-delete dim_tol_setting_dcl_name)
    (SETVAR “cmdecho” old_cm)
    (SETVAR “BLIPMODE” old_bl)
  (setvar “cmdecho” 0)
  (SETVAR “BLIPMODE” 0)
  (vl-load-com)
  (setq dim_tol_dcl_code 29)
  (while (= dim_tol_dcl_code 29)
    (setq dim_tol_dcl_code nil)
    (dim_tol_data_setting)
    (dim_tol_dcl_made)
    (dim_tol_dcl)
    (if (= dim_tol_dcl_code 29)
      (dim_tol_data_setting_dcl_made)
  (if (or (= ok 1) (= ok_1 1))
    (progn
      (if (= dim_tol_dcl_code 27)
(progn
  (prompt “n공차를 삭제할 치수/MTEXT를 선택하시오:”)
  (setq ss (ssget ‘((0 . “DIMENSION,MTEXT”))))
  (if (/= ss nil)
    (progn
  (setq p 0)
  (while (ssname ss p)
(setq n (ssname ss p)
            p (+ p 1)
  (dim_tol3 n)
  );end while
    );end progn
  ); end if
);end progn
(progn
  (prompt “n치수/MTEXT를 선택하시오:”)
  (if (= dim_tol_dcl_code 28)
    (progn
      (setq old_dim_tol_tp dim_tol_tp
    old_dim_tol_tm dim_tol_tm
    n    (ssname ss 0)
    dim_tol_list   (dim_tol_copy n)
      (if (and (/= (car dim_tol_list) nil)
       (/= (cadr dim_tol_list) nil)
(progn
  (setq ss (ssdel n ss))
  (if (> (SSLENGTH ss) 0)
    (setq dim_tol_dcl_2 (car dim_tol_list)
  dim_tol_dcl_3 (cadr dim_tol_list)
(setq ss nil)
    (progn
      (cond
((= (atof (vl-string-left-trim “+-” dim_tol_dcl_2)) 0)
(if (= (nth 25 dim_tol_data) “1”)
   (setq dim_tol_tp “+0”)
   (setq dim_tol_tp ”  0″)
((< (atof dim_tol_dcl_2) 0)
(setq dim_tol_tp dim_tol_dcl_2)
(T
(SETQ dim_tol_tp
(STRCAT
      (cond
((= (atof (vl-string-left-trim “+-” dim_tol_dcl_3)) 0)
   (setq dim_tol_tm “-0”)
   (setq dim_tol_tm ”  0″)
((= (substr dim_tol_dcl_3 1 1) “+”)
(setq dim_tol_tm dim_tol_dcl_3)
(T
(SETQ dim_tol_tm
(STRCAT
      (if (EQUAL (atof (vl-string-left-trim “+” dim_tol_tp))
(atof (vl-string-left-trim “-” dim_tol_tm))
0.0000001
(setq dim_tol_height (atof (nth 22 dim_tol_data)))
(setq dim_tol_height (atof (nth 21 dim_tol_data)))
      (if
       0.0000001
(progn
   (if (= (substr (nth 26 dim_tol_data) 1 1) “1”)
     (progn
       (setq dim_tol_text
      (strcat “{\H”
      (rtos dim_tol_height)
      “x;\W”
      (nth 24 dim_tol_data)
      “;\C”
      (+ 2
(vl-string-search
      “;%%p”
      (rtos (atof dim_tol_tp))
     (progn
       (setq dim_tol_text
      (strcat “{\H”
      “x;\W”
      “;%%p”
(progn
     (progn
       (setq dim_tol_text
      (strcat “{\H”
      “x;\W”
      “;\C”
      (+ 2
(vl-string-search
      “;\S”
      dim_tol_tp
      dim_tol_tm
     (progn
       (setq dim_tol_text
      (strcat “{\H”
      “x;\W”
      “;\S”
      dim_tol_tp
      dim_tol_tm
      (if
(= (atof (vl-string-left-trim “+-” dim_tol_tp)) 0)
(progn
     (setq dim_tp 0.0000001)
     (setq dim_tp 0)
(setq dim_tp (atof dim_tol_tp))
      (if
(= (atof (vl-string-left-trim “+-” dim_tol_tm)) 0)
(progn
     (setq dim_tm 0.0000001)
     (setq dim_tm 0)
(progn
   (if (= (substr dim_tol_tm 1 1) “+”)
     (setq dim_tm
    (atof (strcat
    (vl-string-left-trim “+” dim_tol_tm)
     (setq dim_tm
      (setq p 0)
      p (+ p 1)
(if (= (cdr (assoc 0 (entget n))) “MTEXT”)
  (dim_tol1 n)
  (progn
    (if (= dim_tol_dcl_4 “1”)
      (dim_tol1 n)
      (dim_tol2 n)
;;;               MTEXT형 공차
(defun dim_tol1 (n / n n1 n2 n3 n4 n5 n6 n7 n8 n9 p1)
  (setq n1 (entget n)
n2 (assoc 1 n1)
n3 (cdr n2)
  (if (or (and (= (cdr (assoc 0 n1)) “DIMENSION”)
       (= (EQUAL (cdr (assoc 42 n1)) 0 0.000001) nil)
  (= (cdr (assoc 0 n1)) “MTEXT”)
    (progn
      (if (= (cdr (assoc 0 n1)) “DIMENSION”)
(progn
  (vla-put-tolerancedisplay (vlax-ename->vla-object n) 0)
  (if (or (= n3 “”) (= n3 nil))
    (setq n3 “<>”)
      (while (and (/= (setq n5 (vl-string-search “{” n3)) nil)
  (/= (setq n6 (vl-string-search “}” n3)) nil)
(if (< n6 (- (strlen n3) 1))
  (setq n3 (strcat (substr n3 1 n5)
   (substr n3 (+ n6 2) (- (strlen n3) n6))
  (setq n3 (substr n3 1 n5))
      (setq n8 “”)
      (if (> (atoi (nth 23 dim_tol_data)) 0)
(progn
  (setq p1 1)
  (while (<= p1 (atoi (nth 23 dim_tol_data)))
    (setq n8 (strcat n8 ” “)
  p1 (+ p1 1)
      (if
     (< (setq n7 (vl-string-search “>” n3)) (- (strlen n3) 1))
(setq n9 (subst (cons 1
       (strcat (substr n3 1 (+ n7 1))
       n8
       dim_tol_text
       (substr n3 (+ n7 2))
n2
n1
(progn
   (while (= (substr n3 (strlen n3)) ” “)
     (setq n3 (substr n3 1 (- (strlen n3) 1)))
   (setq n9 (subst (cons 1 (strcat n3 n8 dim_tol_text)) n2 n1))
      (entmod n9)
;;;                      캐드 공차타입 공차
(defun dim_tol2 (n / n n1 n2 n3 n4 n5 n6 n7)
  (setq n1 (entget n)
n2 (assoc 1 n1)
n3 (cdr n2)
  (if (= (EQUAL (cdr (assoc 42 n1)) 0 0.000001) nil)
    (progn
      (while (and (/= (setq n4 (vl-string-search “{” n3)) nil)
  (/= (setq n5 (vl-string-search “}” n3)) nil)
(if (< n5 (- (strlen n3) 1))
  (setq n3 (strcat (substr n3 1 n4)
   (substr n3 (+ n5 2) (- (strlen n3) n5))
  (setq n3 (substr n3 1 n4))
      (setq n6 (subst (cons 1 n3) n2 n1))
      (entmod n6)
      (setq n7 (vlax-ename->vla-object n))
0.0000001
(progn
  (vla-put-tolerancedisplay (vlax-ename->vla-object n) 1)
  (vla-put-tolerancelowerlimit
    dim_tP
(progn
  (vla-put-tolerancedisplay (vlax-ename->vla-object n) 2)
    dim_tm
      (vla-put-toleranceheightscale
dim_tol_height
      (vla-put-toleranceupperlimit
dim_tp
      (command “dimedit” “h” n “”)
;;;               공차 삭제
(defun dim_tol3 (n / p n n1 n2 n3 n4 n5 n6 n7)
  (setq n1 (entget n)
  n2 (assoc 1 n1)
  n3 (cdr n2)
  (if (and (/= n3 “”) (/= n3 nil))
    (progn
      (setq n7 (subst (cons 1 n3) n2 n1))
      (entmod n7)
    (progn
;;;               공차 복사
(defun dim_tol_copy (dim_tol_copy_n  /      dim_text
     dim_text_1      dim_text_2      dim_tol_top
     dim_tol_min
  (if (or (and (= (cdr (assoc 0 (entget dim_tol_copy_n))) “DIMENSION”)
       (= (vla-get-tolerancedisplay
    (vlax-ename->vla-object dim_tol_copy_n)
  0
  (= (cdr (assoc 0 (entget dim_tol_copy_n))) “MTEXT”)
    (progn
      (if (= (cdr (assoc 0 (entget dim_tol_copy_n))) “MTEXT”)
(setq dim_text (vla-get-textstring
(setq dim_text (vla-get-textoverride
      (if (wcmatch dim_text “*{\H*”)
(progn
  (if (wcmatch dim_text “*%%p*”)
    (setq dim_text_1  (substr dim_text
      (+ (vl-string-search “%%p” dim_text) 4)
  dim_tol_top (substr dim_text_1
      1
      (vl-string-search “}” dim_text_1)
  dim_tol_min dim_tol_top
      (+ (vl-string-search “\S” dim_text) 3)
      1
      (vl-string-search “^” dim_text_1)
  dim_text_2  (substr dim_text_1
      (+ (vl-string-search “^” dim_text_1) 2)
  dim_tol_min (substr dim_text_2
      1
      (vl-string-search “;” dim_text_2)
(setq dim_tol_top nil
      dim_tol_min nil
    (progn
      (if (= (vla-get-tolerancedisplay
     1
(setq dim_tol_top (rtos (vla-get-toleranceupperlimit
2
10
(progn
  2
  10
dim_tol_min (rtos (vla-get-tolerancelowerlimit
  2
  10
  (if (vl-string-search “-” dim_tol_min)
    (setq dim_tol_min
   (strcat “+”
   (vl-string-left-trim “-” dim_tol_min)
  (list dim_tol_top dim_tol_min)
(defun dim_tol_dcl (/ dcl_id)
  (setq dcl_id (load_dialog dim_tol_dcl_name))
  (if (not (new_dialog “dim_tol” dcl_id))
    (exit)
  (if (or (and (= dim_tol_dcl_5 nil) (= dim_tol_dcl_4 nil))
    (SET_TILE “dim_tol_dcl_4” “1”)
    (progn
      (SET_TILE “dim_tol_dcl_5” “1”)
  (dim_tol_dcl1)
  (if (= dim_tol_dcl_2 nil)
    (setq dim_tol_dcl_2 “0.01”)
  (if (= dim_tol_dcl_3 nil)
    (setq dim_tol_dcl_3 “0.01”)
  (dim_tol_dcl7)
  (dim_tol_dcl2)
  (action_tile
    “dim_tol_dcl_1”
    “(setq dim_tol_dcl_1 $value)(dim_tol_dcl3)”
  (action_tile
    “dim_tol_dcl_2”
    “(setq dim_tol_dcl_2 $value)(dim_tol_dcl5)(dim_tol_dcl3)”
  (action_tile
    “dim_tol_dcl_3”
    “(setq dim_tol_dcl_3 $value)(dim_tol_dcl6)”
  (action_tile “dim_tol_dcl_4” “(dim_tol_dcl1)”)
  (action_tile “dim_tol_dcl_5” “(dim_tol_dcl1)”)
  (action_tile
    “dim_tol_dcl_6”
    “(setq dim_tol_dcl_code 0)(dim_tol_dcl4)”
  (action_tile
    “dim_tol_dcl_7”
    “(setq dim_tol_dcl_code 1)(dim_tol_dcl4)”
  (action_tile
    “dim_tol_dcl_8”
    “(setq dim_tol_dcl_code 2)(dim_tol_dcl4)”
  (action_tile
    “dim_tol_dcl_9”
    “(setq dim_tol_dcl_code 3)(dim_tol_dcl4)”
  (action_tile
    “dim_tol_dcl_10”
    “(setq dim_tol_dcl_code 4)(dim_tol_dcl4)”
  (action_tile
    “dim_tol_dcl_11”
    “(setq dim_tol_dcl_code 5)(dim_tol_dcl4)”
  (action_tile
    “dim_tol_dcl_12”
    “(setq dim_tol_dcl_code 6)(dim_tol_dcl4)”
  (action_tile
    “dim_tol_dcl_13”
    “(setq dim_tol_dcl_code 7)(dim_tol_dcl4)”
  (action_tile
    “dim_tol_dcl_14”
    “(setq dim_tol_dcl_code 8)(dim_tol_dcl4)”
  (action_tile
    “dim_tol_dcl_15”
    “(setq dim_tol_dcl_code 9)(dim_tol_dcl4)”
  (action_tile
    “dim_tol_dcl_16”
    “(setq dim_tol_dcl_code 10)(dim_tol_dcl4)”
  (action_tile
    “dim_tol_dcl_17”
    “(setq dim_tol_dcl_code 11)(dim_tol_dcl4)”
  (action_tile
    “dim_tol_dcl_18”
    “(setq dim_tol_dcl_code 12)(dim_tol_dcl4)”
  (action_tile
    “dim_tol_dcl_19”
    “(setq dim_tol_dcl_code 13)(dim_tol_dcl4)”
  (action_tile
    “dim_tol_dcl_20”
    “(setq dim_tol_dcl_code 14)(dim_tol_dcl4)”
  (action_tile
    “dim_tol_dcl_21”
    “(setq dim_tol_dcl_code 15)(dim_tol_dcl4)”
  (action_tile
    “dim_tol_dcl_22”
    “(setq dim_tol_dcl_code 16)(dim_tol_dcl4)”
  (action_tile
    “dim_tol_dcl_23”
    “(setq dim_tol_dcl_code 17)(dim_tol_dcl4)”
  (action_tile
    “dim_tol_dcl_24”
    “(setq dim_tol_dcl_code 18)(dim_tol_dcl4)”
  (action_tile
    “dim_tol_dcl_25”
    “(setq dim_tol_dcl_code 19)(dim_tol_dcl4)”
  (action_tile
    “dim_tol_dcl_26”
    “(setq dim_tol_dcl_code 20)(dim_tol_dcl4)”
  (action_tile
    “dim_tol_dcl_27”
    “(setq dim_tol_dcl_code 27 ok_1 1)(done_dialog)”
  (action_tile
    “dim_tol_dcl_28”
    “(setq dim_tol_dcl_code 28 ok_1 1)(done_dialog)”
  (action_tile
    “dim_tol_dcl_29”
    “(setq dim_tol_dcl_code 29)(done_dialog)”
  (setq ok (start_dialog))
  (done_dialog)
  (unload_dialog dcl_id)
(defun dim_tol_dcl1 (/)
  (setq dim_tol_dcl_4 (GET_TILE “dim_tol_dcl_4”)
dim_tol_dcl_5 (GET_TILE “dim_tol_dcl_5”)
    (progn
      (SET_TILE “dim_tol_dcl_4_1”
“***멀티텍스트로 삽입합니다***”
      (SET_TILE “dim_tol_dcl_5_1” “”)
    (progn
      (SET_TILE “dim_tol_dcl_4_1” “”)
      (SET_TILE “dim_tol_dcl_5_1” “***캐드공차로 삽입합니다***”)
(defun dim_tol_dcl2 (/)
  (if (= dim_tol_dcl_2 dim_tol_dcl_3)
    (progn
      (SET_TILE “dim_tol_dcl_1” “1”)
      (SET_TILE “dim_tol_dcl_2” dim_tol_dcl_2)
      (MODE_TILE “dim_tol_dcl_3” 1)
    (progn
      (MODE_TILE “dim_tol_dcl_3” 0)
      (SET_TILE “dim_tol_dcl_1” “0”)
      (SET_TILE “dim_tol_dcl_3” dim_tol_dcl_3)
(defun dim_tol_dcl3 (/)
  (if (= dim_tol_dcl_1 “1”)
    (progn
      (setq dim_tol_dcl_3 dim_tol_dcl_2)
    (progn
(defun dim_tol_dcl4 (/)
  (done_dialog)
  (if (/= (vl-string-search “±” (nth dim_tol_dcl_code dim_tol_data))
  nil
    (setq dim_tol_dcl_2 (vl-string-left-trim
    (setq dim_tol_dcl_2 (substr
  1
  (vl-string-search
  dim_tol_dcl_3 (substr (nth dim_tol_dcl_code dim_tol_data)
   2
  (dim_tol_dcl7)
  (setq ok_1 1)
(defun dim_tol_dcl5 (/ dim_tol_dcl5_1 dim_tol_dcl5_2)
  (setq p 1
dim_tol_dcl5_1
dim_tol_dcl_2
  (if (wcmatch (substr dim_tol_dcl5_1 1 1) “+,-“)
    (setq dim_tol_dcl5_1 (substr dim_tol_dcl5_1 2))
  (while (<= p (strlen dim_tol_dcl5_1))
    (setq dim_tol_dcl5_2 (substr dim_tol_dcl5_1 p 1))
    (if (and (/= dim_tol_dcl5_2 “.”)
     (= (wcmatch dim_tol_dcl5_2 “#”) nil)
      (progn
(setq p (+ (strlen dim_tol_dcl5_1) 1))
(MODE_TILE “dim_tol_dcl_2” 2)
      (setq p (+ p 1))
(defun dim_tol_dcl6 (/ dim_tol_dcl6_1 dim_tol_dcl6_2)
  (setq p 1
dim_tol_dcl6_1
dim_tol_dcl_3
  (if (wcmatch (substr dim_tol_dcl6_1 1 1) “+,-“)
    (setq dim_tol_dcl6_1 (substr dim_tol_dcl6_1 2))
  (while (<= p (strlen dim_tol_dcl6_1))
    (setq dim_tol_dcl6_2 (substr dim_tol_dcl6_1 p 1))
    (if (and (/= dim_tol_dcl6_2 “.”)
     (= (wcmatch dim_tol_dcl6_2 “#”) nil)
      (progn
(setq p (+ (strlen dim_tol_dcl6_1) 1))
(MODE_TILE “dim_tol_dcl_3” 2)
      (setq p (+ p 1))
(defun dim_tol_dcl7 (/)
  (if (or (/= (vl-string-search “+” dim_tol_dcl_2) nil)
  (= (atof (vl-string-left-trim “+-±” dim_tol_dcl_2)) 0)
    (setq dim_tol_dcl_2 (vl-string-left-trim “+-±” dim_tol_dcl_2))
  (if (or (/= (vl-string-search “-” dim_tol_dcl_3) nil)
  (= (atof (vl-string-left-trim “+-±” dim_tol_dcl_3)) 0)
    (setq dim_tol_dcl_3 (vl-string-left-trim “+-±” dim_tol_dcl_3))
(defun dim_tol_dcl_made (/
dim_tol_dcl_name_1
dim_tol_dcl_name_2
  (setq dim_tol_dcl_name   (vl-filename-mktemp “dim_tol.dcl”)
dim_tol_dcl_name_1 (open dim_tol_dcl_name “w”)
dim_tol_dcl_name_2 (strcat
     “dim_tol : dialog {label=”공차 입력”;
:row{
:boxed_row{label=”입력/선택 공차보기”;
:row{
: toggle {
label = ”±공차”;
key = ”dim_tol_dcl_1”;
width = 8;
height = 1;
:column {
:edit_box{
key=”dim_tol_dcl_2”;
edit_width=8;
height = 1;
allow_accept=true;
:edit_box{
key=”dim_tol_dcl_3”;
edit_width=8;
height = 1;
allow_accept=true;
spacer_1;
:boxed_row{label=”TYPE 선택”;
:radio_column{
: radio_button {
label = ”MTEXT로 삽입”;
key = ”dim_tol_dcl_4”;
width = 15;
height = 1;
: radio_button {
label = ”공차로 삽입”;
key = ”dim_tol_dcl_5”;
width = 20;
height = 1;
:column{
: text {
key = ”dim_tol_dcl_4_1”;
is_bold = true;
width = 30;
height = 1;
alignment = left;
: text {
key = ”dim_tol_dcl_5_1”;
is_bold = true;
width = 30;
height = 1;
alignment = left;
spacer_1;
:boxed_column{label=”원터치 선택”;
:row{
:button{
label = ””      (nth 0 dim_tol_data)
key = ”dim_tol_dcl_6”;
height = 2;
width = 13;
:button{
label = ””      (nth 1 dim_tol_data)
key = ”dim_tol_dcl_7”;
height = 2;
width = 13;
:button{
label = ””      (nth 2 dim_tol_data)
key = ”dim_tol_dcl_8”;
height = 2;
width = 13;
:button{
label = ””      (nth 3 dim_tol_data)
key = ”dim_tol_dcl_9”;
height = 2;
width = 13;
:button{
label = ””      (nth 4 dim_tol_data)
key = ”dim_tol_dcl_10”;
height = 2;
width = 13;
:button{
label = ””      (nth 5 dim_tol_data)
key = ”dim_tol_dcl_11”;
height = 2;
width = 13;
:button{
label = ””      (nth 6 dim_tol_data)
key = ”dim_tol_dcl_12”;
height = 2;
width = 13;
spacer_1;
:row{
:button{
label = ””      (nth 7 dim_tol_data)
key = ”dim_tol_dcl_13”;
height = 2;
width = 13;
:button{
label = ””      (nth 8 dim_tol_data)
key = ”dim_tol_dcl_14”;
height = 2;
width = 13;
:button{
label = ””      (nth 9 dim_tol_data)
key = ”dim_tol_dcl_15”;
height = 2;
width = 13;
:button{
label = ””      (nth 10 dim_tol_data)
key = ”dim_tol_dcl_16”;
height = 2;
width = 13;
:button{
label = ””      (nth 11 dim_tol_data)
key = ”dim_tol_dcl_17”;
height = 2;
width = 13;
:button{
label = ””      (nth 12 dim_tol_data)
key = ”dim_tol_dcl_18”;
height = 2;
width = 13;
:button{
label = ””      (nth 13 dim_tol_data)
key = ”dim_tol_dcl_19”;
height = 2;
width = 13;
spacer_1;
:row {
:button{
label = ””      (nth 14 dim_tol_data)
key = ”dim_tol_dcl_20”;
height = 2;
width = 13;
:button{
label = ””      (nth 15 dim_tol_data)
key = ”dim_tol_dcl_21”;
height = 2;
width = 13;
:button{
label = ””      (nth 16 dim_tol_data)
key = ”dim_tol_dcl_22”;
height = 2;
width = 13;
:button{
label = ””      (nth 17 dim_tol_data)
key = ”dim_tol_dcl_23”;
height = 2;
width = 13;
:button{
label = ””      (nth 18 dim_tol_data)
key = ”dim_tol_dcl_24”;
height = 2;
width = 13;
:button{
label = ””      (nth 19 dim_tol_data)
key = ”dim_tol_dcl_25”;
height = 2;
width = 13;
:button{
label = ””      (nth 20 dim_tol_data)
key = ”dim_tol_dcl_26”;
height = 2;
width = 13;
spacer_1;
:row{
spacer_1;
:button{
label = ”삭제”;
key = ”dim_tol_dcl_27”;
height = 2;
width = 13;
:button{
label = ”복사”;
key = ”dim_tol_dcl_28”;
height = 2;
width = 13;
: spacer {width = 55; height = 1;}
:button{
label = ”설정”;
key = ”dim_tol_dcl_29”;
height = 2;
width = 13;
spacer_1;
: spacer {width = 1; height = 2;}
ok_cancel;
  (write-line dim_tol_dcl_name_2 dim_tol_dcl_name_1)
  (close dim_tol_dcl_name_1)
(defun dim_tol_data_setting (/   dim_tol_setting_1
     dim_tol_setting_2   dim_tol_setting_3
     dim_tol_setting_4   p
  (setq dim_tol_data nil)
  (if (/= (open (setq dim_tol_setting_1 “c://dim_tol.dat”) “r”)
  nil
    (progn
      (setq dim_tol_setting_2
     (open dim_tol_setting_1 “r”)
    dim_tol_setting_3
     (read-line dim_tol_setting_2)
    dim_tol_setting_3
    p 0
      (while (and (< p 27) (/= dim_tol_setting_3 nil))
(setq dim_tol_data
       (append dim_tol_data (list dim_tol_setting_3))
      dim_tol_setting_3
      p (+ p 1)
      (close dim_tol_setting_2)
      (if (/= (LENGTH dim_tol_data) 27)
(progn
  (dim_tol_data_setting_1)
    (progn
(defun dim_tol_data_setting_1 (/ dim_tol_setting_1 dim_tol_setting_2 p)
  (if (= dim_tol_data nil)
    (setq dim_tol_data
   (list “0.002/0”   “0.005/0” “0.01/0”    “0.02/0”
“0.05/0”    “0.1/0” “0.2/0”     “±0.002”
“±0.005”   “±0.01” “±0.02”    “±0.05”
“±0.1”     “±0.2” “0/0.002”   “0/0.005”
“0/0.01”    “0/0.02” “0/0.05”    “0/0.1”
“0/0.2”     “0.55” “0.8”      “0”
“0.8”      “0” “0/3”
dim_tol_setting_2 (open dim_tol_setting_1 “w”)
  (write-line
    “치수공차리습에 적용할 환경데이타 입니다,수정하지 마세요 “
    dim_tol_setting_2
  (setq p 0)
  (while (< p (LENGTH dim_tol_data))
    (write-line (nth p dim_tol_data) dim_tol_setting_2)
    (setq p (+ p 1))
(defun dim_tol_data_setting_dcl (/ dcl_id_1 p)
  (setq dcl_id_1 (load_dialog dim_tol_setting_dcl_name))
  (if (not (new_dialog “dim_tol_setting” dcl_id_1))
    (exit)
  (setq p 1
dim_tol_data_setting_ok
0
  (REPEAT 21
    (setq dim_tol_setting_dcl_1 (nth (- p 1) dim_tol_data))
    (if (/= (vl-string-search “±” dim_tol_setting_dcl_1) NIL)
      (SET_TILE (strcat “dim_tol_setting_” (rtos p) “_1”)
(vl-string-left-trim “±” dim_tol_setting_dcl_1)
  (substr dim_tol_setting_dcl_1
  1
  (vl-string-search “/” dim_tol_setting_dcl_1)
    (setq p (+ p 1))
  (setq p 1)
  (REPEAT 21
      (SET_TILE (strcat “dim_tol_setting_” (rtos p) “_2”)
      (SET_TILE
  (+ 2 (vl-string-search “/” dim_tol_setting_dcl_1))
    (setq p (+ p 1))
;;;  (setq p 22)
  (REPEAT 5
    (SET_TILE (strcat “dim_tol_setting_” (rtos p))
    (setq p (+ p 1))
  (setq dim_tol_setting_27 (substr (nth 26 dim_tol_data) 1 1)
dim_tol_setting_28 (atoi (substr (nth 26 dim_tol_data)
(+ 2
    (vl-string-search
  (dim_tol_setting_color)
  (dim_tol_data_setting_dcl1)
  (action_tile
    “dim_tol_setting_1_1”
    “(setq dim_tol_setting_1_1 $VALUE dim_tol_setting_code 1)(dim_tol_data_setting_dcl3)”
  (action_tile
    “dim_tol_setting_1_2”
    “(setq dim_tol_setting_1_2 $VALUE dim_tol_setting_code 1)(dim_tol_data_setting_dcl4)”
  (action_tile
    “dim_tol_setting_2_1”
    “(setq dim_tol_setting_2_1 $VALUE dim_tol_setting_code 2)(dim_tol_data_setting_dcl3)”
  (action_tile
    “dim_tol_setting_2_2”
    “(setq dim_tol_setting_2_2 $VALUE dim_tol_setting_code 2)(dim_tol_data_setting_dcl4)”
  (action_tile
    “dim_tol_setting_3_1”
    “(setq dim_tol_setting_3_1 $VALUE dim_tol_setting_code 3)(dim_tol_data_setting_dcl3)”
  (action_tile
    “dim_tol_setting_3_2”
    “(setq dim_tol_setting_3_2 $VALUE dim_tol_setting_code 3)(dim_tol_data_setting_dcl4)”
  (action_tile
    “dim_tol_setting_4_1”
    “(setq dim_tol_setting_4_1 $VALUE dim_tol_setting_code 4)(dim_tol_data_setting_dcl3)”
  (action_tile
    “dim_tol_setting_4_2”
    “(setq dim_tol_setting_4_2 $VALUE dim_tol_setting_code 4)(dim_tol_data_setting_dcl4)”
  (action_tile
    “dim_tol_setting_5_1”
    “(setq dim_tol_setting_5_1 $VALUE dim_tol_setting_code 5)(dim_tol_data_setting_dcl3)”
  (action_tile
    “dim_tol_setting_5_2”
    “(setq dim_tol_setting_5_2 $VALUE dim_tol_setting_code 5)(dim_tol_data_setting_dcl4)”
  (action_tile
    “dim_tol_setting_6_1”
    “(setq dim_tol_setting_6_1 $VALUE dim_tol_setting_code 6)(dim_tol_data_setting_dcl3)”
  (action_tile
    “dim_tol_setting_6_2”
    “(setq dim_tol_setting_6_2 $VALUE dim_tol_setting_code 6)(dim_tol_data_setting_dcl4)”
  (action_tile
    “dim_tol_setting_7_1”
    “(setq dim_tol_setting_7_1 $VALUE dim_tol_setting_code 7)(dim_tol_data_setting_dcl3)”
  (action_tile
    “dim_tol_setting_7_2”
    “(setq dim_tol_setting_7_2 $VALUE dim_tol_setting_code 7)(dim_tol_data_setting_dcl4)”
  (action_tile
    “dim_tol_setting_8_1”
    “(setq dim_tol_setting_8_1 $VALUE dim_tol_setting_code 8)(dim_tol_data_setting_dcl3)”
  (action_tile
    “dim_tol_setting_8_2”
    “(setq dim_tol_setting_8_2 $VALUE dim_tol_setting_code 8)(dim_tol_data_setting_dcl4)”
  (action_tile
    “dim_tol_setting_9_1”
    “(setq dim_tol_setting_9_1 $VALUE dim_tol_setting_code 9)(dim_tol_data_setting_dcl3)”
  (action_tile
    “dim_tol_setting_9_2”
    “(setq dim_tol_setting_9_2 $VALUE dim_tol_setting_code 9)(dim_tol_data_setting_dcl4)”
  (action_tile
    “dim_tol_setting_10_1”
    “(setq dim_tol_setting_10_1 $VALUE dim_tol_setting_code 10)(dim_tol_data_setting_dcl3)”
  (action_tile
    “dim_tol_setting_10_2”
    “(setq dim_tol_setting_10_2 $VALUE dim_tol_setting_code 10)(dim_tol_data_setting_dcl4)”
  (action_tile
    “dim_tol_setting_11_1”
    “(setq dim_tol_setting_11_1 $VALUE dim_tol_setting_code 11)(dim_tol_data_setting_dcl3)”
  (action_tile
    “dim_tol_setting_11_2”
    “(setq dim_tol_setting_11_2 $VALUE dim_tol_setting_code 11)(dim_tol_data_setting_dcl4)”
  (action_tile
    “dim_tol_setting_12_1”
    “(setq dim_tol_setting_12_1 $VALUE dim_tol_setting_code 12)(dim_tol_data_setting_dcl3)”
  (action_tile
    “dim_tol_setting_12_2”
    “(setq dim_tol_setting_12_2 $VALUE dim_tol_setting_code 12)(dim_tol_data_setting_dcl4)”
  (action_tile
    “dim_tol_setting_13_1”
    “(setq dim_tol_setting_13_1 $VALUE dim_tol_setting_code 13)(dim_tol_data_setting_dcl3)”
  (action_tile
    “dim_tol_setting_13_2”
    “(setq dim_tol_setting_13_2 $VALUE dim_tol_setting_code 13)(dim_tol_data_setting_dcl4)”
  (action_tile
    “dim_tol_setting_14_1”
    “(setq dim_tol_setting_14_1 $VALUE dim_tol_setting_code 14)(dim_tol_data_setting_dcl3)”
  (action_tile
    “dim_tol_setting_14_2”
    “(setq dim_tol_setting_14_2 $VALUE dim_tol_setting_code 14)(dim_tol_data_setting_dcl4)”
  (action_tile
    “dim_tol_setting_15_1”
    “(setq dim_tol_setting_15_1 $VALUE dim_tol_setting_code 15)(dim_tol_data_setting_dcl3)”
  (action_tile
    “dim_tol_setting_15_2”
    “(setq dim_tol_setting_15_2 $VALUE dim_tol_setting_code 15)(dim_tol_data_setting_dcl4)”
  (action_tile
    “dim_tol_setting_16_1”
    “(setq dim_tol_setting_16_1 $VALUE dim_tol_setting_code 16)(dim_tol_data_setting_dcl3)”
  (action_tile
    “dim_tol_setting_16_2”
    “(setq dim_tol_setting_16_2 $VALUE dim_tol_setting_code 16)(dim_tol_data_setting_dcl4)”
  (action_tile
    “dim_tol_setting_17_1”
    “(setq dim_tol_setting_17_1 $VALUE dim_tol_setting_code 17)(dim_tol_data_setting_dcl3)”
  (action_tile
    “dim_tol_setting_17_2”
    “(setq dim_tol_setting_17_2 $VALUE dim_tol_setting_code 17)(dim_tol_data_setting_dcl4)”
  (action_tile
    “dim_tol_setting_18_1”
    “(setq dim_tol_setting_18_1 $VALUE dim_tol_setting_code 18)(dim_tol_data_setting_dcl3)”
  (action_tile
    “dim_tol_setting_18_2”
    “(setq dim_tol_setting_18_2 $VALUE dim_tol_setting_code 18)(dim_tol_data_setting_dcl4)”
  (action_tile
    “dim_tol_setting_19_1”
    “(setq dim_tol_setting_19_1 $VALUE dim_tol_setting_code 19)(dim_tol_data_setting_dcl3)”
  (action_tile
    “dim_tol_setting_19_2”
    “(setq dim_tol_setting_19_2 $VALUE dim_tol_setting_code 19)(dim_tol_data_setting_dcl4)”
  (action_tile
    “dim_tol_setting_20_1”
    “(setq dim_tol_setting_20_1 $VALUE dim_tol_setting_code 20)(dim_tol_data_setting_dcl3)”
  (action_tile
    “dim_tol_setting_20_2”
    “(setq dim_tol_setting_20_2 $VALUE dim_tol_setting_code 20)(dim_tol_data_setting_dcl4)”
  (action_tile
    “dim_tol_setting_21_1”
    “(setq dim_tol_setting_21_1 $VALUE dim_tol_setting_code 21)(dim_tol_data_setting_dcl3)”
  (action_tile
    “dim_tol_setting_21_2”
    “(setq dim_tol_setting_21_2 $VALUE dim_tol_setting_code 21)(dim_tol_data_setting_dcl4)”
  (action_tile
    “dim_tol_setting_22”
    “(setq dim_tol_setting_22 $VALUE dim_tol_setting_code 22)(dim_tol_data_setting_dcl5)”
  (action_tile
    “dim_tol_setting_23”
    “(setq dim_tol_setting_23 $VALUE dim_tol_setting_code 23)(dim_tol_data_setting_dcl5)”
  (action_tile
    “dim_tol_setting_24”
    “(setq dim_tol_setting_24 $VALUE dim_tol_setting_code 24)(dim_tol_data_setting_dcl6)”
  (action_tile
    “dim_tol_setting_25”
    “(setq dim_tol_setting_25 $VALUE dim_tol_setting_code 25)(dim_tol_data_setting_dcl5)”
  (action_tile
    “dim_tol_setting_26”
    “(setq dim_tol_setting_26 $VALUE)”
  (action_tile
    “dim_tol_setting_27”
    “(setq dim_tol_setting_27 $VALUE)(dim_tol_setting_color)”
  (action_tile
    “dim_tol_setting_28”
    “(dim_tol_setting_color1)”
  (setq dim_tol_data_setting_ok (start_dialog))
  (done_dialog)
  (unload_dialog dcl_id_1)
(defun dim_tol_data_setting_dcl1 (/)
(GET_TILE “dim_tol_setting_1_1”)
dim_tol_setting_1_2
(GET_TILE “dim_tol_setting_1_2”)
dim_tol_setting_2_1
(GET_TILE “dim_tol_setting_2_1”)
dim_tol_setting_2_2
(GET_TILE “dim_tol_setting_2_2”)
dim_tol_setting_3_1
(GET_TILE “dim_tol_setting_3_1”)
dim_tol_setting_3_2
(GET_TILE “dim_tol_setting_3_2”)
dim_tol_setting_4_1
(GET_TILE “dim_tol_setting_4_1”)
dim_tol_setting_4_2
(GET_TILE “dim_tol_setting_4_2”)
dim_tol_setting_5_1
(GET_TILE “dim_tol_setting_5_1”)
dim_tol_setting_5_2
(GET_TILE “dim_tol_setting_5_2”)
dim_tol_setting_6_1
(GET_TILE “dim_tol_setting_6_1”)
dim_tol_setting_6_2
(GET_TILE “dim_tol_setting_6_2”)
dim_tol_setting_7_1
(GET_TILE “dim_tol_setting_7_1”)
dim_tol_setting_7_2
(GET_TILE “dim_tol_setting_7_2”)
dim_tol_setting_8_1
(GET_TILE “dim_tol_setting_8_1”)
dim_tol_setting_8_2
(GET_TILE “dim_tol_setting_8_2”)
dim_tol_setting_9_1
(GET_TILE “dim_tol_setting_9_1”)
dim_tol_setting_9_2
(GET_TILE “dim_tol_setting_9_2”)
(GET_TILE “dim_tol_setting_10_1”)
(GET_TILE “dim_tol_setting_10_2”)
(GET_TILE “dim_tol_setting_11_1”)
(GET_TILE “dim_tol_setting_11_2”)
(GET_TILE “dim_tol_setting_12_1”)
(GET_TILE “dim_tol_setting_12_2”)
(GET_TILE “dim_tol_setting_13_1”)
(GET_TILE “dim_tol_setting_13_2”)
(GET_TILE “dim_tol_setting_14_1”)
(GET_TILE “dim_tol_setting_14_2”)
(GET_TILE “dim_tol_setting_15_1”)
(GET_TILE “dim_tol_setting_15_2”)
(GET_TILE “dim_tol_setting_16_1”)
(GET_TILE “dim_tol_setting_16_2”)
(GET_TILE “dim_tol_setting_17_1”)
(GET_TILE “dim_tol_setting_17_2”)
(GET_TILE “dim_tol_setting_18_1”)
(GET_TILE “dim_tol_setting_18_2”)
(GET_TILE “dim_tol_setting_19_1”)
(GET_TILE “dim_tol_setting_19_2”)
(GET_TILE “dim_tol_setting_20_1”)
(GET_TILE “dim_tol_setting_20_2”)
(GET_TILE “dim_tol_setting_21_1”)
(GET_TILE “dim_tol_setting_21_2”)
dim_tol_setting_22
(GET_TILE “dim_tol_setting_22”)
dim_tol_setting_23
(GET_TILE “dim_tol_setting_23”)
dim_tol_setting_24
(GET_TILE “dim_tol_setting_24”)
dim_tol_setting_25
(GET_TILE “dim_tol_setting_25”)
dim_tol_setting_26
(GET_TILE “dim_tol_setting_26”)
(defun dim_tol_data_setting_dcl2 (/)
  (if (= (vl-string-left-trim “+” dim_tol_setting_1_1)
(vl-string-left-trim “-” dim_tol_setting_1_2)
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
  (if (= (vl-string-left-trim “+” dim_tol_setting_2_1)
(vl-string-left-trim “-” dim_tol_setting_2_2)
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
  (if (= (vl-string-left-trim “+” dim_tol_setting_3_1)
(vl-string-left-trim “-” dim_tol_setting_3_2)
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
  (if (= (vl-string-left-trim “+” dim_tol_setting_4_1)
(vl-string-left-trim “-” dim_tol_setting_4_2)
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
  (if (= (vl-string-left-trim “+” dim_tol_setting_5_1)
(vl-string-left-trim “-” dim_tol_setting_5_2)
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
  (if (= (vl-string-left-trim “+” dim_tol_setting_6_1)
(vl-string-left-trim “-” dim_tol_setting_6_2)
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
  (if (= (vl-string-left-trim “+” dim_tol_setting_7_1)
(vl-string-left-trim “-” dim_tol_setting_7_2)
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
  (if (= (vl-string-left-trim “+” dim_tol_setting_8_1)
(vl-string-left-trim “-” dim_tol_setting_8_2)
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
  (if (= (vl-string-left-trim “+” dim_tol_setting_9_1)
(vl-string-left-trim “-” dim_tol_setting_9_2)
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
  (if (= (vl-string-left-trim “+” dim_tol_setting_10_1)
(vl-string-left-trim “-” dim_tol_setting_10_2)
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
  (if (= (vl-string-left-trim “+” dim_tol_setting_11_1)
(vl-string-left-trim “-” dim_tol_setting_11_2)
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
  (if (= (vl-string-left-trim “+” dim_tol_setting_12_1)
(vl-string-left-trim “-” dim_tol_setting_12_2)
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
  (if (= (vl-string-left-trim “+” dim_tol_setting_13_1)
(vl-string-left-trim “-” dim_tol_setting_13_2)
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
  (if (= (vl-string-left-trim “+” dim_tol_setting_14_1)
(vl-string-left-trim “-” dim_tol_setting_14_2)
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
  (if (= (vl-string-left-trim “+” dim_tol_setting_15_1)
(vl-string-left-trim “-” dim_tol_setting_15_2)
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
  (if (= (vl-string-left-trim “+” dim_tol_setting_16_1)
(vl-string-left-trim “-” dim_tol_setting_16_2)
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
  (if (= (vl-string-left-trim “+” dim_tol_setting_17_1)
(vl-string-left-trim “-” dim_tol_setting_17_2)
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
  (if (= (vl-string-left-trim “+” dim_tol_setting_18_1)
(vl-string-left-trim “-” dim_tol_setting_18_2)
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
  (if (= (vl-string-left-trim “+” dim_tol_setting_19_1)
(vl-string-left-trim “-” dim_tol_setting_19_2)
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
  (if (= (vl-string-left-trim “+” dim_tol_setting_20_1)
(vl-string-left-trim “-” dim_tol_setting_20_2)
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
  (if (= (vl-string-left-trim “+” dim_tol_setting_21_1)
(vl-string-left-trim “-” dim_tol_setting_21_2)
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
    (setq dim_tol_data
   (append
     dim_tol_data
     (list
       (strcat
  (setq dim_tol_data
(list dim_tol_setting_22
       dim_tol_setting_23
       dim_tol_setting_24
       dim_tol_setting_25
       dim_tol_setting_26
       (strcat dim_tol_setting_27
       (rtos dim_tol_setting_28)
(defun dim_tol_data_setting_dcl3 (/
  p
  dim_tol_data_text
  dim_tol_data_text_1
  dim_tol_data_text_2
  (setq dim_tol_data_text
(GET_TILE
   (rtos dim_tol_setting_code)
   “_1”
  (if (/= (wcmatch (substr dim_tol_data_text 1 1) “+,-“) nil)
    (setq dim_tol_data_text_1 (substr dim_tol_data_text 2))
    (setq dim_tol_data_text_1 dim_tol_data_text)
  (setq p 1)
  (while (<= p (strlen dim_tol_data_text_1))
    (setq dim_tol_data_text_2
   (substr dim_tol_data_text_1 p 1)
  p (+ p 1)
    (if (and (= (wcmatch dim_tol_data_text_2 “#”) nil)
     (/= dim_tol_data_text_2 “.”)
      (setq p (+ 2 (strlen dim_tol_data_text_1)))
  (if (= p (+ 2 (strlen dim_tol_data_text_1)))
    (progn
      (alert “입력오류!정확하게 입력하세요”)
      (MODE_TILE
(strcat “dim_tol_setting_” (rtos dim_tol_setting_code) “_1”)
2
    (progn
      (if (= (atof (vl-string-left-trim “+-” dim_tol_data_text)) 0)
(SET_TILE
  “0”
(SET_TILE
  dim_tol_data_text
(defun dim_tol_data_setting_dcl4
  p
  dim_tol_data_text
  dim_tol_data_text_1
  dim_tol_data_text_2
(GET_TILE (strcat “dim_tol_setting_”
   “_2”
  (setq p 1)
  p (+ p 1)
    (progn
      (MODE_TILE
(strcat “dim_tol_setting_” (rtos dim_tol_setting_code) “_2”)
2
    (progn
(SET_TILE
  “0”
(SET_TILE
  dim_tol_data_text
(defun dim_tol_data_setting_dcl5
       (/ p dim_tol_data_text dim_tol_data_text_1)
(GET_TILE
   (strcat “dim_tol_setting_” (rtos dim_tol_setting_code))
  (setq p 1)
  (while (<= p (strlen dim_tol_data_text))
   (substr dim_tol_data_text p 1)
  p (+ p 1)
    (if (and (= (wcmatch dim_tol_data_text_1 “#”) nil)
     (/= dim_tol_data_text_1 “.”)
      (setq p (+ 2 (strlen dim_tol_data_text)))
  (if (= p (+ 2 (strlen dim_tol_data_text)))
    (progn
      (alert “입력오류!숫자만 입력하세요”)
      (MODE_TILE (strcat “dim_tol_setting_” (rtos dim_tol_setting_code))
2
    (progn
      (if (> (atof dim_tol_data_text) 1)
(progn
  (alert “입력오류! 1 이하로 입력하세요”)
  (MODE_TILE
    2
(progn
  (SET_TILE
    dim_tol_data_text
(defun dim_tol_data_setting_dcl6
(GET_TILE
  (setq p 1)
  p (+ p 1)
    (if (= (wcmatch dim_tol_data_text_1 “#”) nil)
    (progn
      (alert “입력오류!정수만 입력하세요”)
2
    (progn
      (SET_TILE (strcat “dim_tol_setting_” (rtos dim_tol_setting_code))
dim_tol_data_text
(defun dim_tol_setting_color (/)
  (if (= dim_tol_setting_27 “1”)
    (progn
      (SET_TILE “dim_tol_setting_27” “1”)
      (MODE_TILE “dim_tol_setting_28” 0)
      (MODE_TILE “dim_tol_setting_29” 0)
      (SET_TILE “dim_tol_setting_29” “DTEXT타입에서만 적용”)
      (start_image “dim_tol_setting_28”)
      (setq x (dimx_tile “dim_tol_setting_28”)
    y (dimy_tile “dim_tol_setting_28”)
      (fill_image 0 0 x y dim_tol_setting_28)
      (end_image)
    (progn
      (SET_TILE “dim_tol_setting_27” “0”)
      (SET_TILE “dim_tol_setting_29” “”)
      (MODE_TILE “dim_tol_setting_29” 1)
      (fill_image 0 0 x y -15)
      (end_image)
      (MODE_TILE “dim_tol_setting_28” 1)
(defun dim_tol_setting_color1 (/ dim_tol_setting_28_1)
  (setq dim_tol_setting_28_1 dim_tol_setting_28)
  (if (= (SETQ dim_tol_setting_28 (acad_colordlg dim_tol_setting_28))
nil
    (setq dim_tol_setting_28 dim_tol_setting_28_1)
(defun dim_tol_data_setting_dcl_made
       (/ dim_tol_setting_dcl_name_1 dim_tol_setting_dcl_name_2)
  (setq dim_tol_setting_dcl_name
(vl-filename-mktemp “dim_tol_setting.dcl”)
(open dim_tol_setting_dcl_name “w”)
(strcat
   “dim_tol_setting : dialog {label=”기본공차 및 환경설정”;
:boxed_row{
:column {
:edit_box{label=”상”;
key=”dim_tol_setting_1_1”;
edit_width=5;
height = 1;
:edit_box{label=”하”;
key=”dim_tol_setting_1_2”;
edit_width=5;
height = 1;
spacer_1;
:column {
:edit_box{
key=”dim_tol_setting_2_1”;
edit_width=5;
height = 1;
:edit_box{
key=”dim_tol_setting_2_2”;
edit_width=5;
height = 1;
spacer_1;
:column {
:edit_box{
key=”dim_tol_setting_3_1”;
edit_width=5;
height = 1;
:edit_box{
key=”dim_tol_setting_3_2”;
edit_width=5;
height = 1;
spacer_1;
:column {
:edit_box{
key=”dim_tol_setting_4_1”;
edit_width=5;
height = 1;
:edit_box{
key=”dim_tol_setting_4_2”;
edit_width=5;
height = 1;
spacer_1;
:column {
:edit_box{
key=”dim_tol_setting_5_1”;
edit_width=5;
height = 1;
:edit_box{
key=”dim_tol_setting_5_2”;
edit_width=5;
height = 1;
spacer_1;
:column {
:edit_box{
key=”dim_tol_setting_6_1”;
edit_width=5;
height = 1;
:edit_box{
key=”dim_tol_setting_6_2”;
edit_width=5;
height = 1;
spacer_1;
:column {
:edit_box{
key=”dim_tol_setting_7_1”;
edit_width=5;
height = 1;
:edit_box{
key=”dim_tol_setting_7_2”;
edit_width=5;
height = 1;
:boxed_row{
:column {
key=”dim_tol_setting_8_1”;
edit_width=5;
height = 1;
key=”dim_tol_setting_8_2”;
edit_width=5;
height = 1;
spacer_1;
:column {
:edit_box{
key=”dim_tol_setting_9_1”;
edit_width=5;
height = 1;
:edit_box{
key=”dim_tol_setting_9_2”;
edit_width=5;
height = 1;
spacer_1;
:column {
:edit_box{
key=”dim_tol_setting_10_1”;
edit_width=5;
height = 1;
:edit_box{
key=”dim_tol_setting_10_2”;
edit_width=5;
height = 1;
spacer_1;
:column {
:edit_box{
key=”dim_tol_setting_11_1”;
edit_width=5;
height = 1;
:edit_box{
key=”dim_tol_setting_11_2”;
edit_width=5;
height = 1;
spacer_1;
:column {
:edit_box{
key=”dim_tol_setting_12_1”;
edit_width=5;
height = 1;
:edit_box{
key=”dim_tol_setting_12_2”;
edit_width=5;
height = 1;
spacer_1;
:column {
:edit_box{
key=”dim_tol_setting_13_1”;
edit_width=5;
height = 1;
:edit_box{
key=”dim_tol_setting_13_2”;
edit_width=5;
height = 1;
spacer_1;
:column {
:edit_box{
key=”dim_tol_setting_14_1”;
edit_width=5;
height = 1;
:edit_box{
key=”dim_tol_setting_14_2”;
edit_width=5;
height = 1;
:boxed_row{
:column {
key=”dim_tol_setting_15_1”;
edit_width=5;
height = 1;
key=”dim_tol_setting_15_2”;
edit_width=5;
height = 1;
spacer_1;
:column {
:edit_box{
key=”dim_tol_setting_16_1”;
edit_width=5;
height = 1;
:edit_box{
key=”dim_tol_setting_16_2”;
edit_width=5;
height = 1;
spacer_1;
:column {
:edit_box{
key=”dim_tol_setting_17_1”;
edit_width=5;
height = 1;
:edit_box{
key=”dim_tol_setting_17_2”;
edit_width=5;
height = 1;
spacer_1;
:column {
:edit_box{
key=”dim_tol_setting_18_1”;
edit_width=5;
height = 1;
:edit_box{
key=”dim_tol_setting_18_2”;
edit_width=5;
height = 1;
spacer_1;
:column {
:edit_box{
key=”dim_tol_setting_19_1”;
edit_width=5;
height = 1;
:edit_box{
key=”dim_tol_setting_19_2”;
edit_width=5;
height = 1;
spacer_1;
:column {
:edit_box{
key=”dim_tol_setting_20_1”;
edit_width=5;
height = 1;
:edit_box{
key=”dim_tol_setting_20_2”;
edit_width=5;
height = 1;
spacer_1;
:column {
:edit_box{
key=”dim_tol_setting_21_1”;
edit_width=5;
height = 1;
:edit_box{
key=”dim_tol_setting_21_2”;
edit_width=5;
height = 1;
:spacer {width=5; height = 1.5;}
:row{
:boxed_column {
:edit_box{label=”상하공차 문자비율(1이하)”;
key=”dim_tol_setting_22”;
edit_width=5;
height = 1;
:edit_box{label=”±공차 문자비율(1이하)”;
key=”dim_tol_setting_23”;
edit_width=5;
height = 1;
:edit_box{label=”치수와공차간 간격”;
key=”dim_tol_setting_24”;
edit_width=5;
height = 1;
:edit_box{label=”공차문자 장평비율(1이하)”;
key=”dim_tol_setting_25”;
edit_width=5;
height = 1;
:spacer {width=5; height = 1;}
:boxed_column {
:spacer {width=1; height = 1;}
: toggle {
label = ”공차0에 + -표시하기”;
key = ”dim_tol_setting_26”;
:row {
: toggle {
label = ”공차에 색상적용”;
key = ”dim_tol_setting_27”;
: image_button {
key = ”dim_tol_setting_28”;
color = -15;
width = 5;
height = 2;
: text {label = ”DTEXT타입에서만 적용”;
key = ”dim_tol_setting_29”;
is_bold = true;
width = 30;
height = 1;
alignment = centered;
spacer_1;
ok_cancel;
  (write-line
  (close dim_tol_setting_dcl_name_1)
  (dim_tol_data_setting_dcl)
  (if (= dim_tol_data_setting_ok 1)
    (progn
      (dim_tol_data_setting_dcl2)
  • 74 조회
    2. 캐드플러스 Lv.18
      2020-07-13T19:10:03+09:00답변 등록 답변 등록 일시 2020-07-13 7:10 pm
      이프로그램은 만든 프로그래머에게 문의하는것이 좋을듯 합니다.
      그리고 아래 블로그 주소는 제가 만든 프로그램입니다.
      유료 프로그램인데 코로나 19버전으로 2021년 6월 까지 모든 기능을 사용할수 있습니다.
      치수선을 선택 또는 그릴수 있고 공차 등급만 선택하면 됩니다.
      사용자 입력도 가능합니다.
      http://blog.daum.net/cadplus/7
