홈/ 질문/Q 78057
등록일: 2008-10-132008-10-13T18:05:37+09:00 2008-10-13T18:05:37+09:00카테고리: AutoCAD & CADian
구름마크 리습을 쓰고나면 OSNAP이 다 풀려요…….도와주세요..
(defun c:revc (/ ds plw pt1 pt2 p1 p2 xdist ydist spcsx spcsy ent1 ent2 nxt info bulge data c_o c_l)
 (print “>> Cloud Draw Tool…”)
              (setq c_o (getvar “osmode”))
 (setvar “cmdecho” 0)
 (setvar “osmode” 0)
              (setq c_l (getvar “clayer”)) ;<= 현재 레이어값을 저장한다.
              (setq ly (tblsearch “layer” “Revision”)) ;”레이어를 검색 없으면 레이어 생성
              (if (= ly nil) (command “layer” “n” “Revision” “”))
              (setvar “clayer” “Revision”) ;<= 현재 레이어를 변경한다.
  (setq ds (getvar “dimscale”)
  plw (* 0.02 ds)
  oer *error*
  bm (getvar “blipmode”))
 (setq   ds (* 30 ds))
 (print)                                            ; ————> circle size
 (setq str (strcat “호 지름<” (rtos ds 2) “> : “))
 (setq  buf (getint str))
 (if (/= buf NIL) (setq ds buf))
 (defun *error* (s)      ;start error routine
  (setvar “blipmode” bm)     ;reset blipmode
  (princ (strcat “Exit…” s))    ;type error message
  (if oer (setq *error* oer))
  (princ))
 (print)
 (SETQ PT1 (GETPOINT “영역의 좌측 하단점: “)) (terpri)
 (setq pt2 (getcorner pt1 “영역의 우측 상단점: “))
 (setvar “blipmode” 0)
 (setq p1 (car pt1) p2 (car pt2)    ;find x distances
  xdist (- p2 p1))
 (setq  p1 (cadr pt1) p2 (cadr pt2)    ;find y distances
  ydist (- p2 p1))
;******TO ADJUST SPACING OF ARCS CHANGE THE NUMBER 2 IN THE NEXT TWO LINES*****
 (setq spcsx (/ (abs xdist) (/ ds 2))    ;X spacing
  spcsy (/ (abs ydist) (/ ds 2)))    ;Y spacing
 (if (= spcsx (fix spcsx)) (setq spcsx (fix spcsx)) (setq spcsx (+ 1 (fix spcsx))))
 (if (= spcsx 1) (setq spcsx 2))     ;min of 2 spaces
 (if (= spcsy (fix spcsy)) (setq spcsy (fix spcsy)) (setq spcsy (+ 1 (fix spcsy))))
 (if (= spcsy 1) (setq spcsy 2))     ;min of 2 spaces
 (setq xdist (/ xdist spcsx) ydist (/ ydist spcsy))  ;set distances
 (setq p1 pt1)       ;set polyline start point
 (command “PLINE” p1 “W” “0” “”)     ;start polyline command
 (repeat spcsx       ;draw bottom line segments
  (setq p1 (polar p1 0.0 (abs xdist)))
  (command p1))
 (repeat spcsy       ;draw right line segments
  (setq p1 (polar p1 (/ pi 2) (abs ydist)))
  (command p1))
 (repeat spcsx       ;draw top line segments
  (setq p1 (polar p1 pi (abs xdist)))
  (command p1))
 (repeat (- spcsy 1)      ;draw left line segments
  (setq p1 (polar p1 (* pi 1.5) (abs ydist)))
  (command p1))
 (command “C”)       ;Close polyline
 (setq ent1 (entlast)      ;get entity
  ent2 (entget ent1)     ;get entity info
;******TO ADJUST THE ARC SIZE ADJUST THE 0.5 BELOW*******
  bulge (list (cons 42 0.5))    ;build cloud arcs   0.5
  nxt (cdr (assoc -1 ent2))    ;set for lookup
  nxt (entnext nxt)     ;get next one
  plw (list (cons 41 plw)))    ;build cloud width
 (if (= nxt nil)
  (progn
   (setq ent2 (subst (cons 42 0.5) (assoc 42 ent2) ent2))
   (entmod ent2)       ;modify entity
  (while nxt       ;start loop
   (setq info (entget nxt)    ;get exist. info
    info (append info bulge)   ;set bulge
    info (append info plw)    ;set width
   )       ;end of setq
   (entmod info)       ;modify entity
   (setq nxt (entnext nxt))    ;get next segment
  )        ;end of while
 (entupd ent1)       ;update entity
 (setvar “cmdecho” 1)      ;turn command echo on
              (setvar “osmode” c_o)
              (setvar “clayer” c_l) ;<= 저장된 값으로 현재 레이어를 변경한다.
 (gc) (princ)       ;print blank line
)          ;End program
여기서 구한 구름마크 리습을 쓰고 있습니다…
근데 쓰고나면 OSNAP설정이 다 풀려버려요…제발~~어떻게 해야하나요??!!
글구 색깔도 “1”번으로 바꾸고 싶은데….그것도..좀 갈켜주세요…
제가 리습을 완전 초짜초짜!!! 이거든요……
  • 34 조회
      2008-10-13T18:52:43+09:00답변 등록 답변 등록 일시 2008-10-13 6:52 pm
      오스냅은 다 살리면 됩니까……쓰시는게 따로 있는지요…//
    3. 게릴라어니 Lv.0
      2008-10-13T19:35:55+09:00답변 등록 답변 등록 일시 2008-10-13 7:35 pm
      위쪽에..setvar “osmode” 0  =>  setvar “osmode” c_o 으로 고쳐보세요.
