홈/ 질문/Q 88823
등록일: 2010-09-082010-09-08T15:32:49+09:00 2010-09-08T15:32:49+09:00카테고리: AutoCAD & CADian
구름마크 리습 (캠퍼스)
캐드 2009에 캠퍼스랑 옛날 프로그램을 깔았는데
구름마크가 없는 시절에 만든프로그램이라
지금 구름마크랑 충돌이 나서 구름그리기를 쓸수가없내요 ㅜㅡ
이 리습을 지우면 프로그램에서 리습찾아내라고 난리고 ㅜㅡ
방법이없나요.
그냥 리습 내용을
REVCLOUD 란 명령어만 입력하게 하면 될거같은데 ㅜㅡ
캠퍼스란 프로그램에서 리습은
;;;     REVCLOUD.LSP
;;;     Copyright (C) 1997 by Autodesk, Inc.
;;;     Permission to use, copy, modify, and distribute this software
;;;     for any purpose and without fee is hereby granted, provided
;;;     that the above copyright notice appears in all copies and
;;;     that both that copyright notice and the limited warranty and
;;;     restricted rights notice below appear in all supporting
;;;     documentation.
;;;     AUTODESK PROVIDES THIS PROGRAM “AS IS” AND WITH ALL FAULTS.
;;;     AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
;;;     MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE.  AUTODESK, INC.
;;;     DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
;;;     UNINTERRUPTED OR ERROR FREE.
;;;     Use, duplication, or disclosure by the U.S. Government is subject to
;;;     restrictions set forth in FAR 52.227-19 (Commercial Computer
;;;     Software – Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
;;;     (Rights in Technical Data and Computer Software), as applicable.
;;;     Last revision 3/14/97 1:28 PM Greg Robinson
;;;     Credits: Original Code, idea and concept by David Harrington
;;;              Bill Kramer, Q.C.
;;;              Phil Kreiker, Q.C.
;;;              Dominic Panholzer, Q.C.
;;;              Randy Kinsley, Error Control
;;;              Greg Robinson
(Defun C:REVCLOUD (/
     ARC_DIST   ;;radius of included arc
     INC_ANGLE  ;;included angle in degrees
     LAST_PT    ;;the last point just entered/shown
     START_PT   ;;where the cloud began
     NEXT_PT    ;;where we are going next
     TMP        ;;tempory holder for radius of bulge
   (init_bonus_error
      (List
         (List “cmdecho” 0
               “blipmode” 0
               “osmode” 0
         T     ;flag. True means use undo for error clean up.
      ) ;list
   ) ;init_bonus_error
   ;;——–real program starts here!
   (Setq INC_ANGLE 110)
   (if (and
         (/= “”  (getcfg “AppData/AC_Bonus/Revcld_Bulge”))
         (/= nil (getcfg “AppData/AC_Bonus/Revcld_Bulge”))
     (setq ARC_DIST (atof (getcfg “AppData/AC_Bonus/Revcld_Bulge”)))
     (if (= (getvar “DIMSCALE”) 0)
       (setq ARC_DIST 0.375)
       (setq ARC_DIST (* 0.375 (getvar “DIMSCALE”)))
   );end if
   (prompt (strcat “nArc length set at ” (rtos ARC_DIST 2 3)))
   (initget “Arc”)
   (setq LAST_PT (GetPoint “nArc length/<Pick cloud starting point>: “))
   (if (= LAST_PT “Arc”)
     (progn
       (initget 6)
       (setq TMP (getdist (strcat “nArc length <” (rtos ARC_DIST 2 3) “>: “)))
       (if TMP
         (Progn
           (setq ARC_DIST TMP)
                ;R14 method of saving variable values
           (setcfg “AppData/AC_Bonus/Revcld_Bulge” (rtos ARC_DIST))
       (setq LAST_PT (getpoint “nPick cloud start point: “))
     ) ;;end STR “RADIUS” test
   (if LAST_PT (progn  ;;start up the cloud generator…
     (setq START_PT LAST_PT
           SAVED_EN (entlast))
     (Prompt “nGuide crosshairs along cloud path…”)
     (Command
        “_.pline”     ;draw cloud as a polyline on current layer
        LAST_PT
        “_a”         ;specify arc option
        “_a”         ;specify angle option
        INC_ANGLE    ;included angle
   )) ;end IF LAST_PT
   (While LAST_PT  ;;as long as we have a last point value,
      (Setq NEXT_PT (GrRead 1)     ;;real time read
            READTYP (car NEXT_PT)
      (if (or (=  5 READTYP) (= READTYP 3)) ;;read a position or a pick?
         (progn
           (setq NEXT_PT (cadr NEXT_PT))
           (If (or (> (Distance LAST_PT NEXT_PT) ARC_DIST) (= READTYP 3))
             (Progn
               (Command NEXT_PT “_a” INC_ANGLE)
               (Setq LAST_PT NEXT_PT)
           (If (>
               (Distance START_PT NEXT_PT)
             (Progn
               (Command START_PT “_cl”)
               (Setq LAST_PT Nil)
               (prompt “nCloud finished.”)
         (prompt “nMove the pointer to draw the cloud”)
      );End if
   );End while
   (restore_old_error)
   (Princ)
) ;end cloud.lsp
(Defun c:RCHELP (/)
(prompt ”   The Revision Cloud program draws a user specified bulge plinen”)
(prompt ”   along the path of the crosshairs. To close the cloud, n”)
(prompt ”   simply return to the starting pointn”)
(prompt ”   The cloud arc length can be specified in the beginning, with keyboard inputn”)
(prompt ”   by specifying A for Arc, entering a length, or picking two pts.n”)
(textscr)
(Prompt ”   REVCLOUD loaded. Type REVCLOUD to draw Revision Cloud,n”)
(prompt ”   to close, return to starting point. For additional Help – RCHELP”)
(Princ)
  • 70 조회
      2012-10-29T23:32:03+09:00답변 등록 답변 등록 일시 2012-10-29 11:32 pm
      CADian 기반의 캠퍼스를 설치하면 잘 구동됩니다.  기능 추가도 가능합니다
      http://www.cadian.com/download/value_content.asp?idx=52 다운로드
      * 캐디안 사용자는 무료 다운하여 사용할 수 있습니다
