홈/ 질문/Q 113677
등록일: 2022-03-112022-03-11T14:58:24+09:00 2022-03-11T14:58:24+09:00카테고리: AutoCAD & CADian
기존에 잘 사용하던 리습인데 수정을 조금 했는데 수정을 조금했더니 명령어가 안먹혀서 문의 드립니다.
명령어 66을 입력을하면 layer이 기본적으로 만들어지고
dimstyle 까지 설정되게하는 lisp 이었습니다.
어딜 잘못 건드렸는지 명령어가 안먹혀서 문의드립니다.
(defun c:66() (COMMAND “LAYER”
          “m” “10” “c” “150” “” “Lt” “Continuous” “”
          “m” “11” “c” “161” “” “Lt” “Continuous” “”
          “m” “12” “c” “115” “” “Lt” “Continuous” “”
          “m” “13” “c” “180” “” “Lt” “Continuous” “”
          “m” “14” “c” “190” “” “Lt” “Continuous” “”
          “m” “15” “c” “221” “” “Lt” “Continuous” “”
          “m” “16” “c” “30” “” “Lt” “Continuous” “”
          “m” “17” “c” “141” “” “Lt” “Continuous” “”
          “m” “18” “c” “211” “” “Lt” “Continuous” “”
          “m” “19” “c” “217” “” “Lt” “Continuous” “”
          “m” “20” “c” “165” “” “Lt” “Continuous” “”
          “m” “9” “c” “85” “” “Lt” “Continuous” “”
          “m” “8” “c” 15″ “” “Lt” “Continuous” “”
          “m” “7” “c” “41” “” “Lt” “Continuous” “”
          “m” “6” “c” “6” “” “Lt” “Continuous” “”
          “m” “5” “c” “5” “” “Lt” “Continuous” “”
          “m” “4” “c” “4” “” “Lt” “phantom” “”
          “m” “3” “c” “3” “” “Lt” “hidden” “”
          “m” “2” “c” “1” “” “Lt” “center” “”
          “m” “1” “c” “6” “” “Lt” “Continuous” “”
          “m” “0” “c” “7” “” “Lt” “Continuous” “” “s” “0” “”)
   (command   “dimstyle”  “s” “sh” “y”)
   (command   “dimasz”  “2.5”)
   (command   “dimclrd” “6”)
   (command   “dimclrt” “3”)
   (command   “dimclre” “6”)
   (command   “dimexe”  “1”)
   (command   “dimexo”  “1”)
   (command   “dimtmove”  “0”)
   (command   “dimdli”  “7”)
   (command   “dimdec”  “8”)
   (command   “dimadec” “1”)
   (command   “dimdsep” “.”)
   (command   “dimgap”  “1”)
   (command   “dimtad”  “1”)
   (command   “dimzin”  “8”)
   (command   “dimazin”  “2”)
   (command   “dimtih”  “0”)
   (command   “dimtofl” “1”)
   (command   “dimtix”  “1”)
   (command   “dimtxt”  “2.5”)
   (command  “style”   “whgtxt”  “romans,whgtxt”  “0”       “1.0”       “”        “”        “”        “”)
   (command   “dimtxsty” “whgtxt” )
   (command   “LAYER” “S” “0” “”)
  • 61 조회
      2022-03-11T17:16:32+09:00답변 등록 답변 등록 일시 2022-03-11 5:16 pm
      헐… 감사합니다… 해결되었습니다.
