홈/ 질문/Q 113664
붉은다라이
붉은다라이Lv.0
등록일: 2022-03-012022-03-01T17:12:44+09:00 2022-03-01T17:12:44+09:00카테고리: AutoCAD & CADian
길이합산리습인데 WIN11 캐드버전을 2017에서 안되서 수정부탁드립니다.
; 총길이갯수와 중복객체 (  ) 추가합니다.
(defun c:fv (/ ss sslist i index linelist linenumlist ent old10 old11 dist lnum count temp total total1 subtotal txt pt)
  (vl-load-com)
  (princ "n Eltity Length Sum")
  (setvar "cmdecho" 0)
  (setq ss (ssget (list (cons 0 "LINE,CIRCLE,ARC,POLYLINE,LWPOLYLINE,ELLIPSE,SPLINE"))))
  (setq zzz (sslength ss))
  (if ss
    (progn
      (setq index 0)
      (setq linelist nil)
      (setq linenumlist nil)
      (repeat (sslength ss)
        (setq ent (ssname ss index))
        (command "lengthen" ent "")
        (setq dist (GETVAR "PERIMETER"))
        (if (apply 'or (mapcar '(lambda (x) (equal dist x 1)) linelist))
          (progn
            (setq temp 0)
            (setq lnum nil)
            (foreach x linelist
              (if (equal dist x 1)
                (setq lnum temp)
              (setq temp (1+ temp))
            (setq count 0)
            (setq temp nil)
            (foreach x linenumlist
              (if (= count lnum)
                (setq temp (append temp (list (+ x 1))))
                (setq temp (append temp (list x)))
              (setq count (1+ count))
            (setq linenumlist temp)
          (progn
            (setq linelist (append linelist (list dist)))
            (setq linenumlist (append linenumlist (list 1)))
        (setq index (1+ index))
      (setq txt "")
      (setq count 0)
      (setq total 0)
      (setq subtotal 0)
      (repeat (length linelist)
        (if (= count 0)
          (if (> (nth count linenumlist) 1)
            ;;;;(setq txt (strcat "nL = " (rtos (/ (nth count linelist) 1.0) 2 2) "*" (rtos (nth count linenumlist) 2 0) "개"))
            ;;;;(setq txt  (strcat "nL = " (rtos (/ (nth count linelist) 1.0) 2 2)))
            (setq txt (strcat "nL=" "(" (rtos (/ (nth count linelist) 1000.0) 2 2) "*" (rtos (nth count linenumlist) 2 0) ")"))
            (setq txt  (strcat "nL=" (rtos (/ (nth count linelist) 1000.0) 2 2)))
            ;;;;(setq txt (strcat txt " + " (rtos (/ (nth count linelist) 1.0) 2 2) "*" (rtos (nth count linenumlist) 2 0) "개"))
            ;;;;(setq txt (strcat txt " + " (rtos (/ (nth count linelist) 1.0) 2 2)))
            (setq txt (strcat txt "+" "(" (rtos (/ (nth count linelist) 1000.0) 2 2) "*" (rtos (nth count linenumlist) 2 0) ")"))
            (setq txt (strcat txt "+" (rtos (/ (nth count linelist) 1000.0) 2 2)))
        (setq subtotal (* (/ (nth count linelist) 1) (nth count linenumlist)))
        (setq total (+ subtotal total))
        (setq total1 (/ total 1000))
      (setq txt (strcat txt "=" (rtos total1 2 2) "m"))
      (setq txt (strcat txt " : 총객체수 " (rtos zzz 2 0) "개"))
      (princ txt)
(if (not (setq tth (getreal (strcat "n현재 TextSize : <" (rtos(getvar "textsize") 2 1) "> 입니다. 원하는 Text 크기를 입력하세요 : "))))
    (setq tth (getvar "textsize"))
    (setvar "textsize" tth)
      (setq pt (getpoint "n 텍스트 삽입점 : "))
      (if pt (command "text" pt "" "" txt))
  • 64 조회
    2. 붉은다라이 Lv.0
      2022-03-02T15:31:23+09:00답변 등록 답변 등록 일시 2022-03-02 3:31 pm
      잘됩니다 많이 쓰는리습인데  상큼메론90님 정말 감사합니다 최고^^
