홈/ 질문/Q 107133
목동이
목동이Lv.2
등록일: 2016-08-242016-08-24T11:08:10+09:00 2016-08-24T11:08:10+09:00카테고리: AutoCAD & CADian
리습(Lisp)글자크기 조절 관련하여 질문 드립니다.
아이소 치수  리습인데요 현재 글자 크기가 2로 나오는데~~~
크기를 2.5로 변경 하고 싶은데 메모장에서 어떤 부분을 수정해야 할지 잘 모르겠어요
고수님들 부탁드려욤~~
;**Error**Cancle**
(defun gerr (g)
    (if (/= g “Function cancelled”)
        (princ (strcat “nError:” g))
    (setvar “cmdecho” 1)
    (command”pickbox” “4” “”)
    (SETVAR “CLAYER” “PIPE”)
(defun ddimen(/ pt1 pt2 pt3 pt4 pt5 pt6 pt7 pt8 pt9 pt10 ang t_ang g_ang l_dist t_dist str)
    ;(setiso1)
    (setvar “osmode” 33)
    (setq ds (getvar “dimscale”))
    (setq cor_sty (getvar “textstyle”))
    (command “layer” “s” “dim” “”)
    (if (/= dwgtype “D”)
        (command “layer” “f” “dim” “”)
    (setq pt1 (getpoint “nPick iso 치수보조선 시작 point : “)
    ;(if *error* (setq *error* gerr))
          pt2 (getpoint “nPick iso 치수보조선 끝난 point : ” pt1)
          pt3 (getpoint “nPick iso 치수선 position : ” pt2)
          ang (angle pt1 pt2)        ; dimension line angle
          t_ang (angle pt2 pt3)      ; text style angle
          g_ang (angtos ang)         ; function angle
          l_dist (distance pt1 pt2)  ; dimension line distance
          t_dist (* 15 ds)          ; dimension line distance
       pt3 (polar pt1 t_ang t_dist)
       pt4 (polar pt2 t_ang t_dist)
       pt5 (polar pt3 ang (/ (distance pt1 pt2) 3))
       pt7 (polar pt3 t_ang (* 1 ds))
       pt8 (polar pt4 t_ang (* 1 ds))
       pt9 (polar pt1 t_ang (* 1 ds))
       pt10(polar pt2 t_ang (* 1 ds))
       str (getstring “nInput 숫자입력 : “)
    (if (or (and (>= (rtd ang) 61) (<= (rtd ang) 120))
            (and (>= (rtd ang) 241) (<= (rtd ang) 300))
            (setq pt6 (polar pt5 (dtr 210) (* 1.4 ds)))
            (setq pt6 (polar pt5 (dtr 90) (* 1.4 ds)))
    (setvar “osmode” 0)
    (command “line” pt9 pt7 “”)
    (command “line” pt3 pt4 “”)
    (command “line” pt10 pt8 “”)
    (daa pt3 ang)
    (daa pt4 (+ ang (dtr 180)))
    (i_t pt6 ang str)
    (setq q_con (strcase (getstring “n연속 치수기입? < Yes / No > : “)))
    (if (= q_con “N”)(setq jhg nil)(setq jhg 7))
    (while jhg
        (setq pt1 pt2)
        (setq pt2 (getpoint “nPick iso 치수보조선 끝난 point : ” pt1))
        (if (= pt2 nil)
            (setq jhg nil)
            (progn
                (setq pt3 (getpoint “nPick iso 치수선 position : ” pt2)
                       t_dist (* 15 DS)          ; dimension line distance
                       pt7 (polar pt3 t_ang (* 1 DS))
                       pt8 (polar pt4 t_ang (* 1 DS))
                       pt9 (polar pt1 t_ang (* 1 DS))
                       pt10(polar pt2 t_ang (* 1 DS))
                      (setq pt6 (polar pt5 (dtr 210) (* 1.4 DS)))
                      (setq pt6 (polar pt5 (dtr 90) (* 1.4 DS)))
                (setvar “osmode” 0)
                (daa pt3 ang)
                (i_t pt6 ang str)
       (command “layer” “t” “ghkiso” “”)
    (setvar “textstyle” cor_sty)
    (setiso2)
    (prin1)
(defun i_t(g_pt g_ang g_str)
    (if (= text-type 2)
        (progn
            (if (not (tblsearch “style” “Text1”))
                (progn
                    (SETVAR “CECOLOR” “bylayer”)
                    (command “filedia” “0”)
                    (command “style” “Text1” “romans” “” “0.9” “30” “” “” “”)
                    (command “filedia” “1”)
            (if (not (tblsearch “style” “Text2”))
                (progn
                    (command “style” “Text2” “romans” “” “0.9” “-30” “” “” “”)
 (cond
    ((and (>= (rtd g_ang) 15) (<= (rtd g_ang) 60))
        (if (= text-type 2)
            (if (or (and (>= (rtd t_ang) 61) (<= (rtd t_ang) 120)) (and (>=  (rtd t_ang) 241) (<= (rtd t_ang) 300)))
                (setvar “textstyle” “Text1”)
                (setvar “textstyle” “Text2”)
             (setvar “textstyle” “dim”)
        ;(SETVAR “CECOLOR” “7”)
        (command “text” “c” g_pt (* txt-dh ds) “30” g_str)
    ((and (>= (rtd g_ang) 61) (<= (rtd g_ang) 120))
        (if (= text-type 2)
            (if (or (and (>= (rtd t_ang) 15) (<= (rtd t_ang) 60)) (and (>= (rtd t_ang) 181) (<= (rtd t_ang) 240)))
         (command “text” “c” g_pt (* txt-dh ds) “90” g_str)
     ((and (>= (rtd g_ang) 121) (<= (rtd g_ang) 180))
        (if (= text-type 2)
        (command “text” “c” g_pt (* txt-dh ds) “330” g_str)
     ((and (>= (rtd g_ang) 181) (<= (rtd g_ang) 240))
        (if (= text-type 2)
     ((and (>= (rtd g_ang) 241) (<= (rtd g_ang) 300))
        (if (= text-type 2)
     ((and (>= (rtd g_ang) 301) (<= (rtd g_ang) 360))
        (if (= text-type 2)
(SETVAR “CECOLOR” “BYLAYER”)
(defun daa (g_pt g_ang / pt3 pt4)
 (setq as (* 0.4 ds);;arrow hight
       pt21  (polar g_pt g_ang (* 3 ds));;arrow length
       ;pt21  (polar g_pt g_ang (* 2.5 s));;arrow length(화살표길이)
       g_ang (angtos g_ang)
 (setq pt3 (polar pt21 t_ang  as)
       pt4 (polar pt21 (+ t_ang (dtr 180)) as)
 (command “solid” g_pt pt4 pt3 “” “”)
(defun dimen1(/ n-len i sel l en el text pt1 pt2 pt3 pt4 pt5 pt6
    (setiso1)
    (setq n-len 0)
    (setq i 0)
    (setq sel(ssget))
    (setq l(sslength sel))
    (repeat l
        (setq en(ssname sel i))
        (setq el (entget en))
        (if (= “TEXT” (cdr (assoc 0 el)))
            (progn
                (setq text (cdr (assoc 1 el)))
                (setq n-len(+ n-len (atof text)))
                (setq i(+ 1 i))
    (setq n-len(rtos n-len 3 0))
        (command “layer” “f” “ghkiso” “”)
    (setq pt1 (getpoint “nPick iso dimension start point : “)
          pt2 (getpoint “nPick iso dimension end point : ” pt1)
          pt3 (getpoint “nPick iso dimension line position : ” pt2)
    )    (setvar “osmode” 0)
    (daa pt3 ang)
    (i_t pt6 ang n-len)
       (command “layer” “t” “dim” “”)
    (setiso2)
    (prin1)
  • 97 조회
      2016-08-24T16:50:21+09:00답변 등록 답변 등록 일시 2016-08-24 4:50 pm
      (command “text” ….    구간 보시면
      (* txt-dh ds)
      이놈이 글자 크기 입니다.
      변수상.. txt-dh   ds  가져오는 구간이 없는것으로 봐선 다른 서브 리습이 있을거 같군요..
      (* (* txt-dh ds) 1.25)  이렇게 바꾸면 될듯 한데…
      테스트가 안될게 뻔해서..
      답변만 남겨봅니다…
      될까요?
    3. 목동이 Lv.2
      2016-08-25T08:24:06+09:00답변 등록 답변 등록 일시 2016-08-25 8:24 am
      정말 신기하게도~~~
      글자 크기가 2.5가 되네요~~ 감사 감사
      만약에 글자크기를 3으로 하고 싶다면??
      (* (* txt-dh ds) 1.3)하면 맞나요??
      2016-08-25T12:12:27+09:00답변 등록 답변 등록 일시 2016-08-25 12:12 pm
      1.5 아닌가요?
      2가 된다고 하셨으니,
      1.5 배하면 3 이되겠죠
