홈/ 질문/Q 104591
등록일: 2015-07-132015-07-13T14:43:08+09:00 2015-07-13T14:43:08+09:00카테고리: AutoCAD & CADian
면접 합계를 계산식으로 표기
아래 리습은 길이 합계를 계산식으로 표기될수 있게해주는 리습입니다만
면적 합계를 계산식으로 표기하고 싶습니다 ㅠ 도움 부탁드립니다.
(defun c:MM (/ ss sslist i index linelist linenumlist ent old10 old11 dist lnum count temp total total1 subtotal txt pt)
  (vl-load-com)        ;—->total1 추가함
  (princ “n Eltity Length Sum”)
  (setvar “cmdecho” 0)
  (setq ss (ssget (list (cons 0 “LINE,CIRCLE,ARC,POLYLINE,LWPOLYLINE,ELLIPSE,SPLINE”))))
  (setq zzz (sslength ss))
  (if ss
    (progn
      (setq index 0)
      (setq linelist nil)
      (setq linenumlist nil)
      (repeat (sslength ss)
        (setq ent (ssname ss index))
        (command “lengthen” ent “”)
        (setq dist (GETVAR “PERIMETER”))
        (if (apply ‘or (mapcar ‘(lambda (x) (equal dist x 1)) linelist))
          (progn
            (setq temp 0)
            (setq lnum nil)
            (foreach x linelist
              (if (equal dist x 1)
                (setq lnum temp)
              (setq temp (1+ temp))
            (setq count 0)
            (setq temp nil)
            (foreach x linenumlist
              (if (= count lnum)
                (setq temp (append temp (list (+ x 1))))
                (setq temp (append temp (list x)))
              (setq count (1+ count))
            (setq linenumlist temp)
          (progn
            (setq linelist (append linelist (list dist)))
            (setq linenumlist (append linenumlist (list 1)))
        (setq index (1+ index))
      (setq txt “”)
      (setq count 0)
      (setq total 0)
      (setq subtotal 0)
      (repeat (length linelist)
        (if (= count 0)
          (if (> (nth count linenumlist) 1)
            ;;;;(setq txt (strcat “nL = ” (rtos (/ (nth count linelist) 1.0) 2 2) “*” (rtos (nth count linenumlist) 2 0) “개”))
            ;;;;(setq txt  (strcat “nL = ” (rtos (/ (nth count linelist) 1.0) 2 2)))
            (setq txt (strcat “nL = ” (rtos (/ (nth count linelist) 1000.0) 2 2) “*” (rtos (nth count linenumlist) 2 0) “개”))
            (setq txt  (strcat “nL = ” (rtos (/ (nth count linelist) 1000.0) 2 2)))
            ;;;;(setq txt (strcat txt ” + ” (rtos (/ (nth count linelist) 1.0) 2 2) “*” (rtos (nth count linenumlist) 2 0) “개”))
            ;;;;(setq txt (strcat txt ” + ” (rtos (/ (nth count linelist) 1.0) 2 2)))
            (setq txt (strcat txt ” + ” (rtos (/ (nth count linelist) 1000.0) 2 2) “*” (rtos (nth count linenumlist) 2 0) “개”))
            (setq txt (strcat txt ” + ” (rtos (/ (nth count linelist) 1000.0) 2 2)))
        (setq subtotal (* (/ (nth count linelist) 1) (nth count linenumlist)))
        (setq total (+ subtotal total))
        (setq total1 (/ total 1000));————->추가함
      ;;;;(setq txt (strcat txt ” = ” (rtos total 2 2) “m”))
      (setq txt (strcat txt ” = ” (rtos total1 2 2) “m”));——->total에서 total1 변경함
      (setq txt (strcat txt ” : 객체수 ” (rtos zzz 2 0) ” 개”))
      (princ txt)
(if (not (setq tth (getreal (strcat “n현재 TextSize : <” (rtos(getvar “textsize”) 2 1) “> 입니다. 원하는 Text 크기를 입력하세요 : “))))
    (setq tth (getvar “textsize”))
    (setvar “textsize” tth)
      (setq pt (getpoint “n 텍스트 삽입점 : “))
      (if pt (command “text” pt “” “” txt))
  • 6 6 답변
  • 121 조회
    6 답변
      2015-07-14T08:45:03+09:00답변 등록 답변 등록 일시 2015-07-14 8:45 am
      네 ㅠㅠ 몇일전에 올렸어요.. 근데 해결점을 못찾아서요.
      상큼메론님이 올려주신 방법으로도 해결이 안되네요 ㅠㅠ…
      2015-07-15T09:51:48+09:00답변 등록 답변 등록 일시 2015-07-15 9:51 am
      감사합니다~^^ 상큼메론 덕분에 해결했습니다 ㅠㅠ
      업무에 큰 도움이 될것같아요~
      정말 감사드려요~
      ^^ 좋은하루되세요
      2015-07-15T14:46:21+09:00답변 등록 답변 등록 일시 2015-07-15 2:46 pm
      도면적에 적용해보니 버그가 생겼습니다 ㅠㅠ
      첨부사진과같이 1번 물량을 인식을 못하더라구요  평균값으로 이상하게 계산을해서 물량이 누락되는 현상이 발생합니다..ㅠㅠ 어디가 문제인지 찾질못하겠더라구요…
      2015-07-16T09:14:02+09:00답변 등록 답변 등록 일시 2015-07-16 9:14 am
      드디어!! 완벽하게 작동됩니다!!!!+_+  정말 감사드려요~~~~~
      행복한 하루되세요 ㅎㅎ
      2018-10-08T16:37:26+09:00답변 등록 답변 등록 일시 2018-10-08 4:37 pm
      안녕하세요 .이거 평으로 출력되게하는거 말구요.m2으로 출력되게 하려면 어떤 부분 수정해야하는지 알수있을까요?
      2018-10-08T17:07:41+09:00답변 등록 답변 등록 일시 2018-10-08 5:07 pm
      (setq distt (/ (getvar “area”) 1.0e+06))
      (setq dist (* distt 0.3025)) ;평으로 환산 M²* 0.3025       <——–이부분 1로 바꾸로
      (setq txt (strcat txt ” = ” (rtos total1 2 2) “평“));——->total에서 total1 변경함    <—이부분 m2으로 출력하게수정했는데여 되긴되는데 이렇게하는거 맞나요??컴퓨터언어는 문외한이라…혼자 1시간 넘게 소스만 보구했는데….각 객체에 대한 면적  ” + ” 이거 사이에 m2 도 프린트 하고싶은데 그건 어캐하는건가요?
