홈/ 질문/Q 102699
등록일: 2014-11-192014-11-19T17:20:47+09:00 2014-11-19T17:20:47+09:00카테고리: AutoCAD & CADian
사칙연산 리습 질문드립니다.
;;program name : 캐드내 사칙연산프로그램 ver 1.1
;;date:2000.06.09
;;program by:kang o nam
;;ID : 하이텔ID(anold88)
;;E-MAIL : anold88@hitel.net
;;         anold88@hanmail.net
(defun exe()
   (setvar “cmdecho” 0)
   (setvar “blipmode” 0)
   (setq cl (getvar “clayer”))
   (setq e1 (entsel “n>>첫번째숫자선택:”))
   (setq a (car e1);;———-엔티티의 이름값
         b (entget a);;——–엔티티의 리스트값
         txt1 (assoc 1 b);;—-엔티티중 해당 문자열 리스트
         tt1 (cdr txt1);;——엔티티 문자열의 리스트중 뒤의값=”문자열”
         sum1 (atof tt1);;—–엔티티의 문자열을 정수로 변환=100
         txth1 (assoc 40 b);;–엔티티 리스트중 텍스트 높이의 리스트값(40,100)
         thh (cdr txth1);;—–엔티티의 텍스트높이의 리스트중 뒤의값=100
   (setq e2 (entsel “n>>두번째숫자선택:”))
   (setq aa (car e2)
         bb (entget aa)
         txt2 (assoc 1 bb)
         tt2 (cdr txt2)
         sum2 (atof tt2)
    (setq tl (assoc 8 b)
          txtst (cdr tl)
 (defun exe+()
    (setq sum (+ sum1 sum2))
    (setq summ (rtos sum 2 4))
    (setq p1 (getpoint “n>>표시할 포인트찍기:”))
;;    (command “layer” “s” “tex” “” “”);;—————->> 사용자 선택레이어조정란!!
    (command “text” p1 thh 0 summ)
    (command “layer” “s” cl “”)
 (defun exe-()
    (setq sum (- sum1 sum2))
 (defun exe*()
    (setq sum (* sum1 sum2))
 (defun exe/()
    (setq sum (/ sum1 sum2))
 (defun exe%()
    (setq sum (* (/ sum1 sum2) 100))
(defun c:0( / cl e1 a b txt1 tt1 sum1 txth1 thh e2 aa bb txt2 tt2 sum2 tl txtst sum summ p1)
  (exe)
  (exe+)
(defun c:-( / cl e1 a b txt1 tt1 sum1 txth1 thh e2 aa bb txt2 tt2 sum2 tl txtst sum summ p1)
   (exe)
   (exe-)
(defun c:/( / cl e1 a b txt1 tt1 sum1 txth1 thh e2 aa bb txt2 tt2 sum2 tl txtst sum summ p1)
  (exe)
  (exe/)
(defun c:%( / cl e1 a b txt1 tt1 sum1 txth1 thh e2 aa bb txt2 tt2 sum2 tl txtst sum summ p1)
  (exe)
  (exe%)
(defun c:py( / cl e1 a b txt1 tt1 sum1 txth1 thh sum summ p1 )
   (setq e1 (entsel “n>>숫자선택:”))
    (setq sum (* sum1 0.3025))
    (setq summ (rtos sum 2 2))
    (setq zz (strcat “(” summ “)”))
    (command “text” p1 thh 0 zz)
(defun c:+( / cl sum_m ss ok e ent sum_ p1 txth1 thh summ )
 (setq sum_m 0)
  (setq SS (ssget))
  (setq ok 0)
  (while
    (setq e (ssname ss ok))
    (setq ent (entget e))
    (setq sum_ (assoc 1 ent))
    (setq sum_ (cdr sum_))
    (setq sum_ (atof sum_))
    (setq sum_m (+ sum_m sum_))
    (setq ok (1+ ok))
    (setq txth1 (assoc 40 ent))
    (setq thh (cdr txth1))
    (setq summ (rtos sum_m 2 4))
(defun c:*( / cl sum_m ss ok e ent sum_ p1 txth1 thh summ )
 (setq sum_m 1)
  (setq SS (ssget))
  (setq ok 0)
  (while
    (setq sum_m (* sum_m sum_))
    (setq ok (1+ ok))
(princ “n>>사칙연산 프로그램 로딩완료 command : 0,-,1,/,%,py,00,11”)
사칙연산 리습입니다…  면적: 2100(글씨가 써 일경우) 사칙연산 가능하게 할수있나요?
aaaaadd
  • 78 조회
      2014-11-20T17:07:46+09:00답변 등록 답변 등록 일시 2014-11-20 5:07 pm
      감사합니다~유용하게 사용하겠습니다.
    3. 수야12 Lv.22
      2014-11-19T18:28:01+09:00답변 등록 답변 등록 일시 2014-11-19 6:28 pm
      분명 아름다운 우리글로 써있는 내용인데 내용을 알아 볼수가 없네요 ^^;;
      선택한 텍스트에  숫자와 문자혼합일때도 계산가능하게 해달라는 얘기로 생각하고 수정
      했습니다
      사용예 > test200 (가능) 200test(가능) 2te3s10(결과값 보장못함)
