홈/ 질문/Q 109237
등록일: 2017-12-192017-12-19T16:41:24+09:00 2017-12-19T16:41:24+09:00카테고리: AutoCAD & CADian
선택했을때 insert 시키려 하는데 어떻게 합쳐야 할깡요
(defun : RSCHAIN()
  (setq chainlist1 (list “rs40-10t” “rs40-11t” “rs-4012t” ))
  (setq chainlist2 (list “rs40-10t” “rs40-11t” “rs-4012t” ))
  (setq dcl_id (loading_dialog “chain.dcl”))
  (if (not (new_dialog “RSCHAINLIST” dcl_id))
    (progn
      (alert “THE RSCHAINLIST.DCL file could not be load”
      (exit)
    (start_list “chainlist1” 3)
    (mpcar ‘add_list chainlist1)
    (end_list)
    (start_list “chainlist2” 3)
    (mpcar ‘add_list chainlist2)
    (end_list)
    (acction_tile “accept” “(setq ddiag 2)(savevars)(done_dialog)”)
    (start_dialog)
    (unload_dialog dcl_id)
    (if (= dialog 1)
      (princ “n 취소버튼 누름”)
    (if (= dialo2 2)
      (progn
 (princ (strcat “n chainlist 평면누름” chainlist1 “선택”))
 (princ (strcat “n chainlist 측면누름” chainlist2 “선택”))
아래 부분을 dcl에서 작동시켜 도면에 삽입하는 리습을 하려는데 어디에 넣어야 할지를 모르겠네요
평면
  (command “insert” “c:/lisp/chain/rs40-10t.dwg” pause “1” “1” “0”)
  (command “insert” “c:/lisp/chain/rs40-11t.dwg” pause “1” “1” “0”)
  (command “insert” “c:/lisp/chain/rs40-12t.dwg” pause “1” “1” “0”)
측면
  (command “insert” “c:/lisp/chain/rs40-10ts.dwg” pause “1” “1” “0”)
  (command “insert” “c:/lisp/chain/rs40-11ts.dwg” pause “1” “1” “0”)
  (command “insert” “c:/lisp/chain/rs40-12ts.dwg” pause “1” “1” “0”)
RSCHAINLIST : dialog {
 label = ” THE CHAIN SPROCKET” ;
: colum {
 : boxed_row {
   : popup_list {
     key = “chainlist1” ;
     label = “평면” ;
     fixed_width_font = true;
     width = 30 ;
     value = “” ;
 : popup row {
    key = “chainlist2” ;
    label = “측면” ;
    width = 30 ;
    value = “” ;
 : boxed_row {
   : button {
     key = “accept” ;
     label = “확인” ;
     is_default = true ;
: button {
     key = “cancel” ;
     label = “취소” ;
     is_default = false ;
     is_cancel = trur ;
  • 27 조회
