홈/ 질문/Q 104028
등록일: 2015-05-062015-05-06T10:55:05+09:00 2015-05-06T10:55:05+09:00카테고리: AutoCAD & CADian
소수점 표시 수정 부탁드립니다.(리습소스)
리습 횡단 용지폭 만드는 소스인데요..
좌 우 숫자 입력시 예를들어 18.99, 11.6 이렇게 입력하면
도면에 표시되는 숫자가 반올림 되어 소수점 첫재짜리 밖에 안나옵니다.
반올림 하지말고 그대로 소수점 두재짜리 까지 나오게 수정 부탁드리겠습니다.
(defun c:p0 ()
 (if (/= htext3 nil)
     (command “style” “횡단글꼴” “romans.shx,ghs.shx” htext3 “” “” “” “”)
     (progn
         (setq he1 (getreal “n글자의 높이는 : 재입력 / <1.5> —  “))
         (if (null he1)(setq htext3 1.5)(setq htext3 he1))
 (setq osm1 (getvar “osmode”))
 (setq lay1 (getvar “clayer”))
 (setq distold1 0)
 (setq distold2 0)
 (setvar “osmode” 2)
 (setq roop1 1)
 (setq end-l nil)
 (setq end-r nil)
 (setq end-lold nil)
 (setq end-rold nil)
 (while roop1
    (initget 128 “End”)
    (princ “nn=====================================================”)
    (setq mid1 (getpoint (strcat “n종료(E) / Pick Mid Point ==> “)))
    (cond ((= mid1 “End”)
             (setq roop1 nil)
          ((= mid1 nil)
          (t
               (setvar “osmode” 1)
               (setq to1 (getpoint “n     End Point (진행방향으로 좌측)==> “))
               (setvar “osmode” 0)
               (setq ang1 (angle mid1 to1))
               (grdraw (polar mid1 ang1 20) (polar mid1 (+ ang1 pi) 20) 2 1)
               (setq dist1 (getreal (strcat “n Input Left Dist <” (rtos distold1 2 1) “> : “)))
               (if (= dist1 nil)
                   (setq dist1 distold1)
               (setq dist2 (getreal (strcat “n Input Right Dist <” (rtos distold2 2 1) “> : “)))
               (if (= dist2 nil)
                   (setq dist2 distold2)
               (setq distold1 dist1)
               (setq distold2 dist2)
               (command “-LAYER” “m” “지적-용지폭-횡단” “”)
               (command “line” (polar mid1 ang1 dist1) mid1 (polar mid1 (+ ang1 pi) dist2) “”)
               (setq end-l (polar mid1 ang1 dist1))
               (setq end-r (polar mid1 (+ ang1 pi) dist2))
               (command “-LAYER” “m” “지적-용지폭-횡단거리” “”)
               (command “text” “j” “mc” (polar mid1 ang1 (+ dist1 3)) (* (+ ang1 pi) (/ 180 PI)) (rtos dist1 2 1))
               (command “text” “j” “mc” (polar mid1 (+ ang1 pi) (+ dist2 3)) (* (+ ang1 pi) (/ 180 PI)) (rtos dist2 2 1))
               (command “-LAYER” “m” “지적-용지폭-용지경계” “”)
               (if end-lold (command “line” end-lold end-l “”))
               (if end-rold (command “line” end-rold end-r “”))
               (setq end-lold end-l)
               (setq end-rold end-r)
               (command “redraw”)
               (setvar “osmode” 2)
          );;; t
      );;; cond
 );;;while
 (setvar “osmode” osm1)
 (setvar “clayer” lay1)
 (command “redraw”)
  • 57 조회
    2. 자유천지 Lv.8
      2015-05-06T12:30:59+09:00답변 등록 답변 등록 일시 2015-05-06 12:30 pm
       (rtos dist1 2 1)) =>  (rtos dist1 2 2))
      (rtos dist2 2 1) => (rtos dist2 2 2)
      (rtos distold1 2 1) => (rtos distold1 2 2)
      (rtos distold2 2 1) => (rtos distold2 2 2)
