홈/ 질문/Q 25998
등록일: 2001-07-032001-07-03T14:23:50+09:00 2001-07-03T14:23:50+09:00카테고리: AutoCAD & CADian
시삽님 보시고 검토를 부탁드립니다!
(defun C:1 (/ ENT)
(setvar "cmdecho" 0)
(command "layer" "m" "L-DIE" "")
);defun
(defun C:2 (/ ENT)
(command "layer" "m" "L-DIE-DASH" "")
);defun
(defun C:3 (/ ENT)
(command "layer" "m" "U-DIE" "")
);defun
(defun C:4 (/ ENT)
(command "layer" "m" "U-DIE-DASH" "")
);defun
(defun C:5 (/ ENT)
(command "layer" "m" "PAD" "")
);defun
(defun C:6 (/ ENT)
(command "layer" "m" "PAD-DASH" "")
);defun
(defun C:7 (/ ENT)
(command "layer" "m" "L-STEEL" "")
);defun
(defun C:8 (/ ENT)
(command "layer" "m" "L-STEEL-DASH" "")
);defun
(defun C:9 (/ ENT)
(command "layer" "m" "U-STEEL" "")
);defun
(defun C:0 (/ ENT)
(command "layer" "m" "U-STEEL-DASH" "")
);defun
(defun C:- (/ ENT)
(command "layer" "m" "CAM" "")
);defun
(defun C:= (/ ENT)
(command "layer" "m" "CAM-DASH" "")
);defun
(defun C: (/ ENT)
(command "layer" "m" "CAM-UNIT" "")
);defun
(defun C:12 (/ ENT)
(command "layer" "m" "HEEL" "")
);defun
(defun C:13 (/ ENT)
(command "layer" "m" "HEEL-DASH" "")
);defun
(defun C:14 (/ ENT)
(command "layer" "m" "POST" "")
);defun
(defun C:15 (/ ENT)
(command "layer" "m" "POST-DASH" "")
);defun
(defun C:16 (/ ENT)
(command "layer" "m" "PART" "")
);defun
(defun C:17 (/ ENT)
(command "layer" "m" "PART-NO" "")
);defun
(defun C:18 (/ ENT)
(command "layer" "m" "PANEL" "")
);defun
(defun C:19 (/ ENT)
(command "layer" "m" "PANEL-VIEW" "")
);defun
(defun C:20 (/ ENT)
(command "layer" "m" "SECHION" "")
);defun
(defun C:21 (/ ENT)
(command "layer" "m" "SECHION-DASH" "")
);defun
(defun C:23 (/ ENT)
(command "layer" "m" "AUTO" "")
);defun
(defun C:24 (/ ENT)
(command "layer" "m" "AUTO-DASH" "")
);defun
(defun C:25 (/ ENT)
(command "layer" "m" "AIR" "")
);defun
(defun C:26 (/ ENT)
(command "layer" "m" "DIM" "")
);defun
(defun C:27 (/ ENT)
(command "layer" "m" "DIM-H" "")
);defun
(defun C:28 (/ ENT)
(command "layer" "m" "CENTER" "")
);defun
(defun C:29 (/ ENT)
(command "layer" "m" "CORE" "")
);defun
(defun C:30 (/ ENT)
(command "layer" "m" "STD" "")
);defun
(defun C:31 (/ ENT)
(command "layer" "m" "STD-DASH" "")
);defun
(defun C:32 (/ ENT)
(command "layer" "m" "STD1" "")
);defun
(defun C:34 (/ ENT)
(command "layer" "m" "STD1-DASH" "")
);defun
(defun c:11 (/ ss)
(setq ss (ssget))
(command "change" ss "" "p" "c" "bylayer" "lt" "bylayer" "la" "L-DIE" "")
);defun
(defun c:22 (/ ss)
(setq ss (ssget))
(command "change" ss "" "p" "c" "bylayer" "lt" "bylayer" "la" "L-DIE-DASH" "")
);defun
(defun c:33 (/ ss)
(setq ss (ssget))
(command "change" ss "" "p" "c" "bylayer" "lt" "bylayer" "la" "U-DIE" "")
);defun
(defun c:44 (/ ss)
(setq ss (ssget))
(command "change" ss "" "p" "c" "bylayer" "lt" "bylayer" "la" "U-DIE-DASH" "")
);defun
(defun c:55 (/ ss)
(setq ss (ssget))
(command "change" ss "" "p" "c" "bylayer" "lt" "bylayer" "la" "PAD" "")
);defun
(defun c:66 (/ ss)
(setq ss (ssget))
(command "change" ss "" "p" "c" "bylayer" "lt" "bylayer" "la" "PAD-DASH" "")
);defun
(defun c:77 (/ ss)
(setq ss (ssget))
(command "change" ss "" "p" "c" "bylayer" "lt" "bylayer" "la" "L-STEEL" "")
);defun
(defun c:88 (/ ss)
(setq ss (ssget))
(command "change" ss "" "p" "c" "bylayer" "lt" "bylayer" "la" "L-STEEL-DASH" "")
);defun
(defun c:99 (/ ss)
(setq ss (ssget))
(command "change" ss "" "p" "c" "bylayer" "lt" "bylayer" "la" "U-STEEL" "")
);defun
(defun c:00 (/ ss)
(setq ss (ssget))
(command "change" ss "" "p" "c" "bylayer" "lt" "bylayer" "la" "U-STEEL-DASH" "")
);defun
(defun c:– (/ ss)
(setq ss (ssget))
(command "change" ss "" "p" "c" "bylayer" "lt" "bylayer" "la" "CAM" "")
);defun
(defun c:== (/ ss)
(setq ss (ssget))
(command "change" ss "" "p" "c" "bylayer" "lt" "bylayer" "la" "CAM-DASH" "")
);defun
(defun c: (/ ss)
(setq ss (ssget))
(command "change" ss "" "p" "c" "bylayer" "lt" "bylayer" "la" "CAM-UNIT" "")
);defun
(defun c:122 (/ ss)
(setq ss (ssget))
(command "change" ss "" "p" "c" "bylayer" "lt" "bylayer" "la" "HEEL" "")
);defun
(defun c:133 (/ ss)
(setq ss (ssget))
(command "change" ss "" "p" "c" "bylayer" "lt" "bylayer" "la" "HEEL-DASH" "")
);defun
(defun c:144 (/ ss)
(setq ss (ssget))
(command "change" ss "" "p" "c" "bylayer" "lt" "bylayer" "la" "POST" "")
);defun
(defun c:155 (/ ss)
(setq ss (ssget))
(command "change" ss "" "p" "c" "bylayer" "lt" "bylayer" "la" "POST-DASH" "")
);defun
(defun c:166 (/ ss)
(setq ss (ssget))
(command "change" ss "" "p" "c" "bylayer" "lt" "bylayer" "la" "PART" "")
);defun
(defun c:177 (/ ss)
(setq ss (ssget))
(command "change" ss "" "p" "c" "bylayer" "lt" "bylayer" "la" "PART-NO" "")
);defun
(defun c:188 (/ ss)
(setq ss (ssget))
(command "change" ss "" "p" "c" "bylayer" "lt" "bylayer" "la" "PANEL" "")
);defun
(defun c:199 (/ ss)
(setq ss (ssget))
(command "change" ss "" "p" "c" "bylayer" "lt" "bylayer" "la" "PANEL-VIEW" "")
);defun
(defun c:200 (/ ss)
(setq ss (ssget))
(command "change" ss "" "p" "c" "bylayer" "lt" "bylayer" "la" "SECHION" "")
);defun
(defun c:211 (/ ss)
(setq ss (ssget))
(command "change" ss "" "p" "c" "bylayer" "lt" "bylayer" "la" "SECHION-DASH" "")
);defun
(defun c:233 (/ ss)
(setq ss (ssget))
(command "change" ss "" "p" "c" "bylayer" "lt" "bylayer" "la" "AUTO" "")
);defun
(defun c:244 (/ ss)
(setq ss (ssget))
299 (command "change" ss "" "p" "c" "bylayer" "lt" "bylayer" "la" "AUTO-DASH" "")
);defun
(defun c:255 (/ ss)
(setq ss (ssget))
(command "change" ss "" "p" "c" "bylayer" "lt" "bylayer" "la" "AIR" "")
);defun
(defun c:266 (/ ss)
(setq ss (ssget))
(command "change" ss "" "p" "c" "bylayer" "lt" "bylayer" "la" "DIM" "")
);defun
(defun c:277 (/ ss)
(setq ss (ssget))
(command "change" ss "" "p" "c" "bylayer" "lt" "bylayer" "la" "DIM-H" "")
);defun
(defun c:288 (/ ss)
(setq ss (ssget))
(command "change" ss "" "p" "c" "bylayer" "lt" "bylayer" "la" "CENTER" "")
);defun
(defun c:299 (/ ss)
(setq ss (ssget))
(command "change" ss "" "p" "c" "bylayer" "lt" "bylayer" "la" "CORE" "")
);defun
(defun c:300 (/ ss)
(setq ss (ssget))
(command "change" ss "" "p" "c" "bylayer" "lt" "bylayer" "la" "STD" "")
);defun
(defun c:311 (/ ss)
(setq ss (ssget))
(command "change" ss "" "p" "c" "bylayer" "lt" "bylayer" "la" "STD-DASH" "")
);defun
(defun c:322 (/ ss)
(setq ss (ssget))
(command "change" ss "" "p" "c" "bylayer" "lt" "bylayer" "la" "STD1" "")
);defun
(defun c:344 (/ ss)
(setq ss (ssget))
(command "change" ss "" "p" "c" "bylayer" "lt" "bylayer" "la" "STD1-DASH" "")
);defun
(defun c:EL(/ ip ent)
(graphscr)
(setq 1 "l-die"
2 "l-die-dash"
3 "u-die"
4 "u-die-dash"
5 "pad"
6 "pad-dash")
(setq ip (getreal "1,2,3,4,5,6, @ Eress하고픈 LAYER 이름이 뭐여 ?:"))
(if (eq ip 1)(setq ip "l-die"))
(if (eq ip 2)(setq ip "l-die-dash"))
(if (eq ip 3)(setq ip "u-die"))
(if (eq ip 4)(setq ip "u-die-dash"))
(if (eq ip 5)(setq ip "pad"))
(if (eq ip 6)(setq ip "pad-dash"))
(setq ent (ssget (list (cons 8 ip))))
(command "ERASE" ent "")
);defun
제가 쓰고자하는 레이어들입니다.
원 레이어명은 제가 일하는 설계명들입니다.
그리고 현제는 CADMAX라는 프로그램으로 현레벨(레이어)를 사용하고요.
일본일을 하면서 데이터 인터패이스에 문제가 만더군요.
그들은 LT 를 쓰고 있거든요.
그래서 acad로 바꿀려고 하다 보니까 이런 문제가 있더군요.
현 레이어명으로 그대로 사용하면서 작업을 할때는 간단하게 할려고합니다.
시삽님 보시고 많은 조언을 부탁드립니다.
(defun c:CL(/ ip ent)
(setq ip (getstring "1,2,3,4,5,6,7,8,9,0,-,=,,12,13,14,15,16,17,18,19,20,21,23,24,25,26,27,28,29,30,31,32,34, @ COPY하고픈 LAYER 이름이 뭐여 ?:"))
(command "COPY" ent "")
);defun
  • 48 조회
    • 캐드 마우스 커서이동, 명령어 입력, 그래그 등 버벅거림 도와주세요,.,,
    2. 빌린인생
      2001-07-03T15:13:29+09:00답변 등록 답변 등록 일시 2001-07-03 3:13 pm
      헐~~~~~~~ 넘 수고가 많으시네여^^ 이렇게 까지 리습을 짜다니..대단하심다..
      노력의 승리 같네여 ㅋㅋㅋ
      틀린곳만 체크 해드리겠음다…
      먼저 윗부분은 틀린곳이 없는 것 같구여..윗부분 쓰시느라 고생했음다..
      (graphscr)
      ;(setq 1 "l-die" ============> 요기 부터
      ; 2 "l-die-dash"
      ; 3 "u-die"
      ; 4 "u-die-dash"
      ; 5 "pad"
      ; 6 "pad-dash") ===========> 요까지 필요 없는 부분임다..
      if 문에서 다시 정의를 하기땜시 필요 없음다,..글고 setq 로는 숫자를 함수로 사용못함..
      (setq ent (ssget <<"x">> (list (cons 8 ip)))) =====>그리고 이곳에 "x" 가빠졌네여<< >> 는 안들어가는 거 아시죠?..
      );defun
      );defun
      그리고 뒷부분에 짜신 리습은 전체적으로 마니 틀리네여.. ip에 문자열을 받아 들인다고 치고
      만약에 1를 선택했다면..
      그럼 ent 값은 (list (cons 8 "1") 이런식이 되는 거죠
      먼가 쫌 이상하지 안나여?…. 그리고 CL리습도 EL 리습처럼 정의 해서 짜야 되여
      좀더 실력이 쌓아 진다면 다른방법도 있긴한데..아직까지 그런것을 기대하긴..쫌.
      리습안에서 다른 리습을 불러 사용하는 방법인데…. 앞으로도 공부 열심히
      하세여………그럼 존하루 제가 오늘은 쫌 바뻐서리..^^
    3. ygpark
      2001-07-03T15:22:46+09:00답변 등록 답변 등록 일시 2001-07-03 3:22 pm
      빌린인생님의 답변이 정확하군요~
