홈/ 질문/Q 104784
등록일: 2015-08-052015-08-05T08:22:09+09:00 2015-08-05T08:22:09+09:00카테고리: AutoCAD & CADian
오토캐드 리습인데 캐디안에서 실행될수 있게 수정좀 부탁드립니다,
오토캐드리습인데 캐디안 클래식에서 실행되게 수정좀 부탁드립니다,
(defun c:a (/ circle text @line @pline ename->obj tlst xx @dist aa aaa ss a llist)
(defun Circle (cen rad)
  (entmakex (list (cons 0 “CIRCLE”)
                  (cons 10 cen)
                  (cons 40 rad))))
(defun Text (pt hgt str ang)
  (entmakex (list (cons 0 “TEXT”)
                  (cons 10  ‘(0 0))
                  (cons 11  pt)
                  (cons 40 hgt)
                  (cons 50 ang)
                  (cons 72  1)
                  (cons 73  2)
                  (cons 1  str))))
(defun ename->obj (l) (mapcar ‘vlax-ename->vla-object l))
(defun tlst (l) (if l (cons (list (car l) (cadr l) 0) (tlst (cddr l)))))
(defun xx (l) (if l (cons (car l) (xx (vl-remove (car l) (cdr l))))))
(defun @dist (l)
   (if (cadr l) (cons (list (distance (car l) (cadr l)) (angle (car l) (cadr l))) (@dist (cdr l))))
(defun aaa (l) (if l (cons (list (car l) (- (length l) (length (vl-remove (car l) l)))) (aaa (vl-remove (car l) l)))))
(defun aa (l) (if l (if (= (cadr l) 1) (strcat (rtos (car l) 2 2) “+”) (strcat (rtos (car l) 2 2) “*” (rtos (cadr l) 2 2) “+”))))
(defun bb (l) (if l (strcat (vl-princ-to-string (car l)) “+”)))
(defun @line (l / spt ept dist ang pt sc i pt1 tot tt)
  (setq i 0
         p1 (getpoint “n문자 선택 점:”)
         tot nil)
  (mapcar
     ‘(lambda(x)
         (setq spt (vlax-get x ‘StartPoint)
               ept (vlax-get x ‘EndPoint)
               dist (/ (distance spt ept) 1000)
               ang (angle spt ept)
               pt (list (/ (+ (car spt) (car ept)) 2) (/ (+ (cadr spt) (cadr ept)) 2) 0)
               sc (getvar ‘dimscale))
         (text pt (* sc 2.5) (vl-princ-to-string dist) ang)                          ;<- 2.5 문자크기
         (circle (setq pt1 (polar pt (- ang (/ pi 2)) (* sc 4))) (* sc 1.5))
         (text pt1 (* sc 1.0) (vl-princ-to-string (setq i (+ i 1))) 0)             ;<- 1.0 문자크기
         (setq tot (append tot (list dist)))
   l)
   (setq tt (apply ‘strcat (mapcar ‘(lambda(x) (strcat (rtos x 2 2) “+”)) tot)))
     (text p1 (* sc 2.5) (strcat (substr tt 1 (- (strlen tt) 1)) “=” (rtos (apply ‘+ tot) 2 2)) 0)    ;<- 2.5 문자크기
(defun @pline (l / cdn dis dist1 total i p1 pt sc z tt)
   (setq cdn (xx (tlst (vlax-get l ‘Coordinates))))
      (if (= (vlax-get l ‘Closed) -1)
         (setq dis (@dist (append cdn (list (car cdn)))))
         (setq dis (@dist cdn)))
   (setq dist1 (mapcar ‘(lambda(x) (/ x 1000)) (mapcar ‘car dis))
         total (rtos (apply ‘+ dist1) 2 2)
         i 0
         p1 (getpoint “n문자 선택 점:”))
    (mapcar
       ‘(lambda(x y)
       (setq pt (polar y (cadr x) (/ (car x) 2))
       (text pt (* sc 2.5) (rtos (* (car x) 0.001) 2 2) (cadr x))                   ;<- 2.5 문자크기
       (circle (setq pt1 (polar pt (- (cadr x) (/ pi 2)) (* sc 4))) (* sc 1.5))
       (text pt1 (* sc 1.0) (vl-princ-to-string(setq i (+ i 1))) 0)                  ;<- 1.0 문자크기
     dis cdn)
     (setq z (aaa dist1)
           tt (apply ‘strcat (mapcar ‘aa z)))
     (text p1 (* sc 2.5) (strcat (substr tt 1 (- (strlen tt) 1)) “=” total) 0)     ;<- 2.5 문자크기
   (setq ss (ssget ‘((0 . “*line”)))
         a (ename->obj (vl-remove-if ‘listp (mapcar ‘cadr (ssnamex ss)))))
   (mapcar
      ‘(lambda(x)
         (setq objname (vla-get-ObjectName x))
         (if (= objname “AcDbPolyline”) (@pline x)
         (if (= objname “AcDbLine”) (setq llist (append (list x) llist)))
      a
   (if llist (@line llist))
  • 85 조회
    2. 수야12 Lv.22
      2015-08-28T11:08:38+09:00답변 등록 답변 등록 일시 2015-08-28 11:08 am
      캐디안 비주얼리습 인식못합니다 완전히 뜯어 고쳐야 겠네요
      여러분들 캐디안 비추입니다 차라리 ZWCAD를 사용하세요 저희회사 2중으로 돈들어가게 생겼습니다
      캐디안 괞이 샀어~!! 사장님한테 추천한넘이 전데.. ㅜ.ㅜ 사장님 죄송해요
