홈/ 질문/Q 106425
로이012
로이012Lv.0
등록일: 2016-04-122016-04-12T10:50:14+09:00 2016-04-12T10:50:14+09:00카테고리: AutoCAD & CADian
치수와 치수사이 간격리습 문의
위 그림과 같이 왼쪽 치수 간격을 8로 정해서 띄우려고합니다.
현재 리습실행하게되면 오른쪽과 같이 치수가 겹치게 됩니다.
어디에 수정을 해야될지 헷갈리네요;; 수정부탁드립니다.
;TIP1402.LSP:   UPDLI.LSP   Update Dimension Spacing  (c)1998, Ross Warren, Jr.
(defun UPDLIERR (ERR)
   (princ “nFinished adjusting dimensions !”)
   (setq
      *error* OERROR
   (prin1)
(defun C:UPDLI ()
   (setq OLDERROR *error* *error* UPDLIERR)
   (setq
      CECH (getvar “cmdecho”)
   (setvar “cmdecho” 0)
   (setq
      ENT1 (entget (car (entsel “Select first dimension :”)))
   (entmod ENT1)
   (setq D10 (cdr (assoc 10 ENT1)))
   (setq
      D13 (cdr (assoc 13 ENT1))
   (setq D50 (cdr (assoc 50 ENT1)))
   (if (= D50 0)
      (progn
         (if (> (cadr D10) (cadr D13))
            (progn
               (while t
                  (setq
                     ENT2 (entget
                             (car
                                (entsel
                                   “nSelect next dimension :”
                  (setq D210 (cdr (assoc 10 ENT2)))
                  (setq
                     D210 (list
                             (car D210)
                                (cadr D10)
                                   (getvar “DIMSCALE”)
                                   (getvar
                                      “DIMDLI”
                             (caddr D210)
                  (setq
                     ENT2 (subst
                             (cons 10 D210)
                             (assoc 10 ENT2)
                             ENT2
                  (entmod ENT2)
                  (entupd (cdr (car ENT2)))
                  (setq
                     D10 (cdr (assoc 10 ENT2))
         (if (< (cadr D10) (cadr D13))
            (progn
               (while t
                  (setq
                     ENT2 (entget
                             (car
                                (entsel
                  (setq
                     D210 (list
                             (car D210)
                                (cadr D10)
                                   (getvar “DIMSCALE”)
                                   (getvar
                                      “DIMDLI”
                             (caddr D210)
                  (setq
                     ENT2 (subst
                             (cons 10 D210)
                             (assoc 10 ENT2)
                             ENT2
                  (entmod ENT2)
                  (setq
   (if (> D50 0)
      (progn
         (if (> (car D10) (car D13))
            (progn
               (while t
                  (setq
                     ENT2 (entget
                             (car
                                (entsel
                  (setq
                     D210 (list
                                (car D10)
                                   (getvar “DIMSCALE”)
                                   (getvar
                                      “DIMDLI”
                             (cadr D210)
                             (caddr D210)
                  (setq
                     ENT2 (subst
                             (cons 10 D210)
                             (assoc 10 ENT2)
                             ENT2
                  (entmod ENT2)
                  (setq
         (if (< (car D10) (car D13))
            (progn
               (while t
                  (setq
                     ENT2 (entget
                             (car
                                (entsel
                  (setq
                     D210 (list
                                (car D10)
                                   (getvar “DIMSCALE”)
                                   (getvar
                                      “DIMDLI”
                             (cadr D210)
                             (caddr D210)
                  (setq
                     ENT2 (subst
                             (cons 10 D210)
                             (assoc 10 ENT2)
                             ENT2
                  (entmod ENT2)
                  (setq
   (setvar “cmdecho” CECH)
   (setq *error* OLDERROR)
   (prin1)
  • 155 조회
    2. 로이012 Lv.0
      2016-04-14T10:24:59+09:00답변 등록 답변 등록 일시 2016-04-14 10:24 am
      감사합니다.emoticon
