홈/ 질문/Q 109194
등록일: 2017-12-072017-12-07T10:51:54+09:00 2017-12-07T10:51:54+09:00카테고리: AutoCAD & CADian
텍스트 수정 부탁드려요
평, 면적 산출리습입니다.. 글자체 수정이 가능할까요?
(defun c:pp()
  (setq doc (vla-get-activedocument (vlax-get-acad-object)))
  (cond
    ((= (vla-get-activespace doc) 1) (setq space (vla-get-modelspace doc)))
    ((= (vla-get-activespace doc) 0) (setq space (vla-get-paperspace doc)))
  (if (setq ss (ssget (list (cons 0 “CIRCLE,ARC,*POLYLINE,LINE,ELLIPSE,SPLINE”))))
    (if (setq ts (getreal “n텍스트 높이 입력:”))
      (progn
 (setq index 0)
 (repeat (sslength ss)
   (setq obj (vlax-ename->vla-object (ssname ss index)))
   (vla-getboundingbox obj ‘mi ‘mx)
   (setq minpt (vlax-safearray->list mi) maxpt (vlax-safearray->list mx))
   (setq inspt (polar minpt (angle minpt maxpt) (/ (distance minpt maxpt) 2)))
   (setq inspt (list (car inspt) (+ (cadr inspt) (* ts 2))))
   (setq area (vla-get-area obj) len (vlax-curve-getdistatparam obj (vlax-curve-getendparam obj)))
   (mapcar ‘(lambda (a b)
       (setq p (vlax-3d-point inspt))
       (setq txtobj (vla-addtext space (strcat a b) p ts))
       (vla-put-alignment txtobj 4)
       (vla-put-textalignmentpoint txtobj p)
       (setq inspt (polar inspt (/ (* 270 pi) 180) (* ts 2)))
              ‘(“평 : ” “면적(㎡) : ” “길이(m) : ” ) (list (rtos (/ area 3305796.) 2 4) (rtos (/ area 1000000.) 2 4) (rtos (/ len 1000.) 2 4))
   (setq index (1+ index))
 (command “chprop” (ssget “x” ‘((0 . “TEXT”) (1 . “평*”))) “” “c” “7” “”)
(vl-load-com)
(prompt “n[ AAA ]”)
  • 30 조회
      2017-12-07T11:27:24+09:00답변 등록 답변 등록 일시 2017-12-07 11:27 am
      현재 글자체 따라갑니다 스타일에서 바꾸세요
