홈/ 질문/Q 108304
등록일: 2017-04-182017-04-18T12:23:42+09:00 2017-04-18T12:23:42+09:00카테고리: AutoCAD & CADian
파이 기호 리습 수정 문의 입니다.
숫자 앞에 %%c를 넣어 주는 리습인데 숫자 뒤에 %%d를 넣고 싶어요
수정 할 수 있게 도와주세요!
ex) 300-> %%c300 을 300%%d로 나타내고 싶어요
(defun C:ZC ( / TXT_String LOC ELIST EntType Old_TXT Chk_TXT EntType SUB Sub_Ent)
  (while (= TXT_String nil); checks to make sure something was selected
    (setq TXT_String (entsel “nPick the text to add Phi symbol :”); if nothing was selected try again
   Loc (cadr TXT_String); stores the point picked
   TXT_String (car TXT_String)); stores the entity name
    (if(= TXT_String nil)
      (princ “Nothing Picked”); tell user nothing has been selected
      ); end if
    ); end while
  (setq ELIST (entget TXT_String))
  (setq EntType (cdr (assoc 0 elist))); stores the entity type
  (cond
    ((= EntType “TEXT”)
     (setq Old_TXT (cdr (assoc 1 elist)); gets the text from the string
    Chk_TXT  (substr Old_TXT 1 3); gets the 1st 3 characters of the string for testing
     ); end setq
     (if
       (or (= Chk_TXT “%%c”) (= Chk_TXT “%%c”))
 (progn
   (setq New_Txt (substr Old_TXT 4); removes the Phi if it exists
  ELIST (subst (cons 1 New_TXT) (assoc 1 ELIST) ELIST); replaces the existing string
   ); end setq
 ); end progn
 (progn
   (setq New_TXT (strcat “%%c”Old_TXT); adds the Phi
  ELIST (subst (cons 1 New_TXT) (assoc 1 ELIST) ELIST);replaces the existing string
   ); end setq
 ); end Progn
     ); end if
    ((= EntType “MTEXT”)
     ); end setq
     (if
       (= Chk_TXT “{%%c”)
 (progn
   (setq Strg_Lngh (- (strlen Old_TXT) 4); checks the string length – the Phi
  New_TXT   (substr Old_TXT 4 Strg_Lngh); removes the Phi if it exists
   ); end setq
 ); end progn
 (progn
   (setq New_TXT (strcat “{%%c”Old_TXT”}”);adds the Phi
   ); end setq
 ); end Progn
     ); end if
    ((= EntType “DIMENSION”)
     );end setq
     (if
       (= Old_TXT “”)
 (setq Old_TXT “<>”)
     ); end if
     (if
       (= Chk_TXT “{%%c”)
 (progn
   (setq Lngh (strlen old_txt)
  New_Lngh (- Lngh 4)
  New_TXT (substr Old_TXT 4 New_Lngh); removes the Phi if it exists
   ); end setq
 ); end progn
 (progn
   (setq New_TXT (strcat “{%%c”Old_TXT”}”) ; adds the Phi
   ); end setq
 ); end Progn
     ); end if
    ((= EntType “INSERT”)
     (setq SUB    (nentselp LOC); Use pick point to select subentity
    Sub_Ent (car SUB); Store entity name
    Old_TXT (cdr (assoc 1 (entget Sub_Ent))); Retrieve value
     ); end setq
     (if
 (progn
   (setq ELIST (entget Sub_Ent)
   ); end setq
 ); end progn
 (progn
   ); end setq
 ); end Progn
     ); end if
    ((princ “nSelected object is not text”))
  ); end COND
  (entmod ELIST)
  (entupd TXT_String)
);end defun
  • 35 조회
      2017-04-18T16:59:29+09:00답변 등록 답변 등록 일시 2017-04-18 4:59 pm
      감사합니다 !! 즐거운 하루 되세요~
