홈/ 질문/Q 98893
등록일: 2013-07-222013-07-22T13:37:03+09:00 2013-07-22T13:37:03+09:00카테고리: AutoCAD & CADian
<파일첨부>BOM중량 리습관련하여 문의드립니다.
문의사항.JPG기존에 가지고 있던 리습에서 좌표값만 수정해놓았습니다.
그런데 UNIT WEIGHT는 적용이 안되고 단일 개체 WEIGHT만 계산이 되고있습니다.
아무리 해봐도 잘안되서 고수님께 문의드립니다.
(defun C:CSP (/ ss szss qtss qtmin qtmax szmin szmax unitp totalp olderr
               i ii fa en ed szed qty sz sp uwt twt x1 x2 x3 x4)
  (setq olderr *error
        *error* wterr
  (if (setq ss (ssget))
    (progn
      (command “layer” “S” “TXT” “”)
      (command “COLOR” “bylayer” “”)
   (setq old_snap (getvar “osmode”))
      (setvar “osmode” 0)
      (SETVAR “LUPREC” 1)
   (setvar “dimzin” 0)
      (setq gap 0)
      (setq i   -1
            wtn  0
            fa   (getvar “dimscale”)
            llpx (car (getvar “limmin”))
            urpx (car (getvar “limmax”))
            paper (rem (- urpx llpx) 594)
            qtss (ssadd)
            szss (ssadd)
      (if (zerop paper)
        (setq qtmin  (* fa (+ gap 720.7))    ;Quantity x-coordinates
              qtmax  (* fa (+ gap 735.7))
              szmin  (* fa (+ gap 735.7))    ;Description x-coordnates
              szmax  (* fa (+ gap 779.7))
 ;            unitp  (* fa (+ gap 779.7))    ;Unit weight text end point
              totalp (* fa (+ gap 803.7))    ;Total weight text end point
      (while
   (setq en (ssname ss (setq i (1+ i))))
   (setq ed (entget en))
   (if (= “TEXT” (cdr (assoc 0 ed)))
     (cond
    ((> szmin (setq sp (cadr (assoc 10 ed)))) )
    ((< szmim sp szmax) (ssadd en szss))
    ((< qtmin sp qtmax) (ssadd en qtss))
      (setq i -1)
      (repeat (setq szn (sslength szss))
        (setq szed (entget (ssname szss (setq i (1+ i))))
              sz (strcase (setq orgsz (cdr (assoc 1 szed))))
              sp (caddr (assoc 10 szed))
        (cond
          ((wcmatch sz “H*X*X*X*X*”)      (kgperm x4 1 “HBEAM.DAT”))   ; Calculation ok
          ((wcmatch sz “L*X*X*X*”)      (kgperm x3 2 “ANGLE.DAT”))   ; Calculation ok
          ((wcmatch sz “C*X*X*X*X*”)      (kgperm x4 3 “CHANEL.DAT”))  ; Calculation ok
          ((wcmatch sz “I*X*X*X*X*”)      (kgperm x4 4 “IBEAM.DAT”))   ; Calculation ok
          ((wcmatch sz “T*X*X*X*X*”)      (kgperm x4 5 “T-BEAM.DAT”))  ; Calculation ok
          ((wcmatch sz “PL-*X*X*”)       (xptrs 4)   (plate))         ; Calculation ok
          ((wcmatch sz “F.B *X*X*”)       (xptrs 5)   (plate))         ; Calculation ok
          ((wcmatch sz “R.B %%C*X*”)      (xptrs 8)   (rd_bar))        ; Calculation ok
          ((wcmatch sz “CHK’D PL-*3.2*X*”)   (xptrs 10)  (chplate1))      ; Calculation ok
          ((wcmatch sz “CHK’D PL-*4.5*X*”)   (xptrs 10)  (chplate2))      ; Calculation ok
          ((wcmatch sz “CHK’D PL-*6*X*”)     (xptrs 10)  (chplate3))      ; Calculation ok
          ((wcmatch sz “EXP’D METAL-*2.3*X*”)  (xptrs 10)  (explate1))      ; Calculation ok
          ((wcmatch sz “EXP’D METAL-*6*X*”)  (xptrs 10)  (explate2))      ; Calculation ok
          ((wcmatch sz “EXP’D METAL-*4.5*X*”)  (xptrs 10)  (explate3))      ; Calculation ok
          ((wcmatch sz “LINER*X*X*”)      (xptrs 7)   (LINER))      ; Calculation ok
          ((wcmatch sz “RUBBER*X*X*”)     (xptrs 8)   (RUBBER))      ; Calculation ok
    ((wcmatch sz “PIPE *AX*”)             (xptrs 5)   (sgp_pipe))      ; Calculation ok
          ((wcmatch sz “SQ*X*X*”)        (xptrs 4)  (plate))
          ((wcmatch sz “CHK*X*X*”)        (xptrs 4)  (plate))
          ((wcmatch sz “W*X*X*”)        (xptrs 2)  (w_shap))
          ((wcmatch sz “G*X*X*X*”)        (xptrs 2)  (gratg))
          ((wcmatch sz “SERR.G*X*X*X*”)       (xptrs 7)  (serrgt))
          ((wcmatch sz “P*”%%*X*SC*X*”)      (xptrs 2)  (sch_p))
          ((wcmatch sz “P*”%%*X*”X*”)       (xptrs 2)  (in_pip))
          ((wcmatch sz “P*%%*X*X*”)        (xptrs 2)  (mm_pip))
          ((wcmatch sz “DIA*X*%%*”)        (xptrs 4)  (rd_bar))
          ((wcmatch sz “FOLDED PL*X*X*”)      (xptrs 10) (folded))
          ((wcmatch sz “IPET*X*”)      (xptrs 5)  (xrefkg “HIBERNIA.KGM”))
          ((wcmatch sz “[IU]P[EN]*X*,HE[AB]*X*”)  (xptrs 4)  (xrefkg “HIBERNIA.KGM”))
          ((wcmatch sz “HSS*X*X*X*”)              (xptrs 4)  (xrefkg “HIBERNIA.KGM”))
          ((wcmatch sz “2-L*X*X*”)      (xptrs 4)  (xrefkg “BPF.KGM”))
          (t (princ (strcat “n” orgsz ” is not standard pattern.”)))
        (if uwt
          (progn
            (if (< 1 uwt) (setq uwt (atof (rtos uwt 2 1))))
            (setq qty 1 ii -1)
            (while ii
              (if (setq en (ssname qtss (setq ii (1+ ii))))
                (progn
                  (if (< (* fa -2) (- sp (caddr (assoc 10 ed))) (* fa 2))
                      (setq qty (atoi (cdr (assoc 1 ed))) ii nil)
                (setq ii nil)
            (if (= qty 1)
              (weight totalp (if (> 0.1 uwt) “-” (rtos uwt 2 1)))
              (progn
                (weight unitp (if (> 0.1 uwt) (rtos uwt 2 1) (rtos uwt 2 1)))
                (weight totalp
                  (if (> 0.1 (setq twt (* qty uwt))) “-”
                    (if (> 0.1 uwp) (rtos twt 2 1) (rtos twt 2 1))
            (setq wtn (1+ wtn))
        (setq uwt nil kgm nil)
    (princ “Entities not selected.”)
  (princ (strcat “nSelected Descriptions is ” (itoa szn) ” items.”
                 “nCalculated Descriptions is ” (itoa wtn) ” items.”
  (setq *error* olderr)
  (setvar “osmode” old_snap)
  (command “layer” “S” “txt” “”)
  (command “-style” “romans” “” kck 0.75 “” “” “” “”)
  (prompt “n Auto Steel Weight Program [Rev. 2012. 08. 30.]”)
  (prompt “n ※ 주의사항 ※ 형강류 규격은 China GB Standard 임. “)
;; Program End !!!!
  • 150 조회
      2014-12-03T14:35:31+09:00답변 등록 답변 등록 일시 2014-12-03 2:35 pm
      http://cafe.naver.com/sbbom 이곳에 한번 가보세요 철골 관련 bom프로그램이 잘 만들어져 있네요
