홈/ 질문/Q 109212
등록일: 2017-12-122017-12-12T19:26:11+09:00 2017-12-12T19:26:11+09:00카테고리: AutoCAD & CADian
cad 리습파일 주기좀달아주세요.
(defun c:+(/ choi d_ts w_os ht ss grpt pt1 n k tot en tv rtv an)
   (setq choi (getvar “orthomode”)  d_ts (getvar “textsize”)
            w_os (getvar “osmode”) )
   (setvar “orthomode” 0) (setvar “osmode” 0)
   (setq ht d_ts)
         (setq lts1 (getvar “ltscale”))
         (setq lts (* 2 lts1))
   (prompt “nText Height<“) (prin1 ht) (prompt “>: “)
   (setq ht (getdist))
   (if (= ht nil) (setq ht d_ts))
   (prompt “nSelect number->”)
   (setq ss (ssget))
   (setq grpt (grread T))
   (setq pt1 (cadr grpt))
   (setq n (sslength ss))
   (setq k 0 tot 0)
   (while (<= 1 n)
        (setq en (ssname ss k))
        (setq tv (cdr (assoc 1 (entget en))))
        (setq kn (strlen tv))
        (if (/= (wcmatch tv “*,*”) nil)(progn
        (setq kk 2)
        (setq a0 (substr tv KK 1))
        (while (and (/= a0 “,”)(<= kk kn))
        (setq kk (+ kk 1))
   (princ tv)
               (if (= a0 “,”)(progn
                   (setq a1 (substr tv 1 (- kk 1)))
                   (setq a2 (substr tv (+ kk 1) (- kn kk)))
                   (setq tv (strcat a1 a2))
;                   (entmod (subst (cons 1 tv) (assoc 1 (entget en))(entget en)))
(prompt “nSelect number122221->”)
   (princ tv)
  (prompt “nSelect number11111->”)
   (princ tv)
        (setq rtv (atof tv))
        (setq tot (+ tot rtv))
        (setq n (- n 1))
        (setq k (+ k 1))
   (setq tot (rtos tot 2 3))
   (prompt “n합 계 : “) (prin1 tot)
         (setvar “osmode” 0)
    (setq p12 (getpoint “nEnter text point->”))
    (command “text” “j” “r” p12 lts “0” tot)
(defun c:-(/ ot ts os ht ss1 en1 ent1 tv1 ss2 en2 ent2 tv2 grpt pt1 rst1
                      tot1 rtv1 rtv2 en an)
   (setq ot (getvar “orthomode”)  ts (getvar “textsize”)
   (setq ht ts)
   (setq ht (getdist))
   (if (= ht nil) (setq ht ts))
   (prompt “nSelect first number->”)
   (setq ss1 (entsel) en1 (car ss1))   (redraw en1 3)
   (setq ent1 (assoc 1 (entget (car ss1))))
   (setq tv1 (cdr ent1))
   (prompt “nSelect second number->”)
   (setq ss2 (entsel) en2 (car ss2))   (redraw en2 3)
   (setq ent2 (assoc 1 (entget (car ss2))))
   (setq tv2 (cdr ent2))
   (setq grpt (grread T) pt1 (cadr grpt))
   (setq  rst1 0)
   (setq rtv1 (atof tv1)  rtv2 (atof tv2))
   (setq rst1 (- rtv1 rtv2))
   (setq tot1 (abs rst1))
   (setq tot1 (rtos tot1 2 3))
   (if (= (wcmatch tot1 “*.*”) nil)
       (setq tot1 (strcat tot1 “.00”)))
   (setq an (strlen tot1))
   (if (= (substr tot1 (- an 1) 1) “.”)
       (setq tot1 (strcat tot1 “0”)) )
   (if (< rst1 0)
       (setq tot1 (strcat “-” tot1)))
   (prompt “n결 과 : “) (prin1 rst1)
   (command “text” “j” “r” pt1 ht “0” tot1)
   (redraw en1 4) (redraw en2 4)
   (prompt “nEnter text point->”)
   (command “move” “l” “” pt1 pause)
   (setvar “orthomode” ot) (setvar “osmode” os)
   (prin1)
(defun c:*(/ choi d_ts w_os ht ss grpt pt1 n k tot en tv rtv an)
   (setq ht d_ts)
;   (prompt “nText Height<“) (prin1 ht) (prompt “>: “)
;   (setq ht (getdist))
    (setq tot 1)
   (princ tot)
;   (if (= ht nil) (setq ht d_ts))
   (setq ss (ssget))
   (setq k 0 tot 1)
   (while (<= 1 n)
        (setq kk 2)
        (setq kk (+ kk 1))
   (princ tv)
   (princ tv)
   (princ tot)
        (setq tot (* tot rtv))
        (setq n (- n 1))
        (setq k (+ k 1))
         (setvar “osmode” 0)
    (command “text” “j” “r” p12 ht “0” tot)
(defun c:/(/ choi d_ts w_os ht ss1 en1 ent1 tv1 ss2 en2 ent2 tv2 grpt pt1 rst1
   (setq ht d_ts)
   (setq ht (getdist))
   (setq  rst1 0)
   (setq rst1 (/ rtv1 rtv2));나누기
   (setq tot1 (rtos tot1 2 5));자리수
       (setq tot1 (strcat tot1 “.000”)))
   (if (< rst1 0)
   (setvar “orthomode” choi) (setvar “osmode” w_os)
   (prin1)
설비쪽일을하고있는데견적내기가너무시간이오래걸려서어떻게든시간을단축하고자
알아보든중에리습이라는파일이있다는걸알고폭풍검색해서하나발견해서몰립니다.
아무것도몰라서수정하고싶어도못하겠네요.
제가원하는것은아니지만내용을알면좀할수있을것같아서요.
제가원하는것은부품하나견적을낸다하면 드래그한번으로 재료비 : 0000원, 볼트 : 0000원 텝 : 0000원 도금 : 0000원이런식으로원하는데어렇겠죠.^^그래서연구좀해볼려구요.
왕초보라아무것도모릅니다..
옆에주석좀달아주세요고수님들..
그리고리습강좌하는싸이트아시는분있음정보공유좀부탁드립니다.
  • 54 조회
    2. 수야12 Lv.22
      2017-12-13T12:27:53+09:00답변 등록 답변 등록 일시 2017-12-13 12:27 pm
      아… 이게 주석이 필요하시다면 전혀 리습을 해보신적 없으시다는 얘긴데요 주석이 의미 있을까 싶네요  여기다 주석을 단다면 주석이 아니라 강의가 되겠네요
      http://www.afralisp.net/index.php&nbsp;
      http://cafe.daum.net/archimore&nbsp;
      일단 이곳을 둘러보시도록하세요
